Backlink quality vs quantity: Should I keep spammy backlinks?
Regarding backlinks, I'm wondering which is more advantageous for domain authority and Google reputation:
- Option 1: More backlinks including a lot of spammy links
- Option 2: Fewer backlinks but only reliable, non-spam links
I've researched this topic around the web a bit and understand that the answer is somewhere in the middle, but given my site's specific backlink volume, the answer might lean one way or the other.
For context, my site has a spam score of 2%, and when I did a quick backlink audit, roughly 20% are ones I want to disavow. However, I don't want to eliminate so many backlinks that my DA goes down. As always, we are working to build quality backlinks, but I'm interested in whether eliminating 20% of backlinks will hurt my DA.
Thank you!
Backlinks are always about quality not quantity. Google does not like too many backlinks and especially spammy backlinks. I would suggest you to go with quality backlinks if you want long term and sustainable results otherwise there will always be a threat of getting penalized by google if you focus on spammy backlinks.
It's a myth that your DA drops because you put links in disavow. Disavow is a google only (or bing) tool, where lets say you get spammy links from a rogue domain and there's no way you can get 'm removed.
MOZ cant read your disavow file either you file into google. So i'm not sure on how the link is being put here. With MOZ, or any other tool, they just calculate the amount of incoming, FOLLOW links and presume your DA on some magical number. Thats all there is to it. Again, PA/DA has nothing in common at all with Google as Google maintains their own algorithm.
Hello again,
Thanks for the clarification and the link. I've read through that and a few other sources across the web, but none of them seemed to answer my question the way you did, so thanks! Our backlink profile is pretty balanced with spammy and definitely not spammy, so I'm not super concerned about it, but I appreciate the reminder.
I should also clarify, these may hurt you if they are your only links. If you have very little equitable links, this may cause Google and other search engines to falsely recognize you as spam. So just be careful and be on the look out for extra suspicious spam links. The balanced approach is the best approach: don't worry but stay aware!
Here is a more technical write-up from Moz that I reccomend: https://cloudz.click/help/link-explorer/link-building/spam-score
No problem Liana.
- That is correct. Google understands that you don't have control of 3rd party sites, so instead of penalizing you, they minimize/ delete the effect the spam site links have.
- Yes, but only kind of. It may or may not increase PA/ DA, but according to Google it shouldn't hurt you.
But yeah that's the gist of it! Instead taking the time investigating and disavowing links, you could spend that time cultivating relationships with other websites and businesses that could give you nice quality linkage.
Hope this answer works for you.
Hello Advanced Air Ambulance SEO!
Thanks for the quick and thorough response. Please confirm if I understand you correctly:
- I can leave spammy backlinks alone (not spend time disavowing them) _unless _I see a manual action in Search Console, which would indicate that Google sees an issue and is penalizing my site until I disavow the links. Without this manual action, there's no indication that the spam links are hurting my rankings or DA.
- Leaving spammy backlinks that don't incur a manual action may actually increase DA since leaving them maintains a higher volume of backlinks (albeit some spammy), and backlink quantity is a contributor to DA.
Thank you!
Hi Liana,
As far as spammy links, Google has done well detecting whether or not they are intentional, aka black hat. If they aren't, Google does not penalize you for these links, so it's best to leave them.
As far as a strategy for generating links to your website, you should always focus on high quality over quantity. High quality links give you exponentially more return than high quantity of bad links.
I recommend this article Google wrote for us to understand when and how to disavow links.
https://support.google.com/webmasters/answer/2648487?hl=en
In short, rarely do you ever need to disavow links, even if they have a high spam score. You are only hurt when they sense you are gaming the system and in the case that they detect or suspect unethical backlinking, you will be penalized with a "manual action". You can check if you were penalized, as well as disavow flagged backlinks, in the Google Search Console.
My backlinks are not showing in webmaster tools? Why
Hi Experts, I have follow backlinks from a domain for 6 months, but its not apear in Links to Your Site tools (search console) that domain has 302k indexed pages in google! Could you please explain me why google not showing this type of backlinks?
Technical SEO | | denakalami7 -
How much difference does .co.uk vs .com for SEO make?
My Website has a .com domain. However I have noticed that for local businesses all of them have a .co.uk (UK business) TLD (check plumbers southampton for example). I have also noticed that on checking my serp rankings, I'm on page 1 if searched on Google.com but page 2 if searched on google.co.uk. Now being UK based I would assume most of my customers will be redirected to google.co.uk so I'm wondering how much of an impact this actually makes? Would it be worth purchasing .co.uk domain and transferring my website to that? Or run them both at the same time and set up 301 direct on my .com to .co.uk? Thanks
Technical SEO | | Marvellous0 -
Title Tag vs. H1 / H2
OK, Title tag, no problem, it's the SEO juice, appears on SERP, etc. Got it. But I'm reading up on H1 and getting conflicting bits of information ... Only use H1 once? H1 is crucial for SERP Use H1s for subheads Google almost never looks past H2 for relevance So say I've got a blog post with three sections ... do I use H1 three times (or does Google think you're playing them ...) Or do I create a "big" H1 subhead and then use H2s? Or just use all H2s because H1s are scary? 🙂 I frequently use subheads, it would seem weird to me to have one a font size bigger than another, but of course I can adjust that in settings ... Thoughts? Lisa
Technical SEO | | ChristianRubio0 -
Multilingual Website - Sub-domain VS Sub-directory
Hi Folks - Need your advice on the pros and cons of going with a sub-domain vs a sub-directory approach for a multi lingual website. The best would be a ccTLD but that is not possible now, so I would be more interested in knowing your take on these 2 options. Though, I have gone through http://www.stateofsearch.com/international-multilingual-sites-criteria-to-establish-seo-friendly-structure/ and this somewhat vouches for a sub-directory, but what would you say'?
Technical SEO | | RanjeetP0 -
Subdomain vs Main Domain Penalties
We have a client who's main root.com domain is currently penalized by Google, but the subdomain.root.com is appearing very well. We're stumped - any ideas why?
Technical SEO | | Prospector-Plastics0 -
Redirection plugin: wordpress vs apache module?
Hi, Any one familiar with the wordpress plugin 'redirection' Are there any SEO benefits of having the plugin write the 301 redirects into the .htaccess? The standard mode does not use .htaccess but has wordpress genertae the 301s Thanks
Technical SEO | | Justin10 -
Microsite on subdomain vs. subdirectory
Based on this post from 2009, it's recommended in most situations to set up a microsite as a subdirectory as opposed to a subdomain. http://www.seomoz.org/blog/understanding-root-domains-subdomains-vs-subfolders-microsites. The primary argument seems to be that the search engines view the subdomain as a separate entity from the domain and therefore, the subdomain doesn't benefit from any of the trust rank, quality scores, etc. Rand made a comment that seemed like the subdomain could SOMETIMES inherit some of these factors, but didn't expound on those instances. What determines whether the search engine will view your subdomain hosted microsite as part of the main domain vs. a completely separate site? I read it has to do with the interlinking between the two.
Technical SEO | | ryanwats0 -
Syndication: Link back vs. Rel Canonical
For content syndication, let's say I have the choice of (1) a link back or (2) a cross domain rel canonical to the original page, which one would you choose and why? (I'm trying to pick the best option to save dev time!) I'm also curious to know what would be the difference in SERPs between the link back & the canonical solution for the original publisher and for sydication partners? (I would prefer not having the syndication partners disappeared entirely from SERPs, I just want to make sure I'm first!) A side question: What's the difference in real life between the Google source attribution tag & the cross domain rel canonical tag? Thanks! PS: Don't know if it helps but note that we can syndicate 1 article to multiple syndication partners (It would't be impossible to see 1 article syndicated to 50 partners)
Technical SEO | | raywatson0
