Multiple Markups on The Same Page - Best Solution?
Hi there! I have a website that is build in react javascript, and I'm trying to use markup on my pages. They are mostly articles about general topics with common questions (about the topic), and for most articles I would like to use two markups:
article markup + FAQ Markup ( for the questions in the article)
article markup + how-to markup
Can I do this or will Google get confused? Since I have two @type at the same time, for example @type": "FAQPage" and "@type": "Article".
How should I think? I'm using https://schema.dev/ right now.
Doesn't this contradict that you can only have one or the other?
"Multiple items on a page
Multiple items on a page means that there is more than one kind of thing on a page. For example, a page could contain a recipe, a video that shows how to make that recipe, and breadcrumb information for how people can discover that recipe. All of this user-visible information can also be marked up with structured data, which makes it easier for search engines like Google Search to understand the information on a page. When you add more items that apply to a page, Google Search has a fuller picture of what the page is about and can display that page in different search features.
Google Search understands multiple items on a page, whether you nest the items or specify each item individually:
- Nesting: When there is one main item, and additional items are grouped under the main item. This is particularly helpful when grouping related items (for example, a recipe with a video and reviews).
- Individual items: When each item is a separate block on the same page."
https://developers.google.com/search/docs/guides/sd-policies#multiple-items
Article
Ah okay, so this article for example can only have Article schema? Or would it be smart to mark it as an FAQ schema since it answers a lot of questions and we can only use one or the other?
I see. You can only have one or the other. If you are trying to create scheme for a How-to, I would create a page and structure it as such. We use https://technicalseo.com/tools/schema-markup-generator/ - same goes for the Article Scheme. I hope that helps.
But I haven't added any markups yet, I'm in research phase!
What's your URL? Perhaps we can look into it and try to give you a more technical answer.
How to update Schema markup code to all pages of my website ?
Hi all i have a website with 1k+ pages and i have schema markup code for reviews and FAQ's, so need help in knowing how to update code for all pages in one go without using tag manager as updating to all pages manually is similar to impossible, let me know is there any way out to achieve the results and my website is built on word-press, awaiting for earliest reply......... Thanks
Intermediate & Advanced SEO | | atiagr1232 -
Fresh page versus old page climbing up the rankings.
Hello, I have noticed that if publishe a webpage that google has never seen it ranks right away and usually in a descend position to start with (not great but descend). Usually top 30 to 50 and then over the months it slowly climbs up the rankings. However, if my page has been existing for let's say 3 years and I make changes to it, it takes much longer to climb up the rankings Has someone noticed that too ? and why is that ?
Intermediate & Advanced SEO | | seoanalytics0 -
Too many on page links
Hi I know previously it was recommended to stick to under 100 links on the page, but I've run a crawl and mine are over this now with 130+ How important is this now? I've read a few articles to say it's not as crucial as before. Thanks!
Intermediate & Advanced SEO | | BeckyKey1 -
Best-practice URL structures with multiple filter combinations
Hello, We're putting together a large piece of content that will have some interactive filtering elements. There are two types of filters, topics and object types. The architecture under the hood constrains us so that everything needs to be in URL parameters. If someone selects a single filter, this can look pretty clean: www.domain.com/project?topic=firstTopic
Intermediate & Advanced SEO | | digitalcrc
or
www.domain.com/project?object=typeOne The problems arise when people select multiple topics, potentially across two different filter types: www.domain.com/project?topic=firstTopic-secondTopic-thirdTopic&object=typeOne-typeTwo I've raised concerns around the structure in general, but it seems to be too late at this point so now I'm scratching my head thinking of how best to get these indexed. I have two main concerns: A ton of near-duplicate content and hundreds of URLs being created and indexed with various filter combinations added Over-reacting to the first point above and over-canonicalizing/no-indexing combination pages to the detriment of the content as a whole Would the best approach be to index each single topic filter individually, and canonicalize any combinations to the 'view all' page? I don't have much experience with e-commerce SEO (which this problem seems to have the most in common with) so any advice is greatly appreciated. Thanks!0 -
Best practice for retiring old product pages
We’re a software company. Would someone be able to help me with a basic process for retiring old product pages and re-directing the SEO value to new pages. We are retiring some old products to focus on new products. The new software has much similar functionality to the old software, but has more features. How can we ensure that the new pages get the best start in life? Also, what is the best way of doing this for users? Our plan currently is to: Leave the old pages up initially with a message to the user that the old software has been retired. There will also be a message explaining that the user might be interested in one of our new products and a link to the new pages. When traffic to these pages reduces, then we will delete these pages and re-direct them to the homepage. Has anyone got any recommendations for how we could approach this differently? One idea that I’m considering is to immediately re-direct the old product pages to the new pages. I was wondering if we could then provide a message to the user explaining that the old product has been retired but that the new improved product is available. I’d also be interested in pointing the re-directs to the new product pages that are most relevant rather than the homepage, so that they get the value of the old links. I’ve found in the past that old retirement pages for products can outrank the new pages as until you 301 them then all the links and authority flow to these pages. Any help would be very much appreciated 🙂
Intermediate & Advanced SEO | | RG_SEO0 -
Do 404 pages pass link juice? And best practices...
Last year Google said bad links to 404 pages wouldn't hurt your site. Could that still be the case in light of recent Google updates to try and combat spammy links and negative SEO? Can links to 404 pages benefit a website and pass link juice? I'd assume at the very least that any link juice will pass through links FROM the 404 page? Many websites have great 404 pages that get linked to: http://www.opensiteexplorer.org/links?site=http%3A%2F%2Fretardzone.com%2F404 - that was the first of four I checked from the "60 Really Cool...404 Pages" that actually returned the 404 HTTP Status! So apologies if you find the word 'retard' offensive. According to Open Site Explorer it has a decent Page Authority and number of backlinks - but it doesn't show in Google's SERPs. I'd never do it, but if you have a particularly well-linked to 404 page, is there an argument for giving it 200 OK Status? Finally, what are the best practices regarding 404s and address bar links? For example, if
Intermediate & Advanced SEO | | Alex-Harford
www.examplesite.com/3rwdfs returns a 404 error, should I make that redirect to
www.examplesite.com/404 or leave it as is? Redirecting to www.examplesite.com/404 might not be user-friendly as people won't be able to correct the URL in the address bar. But if I have a great 404 page that people link to, I don't want links going to loads of random pages do I? Is either way considered best practice? If I did a 301 redirect I guess it would send the wrong signal to the crawlers? Should I use a 302 redirect, or even a 304 Not Modified redirect?1 -
Multiple sites in the same niche
Hi All A question regarding multiple sites in the same niche... If I have say 10 sites all targetting the same niche yet all on different C-class IPs with different hosts, registrars, whois data and ages can I use the same template, or will Google discern a pattern? Basically I have developed a WordPress template which I want to use on the sites albeit with different logos / brand colours. NB/ All of the 10 sites will have unique, original content and they will NOT be interlinked
Intermediate & Advanced SEO | | danielparry1 -
301 - should I redirect entire domain or page for page?
Hi, We recently enabled a 301 on our domain from our old website to our new website. On the advice of fellow mozzer's we copied the old site exactly to the new domain, then did the 301 so that the sites are identical. Question is, should we be doing the 301 as a whole domain redirect, i.e. www.oldsite.com is now > www.newsite.com, or individually setting each page, i.e. www.oldsite.com/page1 is now www.newsite.com/page1 etc for each page in our site? Remembering that both old and new sites (for now) are identical copies. Also we set the 301 about 5 days ago and have verified its working but haven't seen a single change in rank either from the old site or new - is this because Google hasn't likely re-indexed yet? Thanks, Anthony
Intermediate & Advanced SEO | | Grenadi0
