How much difference does .co.uk vs .com for SEO make?
My Website has a .com domain. However I have noticed that for local businesses all of them have a .co.uk (UK business) TLD (check plumbers southampton for example). I have also noticed that on checking my serp rankings, I'm on page 1 if searched on Google.com but page 2 if searched on google.co.uk.
Now being UK based I would assume most of my customers will be redirected to google.co.uk so I'm wondering how much of an impact this actually makes? Would it be worth purchasing .co.uk domain and transferring my website to that? Or run them both at the same time and set up 301 direct on my .com to .co.uk?
Update to the above. Just checked that the results also apply in Yahoo and Bing, in that I rank first page for .com but 2-3rd page for .co.uk. As I understand setting geographic target in WMT would have no bearing on this? Seems .searchengine.co.uk really prefers .co.uk over .com?
Sorry, when you say keep .com and do a 301 redirect to .co.uk. Do you mean I duplicate the website at .co.uk and redirect all pages from .com to .co.uk accordingly? Would this cause a significant SEO drop as all my past backlink work have been towards .com?
Edit: I misread, I believe you just said do a 301 from .co.uk TO .com. Correct me if I'm wrong
Thanks again
If you only set WMT's to the UK today you will have to wait a while for it to update. That would be the primary cause of the issue you have raised above - so you have solved it!
I would keep your .com do a 301 re-direct on the .co.uk.
Well done.
I bought the .co.uk a while ago and was actually debating which one to use, .com or .co.uk. In the end we went with .com.
Would it be worth transferring the website to .co.uk now and setting up a 301 redirect at .com to .co.uk?
Yes, I only just set WMT to UK today, will that suffice?
Is the geo setting in WMT's set to UK? You need to tell google what is your target audience in your case the UK.
If the .co.uk is available I would buy it to stop competitors buying it, and re-directing it to there site.
How .ae and .com domain in SEO performance for UAE region?
I have a domain for my UAE based project called https://mydubaiseo.com/ and however, one of my colleagues suggested going with .ae option.
Technical SEO | | 0eup.ombitao
Whether if we change the domain like as suggested get earlier results than .com domain or what?\Which domain .com or .ae ranks faster in UAE location if the SEO strategies followed in the same way?0 -
# Tag - opacity and SEO impact
Technical SEO | | Tiffany_Barn
I have a query animation 'fade-in-up' on my website: tiffanybarnard.com which moves the H1 tag slightly and fades it in from zero opacity to 1. Will this affect the SEO value of the H1 tag?
Thank you!0 -
Personalized Content Vs. Cloaking
Hi Moz Community, I have a question about personalization of content, can we serve personalized content without being penalized for serving different content to robots vs. users? If content starts in the same initial state for all users, including crawlers, is it safe to assume there should be no impact on SEO because personalization will not happen for anyone until there is some interaction? Thanks,
Technical SEO | | znotes0 -
DNS vs IIS redirection
I'm working on a project where a site has gone through a rebrand and is therefore also moving to a new domain name. Some pages have been merged on the new site so it's not a lift and shift job and so I'm writing up a redirect plan. Their IT dept have asked if we want redirects done by DNS redirect or IIS redirect. Which one will allow us to have redirects on a page level and not a domain level? I think IIS may be the right route but would love your thoughts on this please.
Technical SEO | | Marketing_Today1 -
Do Abbreviations Hurt SEO Results?
We have certain products that we've abbreviated since it's a bit too long. For example, the word Fair Trade Organic is one of our categories and we abbreviate it to FTO. If I put FTO on our meta tag titles and links instead of the actual word, would that provide a weaker result?
Technical SEO | | ckroaster0 -
.ca and. com domains
Hello, currently the main site im working on is a .com, but have the .ca version purchased from register.com. should i have this setup to redirect to the .com site. will google see these as dup content. We have the .ca for our canadian customers but both sites are identical. Thank you
Technical SEO | | TP_Marketing0 -
Rel=Canonical, WWW vs non WWW and SEO
Okay so I'm a bit of a loss here. For what ever reason just about every single Wordpress site I has will turn www.mysite.com into mysite.com in the browser bar. I assume this is the rel=canonical tag at work, there are no 301s on my site. When I use the Open Site Explorer and type in www.mysite.com it shows a domain authority of around 40 and a few hundred backlinks... and then I get the message. Oh Hey! It looks like that URL redirects to XXXXXX. Would you like to see data for <a class="clickable redirects">that URL instead</a>? So if I click to see this data instead I have less than half of that domain authority and about 2 backlinks. *** Does this make a difference SEO wise? Should my non WWW be redirecting to my WWW instead because that's where the domain authority and backlinks are? Why am I getting two different domain authority and backlink counts if they are essentially the same? Or am I wrong and all that link juice and authority passes just the same?
Technical SEO | | twilightofidols0 -
.com or .co.uk in UK index? but the .com has higher domain authority...
Hi there i have a .com and a .co.uk for a site that has been around a while. However not much seo has been done on it, i was wonderign do i continue to optimise for the .com or switch to the .co.uk to rank in Google UK index for various search terms. .COM = 40 domain authority .CO.UK - 10 domain authority. Let the debate start 🙂
Technical SEO | | pauledwards0
