Product Schema Markup for All Products
Hi Team,
Google search console used to allow you to use their structured data markup helperhttps://www.google.com/webmasters/markup-helper/u/0/ to markup multiple product pages at once that were similar. I do not see this feature anymore with the new search console. Does anyone have a recommendation for marking up multiple product pages without having to have schema markup firing in GTM for each product page?
thanks for the schema code .
I already try with my personal website .please have a look at the code seo company in dubai
It is a AspDotNetStorefront E-commerce CMS. These developer tools are helpful. I have looked into the dynamic schema markup blog, but am not sure it is the best to implement this if there are a lot of products. I might also consider trying to have a developer implement article markup for a drupal site. This has been helpful thank you.
I agree what is storefront I can't find a CMS called storefront?
If Schema markup is being added to a brand new site, it’s much easier for developers to add the Schema as part of the site build, as opposed to layering it on after the website has already been coded. Developers benefit from SEOs telling them specifically which page elements require Schema (location, events, etc.) and a link to the respective Schema type on Schema.org, so the developer can figure out the best approach for implementation.
SEOs have largely taken ownership of writing JSON-LD themselves, which is great for speeding up the process of implementing Schema. JSON-LD is generally easiest for developers to implement, but adding inline Schema is usually simple as well. There are some plugins that can assist with the implementation, but they generally only support basic Schema types, such as the Website or Organization.
One way:
https://cloudz.click/blog/using-google-tag-manager-to-dynamically-generate-schema-org-json-ld-tags
https://cloudz.click/blog/json-ld-for-beginners
You can use Cloudflare
https://github.com/cloudflare/doca/blob/master/example/product.json
https://blog.cloudflare.com/cloudflares-json-powered-documentation-generator/
https://www.cloudflare.com/apps/developer/docs/install-json/options
I hope I have been of help,
Tom
Thank you Tom,
We are on storefront currently. We had previously used the schema markup tool for some of their products. I have used Google markup helper and technicalseo.com resources before to create JSON-LD to fire in GTM for blogs, vidoes, how-to pages, etc but not for product pages. Mostly because I agree that it can be done in a better way. Maybe consulting with a developer to implement product markup is best.
HI
Can I ask what platform you are using? If you're using an e-commerce platform like Magento, Shopify, BigCommerce, etc. There are simple ways of writing code that will do a better job as well as plug-ins that you can purchase and/or use for free.
Or if in the unlikely event you are just running an E-commerce website without a CMS you can still do this via coding. there is a method no matter what flavor of kosher using rather it be Ruby, PHP NodeJS, etc.
FYI
Google does NOT recommend Using Tag Manager to Implement Schema Markup.
John Mueller from Google advises against using Google Tag Manager to deploy Structured Data and mentions that the ideal solution is to add the structured data directly into the HTML. So ideally process it server-side and pass it via HTML instead of relying on a client-side solution like Javascript.
While this is not the ideal solution, as SEOs we know that we are not always in ideal situations and at times our best bet is to deploy it through a solution like Google Tag Manager. You could also look at deploying it via an Edge Computing Solution like Cloudflare Workers.
https://www.cloudflare.com/en-au/products/cloudflare-workers/
It is less than ideal to use Google tag manager to deploy JSON-LD to websites. It can be done but obviously it's not the best way.
just because it's not on the new search console yet does not mean that Google's structured data markup helper tool is obsolete.
Yes if you want to ad JSON-LD
Use any of the tools here
https://www.schemaapp.com/60-structured-data-tools-create-test-plugins-more/
Convert to GTM
https://saijogeorge.com/json-ld-schema-generator/tag-manager-fix/
You can add basic JSON-LD with
https://www.bounteous.com/insights/2017/03/20/seo-structured-data-recipe-gtm/
I use this to make this example
https://technicalseo.com/tools/schema-markup-generator/
GTM Friendly code
Tom
Product schema GSC Error 'offers, review, or aggregateRating should be specified'
I do not have a sku, global identifier, rating or offer for my product. Nonetheless it is my product. The price is variable (as it's insurance) so it would be inappropriate to provide a high or low price. Therefore, these items were not included in my product schema. SD Testing tool showed 2 warnings, for missing sku and global identifier. Google Search Console gave me an error today that said: 'offers, review, or aggregateRating should be specified' I don't want to be dishonest in supplying any of these, but I also don't want to have my page deprecated in the search results. BUT I DO want my item to show up as a product. Should I forget the product schema? Advice/suggestions? Thanks in advance.
Technical SEO | | RoxBrock1 -
Truncated product names
Due to the restraints of category page layout many of the products in certain categories have the product titles truncated, in some cases missing off 2-5 words depending on the product in question. The product name which displays on the category page is lifted straight from the product page itself, so not possible to do something like "product name including spec..." to place ... to indicate a bit more. I'm assuming not but just wanted to check that Google will not frown on this. Text is not being hidden it just does not render fully in the restricted space. So there is a scenario of 'bits of' text in the source not displaying on the rendered page.
Technical SEO | | MickEdwards0 -
Size of image for article Schema
Hi, I implemented schema markup for an article and all tested fine and I can see it being fired in preview mode of Google Tag Manager. But when I run the URL which has it applied through Google Structured Testing tool it is not appearing. I have now read that the image needs to be a certain size. For AMP articles this appears to be 12oo pixels wide http://www.thesempost.com/google-changes-image-size-requirements-amp-articles/ But what about non-AMP articles? Does it need to be that big too?
Technical SEO | | AL123al0 -
When should a variant be a variant and when should it be a separate product from an SEO POV?
Hi all, We are looking at changing our current e-commerce store to a new platform and in doing so thinking of making some changes to how we list products in sub-categories. We have seen related questions asking about splitting a single product into multiple products to rank for different terms, but we are wondering about combining multiple products into a single product page? The examples we have seen have been about fashion items with variants of colour and size. However, the products we sell have variances that change the appearance, dimensions and technical specification, so we would like to ask the MOZ community if combining products with these variances would still be deemed good practice? We sell wood burning stoves and a good example of a product that we are considering combining is the Scan 85 stove, which is available in eight different configurations: 85-1, 85-2, 85-3 etc. Scan themselves refer to each version as a separate product and they are bought, stocked and sold as separate products. Wood burning stoves like this typically have a firebox in the centre and then design options that can change the top, side, base, door, colour and fuel. In this example, the firebox is the Scan 85 and the variation is the last number, each of which corresponds to a different design option changing both the appearance and dimensions (see attached image). We have them listed as eight different products on our current site, one for each version. Primarily because each option has its own name (albeit 1-digit difference) which when we created the pages we thought that more pages would present us with more ranking opportunity. However, we have since learnt that because these eight pages are all so similar and it is difficult to write unique content about each product (with the 85-1 and 85-2 the only difference between the models are the black trim on the 85-1 and the silver trim on 85-2). Especially as when talking about the firebox itself, how well the fire burns, how controllable it is etc, will be the same for all versions. Likewise, earning backlinks to eight separate pages is also very difficult. Exploring this lead, us to the question, when is a variant a variant and when is it a separate product? Are there hard and fast rules for what defines variants and products? Or does it simply vary from industry to industry product to product, and if so should we be looking at it from a UX or SEO POV, when making that decision? Our hope is that if we combine these eight products into a single high-quality page, it will present us with a greater ranking opportunity for that one page over eight individual pages. We also hope that in doing so will allow us to create a more intuitive UX on a single page with a unique description, more reviews focused on one page and an explanation of the options available, all of which should lead to more conversions. Finally, by creating a better UX and unique detailed description we hope that there is a higher chance of us earning product level backlinks then we do with eight lower quality pages. One of the issues in creating a single product page for all the variants is the sub-category/results pages, as we would be removing eight simple products and replacing them with one complex product. We have questions over how this would work from a filter/facet level whereby when you apply a filter there is an expectation that the image shown will match the criteria, so if we filter for stoves with a silver trim for example, there is an expectation to only see stoves that have a silver trim in the results. When you have separate product pages you have separate listings which makes this easier to only bring back the models matching the criteria. However, when you have a single page this is more complex as you will need a default image for non-filtered results and then the ability to assign an image to lots of different attributes so that the correct image is always shown that matches the criteria selected. All of which we have been assured is do-able but adds an extra level of complexity to the process from an admin side. The alternative to doing this would be to create eight simple/child products and link them to one configurable/parent product. We could them list the simple products into the results pages and have them all linking back to the main configurable product which could load with the options of the simple product that was selected. From an SEO POV this brings in some more work, redirecting each page to the parent, but ultimately this could provide a better UX and might be the better solution. Has anyone got any experience in doing either of these options before? Both options above with affect the number of products we have available, so does the number of products in a sub-category effect the ability for that category page to rank? We currently have around 500 products in our wood burning stoves category, with perhaps an additional 300 to add. If we go down the combining into a single product page route this will reduce the number of products by around a third. If we keep all the simple/child products, then this will stay around the same. So, have we missed something obvious? Is there a glaring issue that we have overlooked from an SEO point of view as well as from the customer experience? We would appreciate your thoughts on this. Thanks, Reece scan85-1.jpg
Technical SEO | | fireproductsuk0 -
Schema Markup for property listings (estate agent)
Hello, I've been looking online for some help with this. An estate agent has a page of properties for sale. Is it possible to mark these individual properties up and if so would they appear as rich snippets in the SERPS - never seen anything like this for properties for sale so just wondered,
Technical SEO | | AL123al1 -
Canonical for duplicate pages in ecommerce site and the product out of stock
I’m an SEO for an ecommerce site that sells shoes I have duplicate pages for different colors of the same product (unique URL for each color), Conventionally I have added canonical tags for each page, which direct to a specific product URL My question is what happens when a product which the googlbot is direct to, is out of stock but is still listed in the canonical tag ?
Technical SEO | | shoesonline0 -
Schema for Banks and SEO
I'm researching Schema opportunities for a bank, but besides the shema markup available today (like bankorcreditunion) and developments with FIBO, I can find no answer as to the effect of tagging interest rates and such in terms of SERP/CTR performance or visibility. Does anyone have a case study to share or some insight on the matter?
Technical SEO | | Netsociety0 -
Can you mark up a page using Schema.org and Facebook Open Graph?
Is it possible to use both Schema.org and Facebook Open Graph for structured data markup? On the Google Webmaster Central blog, they say, "you should avoid mixing the formats together on the same web page, as this can confuse our parsers." Source - http://googlewebmastercentral.blogspot.com/2011/06/introducing-schemaorg-search-engines.html
Technical SEO | | SAMarketing1
