Product schema GSC Error 'offers, review, or aggregateRating should be specified'
I do not have a sku, global identifier, rating or offer for my product. Nonetheless it is my product. The price is variable (as it's insurance) so it would be inappropriate to provide a high or low price. Therefore, these items were not included in my product schema. SD Testing tool showed 2 warnings, for missing sku and global identifier.
Google Search Console gave me an error today that said: 'offers, review, or aggregateRating should be specified'
I don't want to be dishonest in supplying any of these, but I also don't want to have my page deprecated in the search results. BUT I DO want my item to show up as a product. Should I forget the product schema? Advice/suggestions?
Thanks in advance.
Really interested to see that others have been receiving this too, we have been having this flagged on a couple of sites / accounts over the past month or two
Basically, Google Data Studio's schema error view is 'richer' than that of Google's schema tool (stand-alone) which has been left behind a bit in terms of changing standards. Quite often you can put the pages highlighted by GSC (Google Search Console) into Google's schema tool, and they will show as having warnings only (no errors) yet GSC says there are errors (very confusing for a lot of people)
Let's look at an example:
- https://d.pr/i/xEqlJj.png (screenshot step 1)
- https://d.pr/i/tK9jVB.png (screenshot step 2)
- https://d.pr/i/dVriHh.png (screenshot step 3)
- https://d.pr/i/X60nRi.png (screenshot step 4)
... basically the schema tool separates issues into two categories, errors and warnings
But Google Search Console's view of schema errors, is now richer and more advanced than that (so adhere to GSC specs, not schema tool specs - if they ever contradict each other!)
What GSC is basically saying is this:
"Offers, review and aggregateRating are recommended only and usually cause a warning rather than an error if omitted. However, now we are taking a more complex view. If any one of these fields / properties is omitted, that's okay but one of the three MUST now be present - or it will change from an warning to an error. SO to be clear, if one or two of these is missing, it's not a big deal - but if all three are missing, to us at Google - the product no longer constitutes as a valid product"
So what are the implications of having schema which generates erroneous, invalid products in Google's eyes?
This was the key statement I found from Google:
Google have this document on the Merchant Center (all about Google Shopping paid activity): https://support.google.com/merchants/answer/6069143?hl=en-GB
They say: "Valid structured markup allows us to read your product data and enable two features: (1) Automatic item updates: Automatic item updates reduce the risk of account suspension and temporary item disapproval due to price and availability mismatches. (2) Google Sheets Merchant Center add-on: The Merchant Center add-on in Google Sheets can crawl your website and uses structured data to populate and update many attributes in your feed. Learn more about using Google sheets to submit your product data. Prevent temporary disapprovals due to mismatched price and availability information with automatic item updates. This tool allows Merchant Center to update your items based on the structured data on your website instead of using feed-based product data that may be out of date."
So basically, without 'valid' schema mark-up, your Google Shopping (paid results) are much more likely to get rejected at a higher frequency, as Google's organic crawler passes data to Google Shopping through schema (and assumedly, they will only do this if the schema is marked as non-erroneous). Since you don't (well, you haven't said anything about this) use Google Shopping (PLA - Product Listing Ads), this 'primary risk' is mostly mitigated
It's likely that without valid product schema, your products will not appear as 'product' results within Google's normal, organic results. As you know, occasionally product results make it into Google's normal results. I'm not sure if this can be achieved without paying Google for a PLA (Product Listings Ad) for the hypothetical product in question. If webmasters can occasionally achieve proper product listings in Google's SERPs without PLA, e.g like this:
https://d.pr/i/XmXq6b.png (screenshot)
... then be assured that, if your products have schema errors - you're much less likely to get them listed in such a way for for free. In the screenshot I just gave, they are clearly labelled as sponsored (meaning that they were paid for). As such, not sure how much of an issue this would be
For product URLs which rank in Google's SERPs which do not render 'as' products:
https://d.pr/i/aW0sfD.png (screenshot)
... I don't think that such results would be impacted 'as' highly. You'll see that even with the plain-text / link results, sometimes you get schema embedded like those aggregate product review ratings. Obviously if the schema had errors, the richness of the SERP may be impacted (the little stars might disappear or something)
Personally I think that this is going to be a tough one that we're all going to have to come together and solve collectively. Google are basically saying, if a product has no individual review they can read, or no aggregate star rating from a collection of reviews, or it's not on offer (a product must have at least one of these three things) - then to Google it doesn't count as a product any more. That's how it is now, there's no arguing or getting away from it (though personally I think it's pretty steep, they may even back-track on this one at some point due to it being relatively infeasible for most companies to adopt for all their thousands of products)
You could take the line of re-assigning all your products as services, but IMO that's a very bad idea. I think Google will cotton on to such 'clever' tricks pretty quickly and undo them all. A product is a product, a service is a service (everyone knows that)
Plus, if your items are listed as services they're no longer products and may not be eligible for some types of SERP deployment as a result of that
The real question for me is, why is Google doing this?
I think it's because, marketers and SEOs have known for a long time that any type of SERP injection (universal search results, e.g: video results, news results, product results injected into Google's 'normal' results) are more attractive to users and because people 'just trust' Google they get a lot of clicks
As such, PLA (Google Shopping) has been relatively saturated for some time now and maybe Google feel that the quality of their product-based results, has dropped or lowered in some way. It would make sense to pick 2-3 things that really define the contents of a trustworthy site which is being more transparent with its user-base, and then to re-define 'what a product is' based around those things
In this way, Google will be able to reduce the amount of PLA results, reduce the amount of 'noise' they are generating and just keep the extrusions (the nice product boxes in Google's SERPs) for the sites that they feel really deserve them. You might say, well if this could result in their PLA revenue decreasing - why do it? Seems crazy
Not really though, as Google make all their revenue from the ads that they show. If it becomes widely known that Google's product-related search results suck, people will move away from Google (in-fact, they have often quoted Amazon as being their leading competitor, not another search engine directly)
People don't want to search for website links any more. They want to search for 'things'. Bits of info that pop out (like how you can use Google as a calculator or dictionary now, if you type your queries correctly). They want to search for products, items, things that are useful to them
IMO this is just another step towards that goal
Thank you for posting this question as it's helped me get some of my own thoughts down on this matter
I had a similar issue as we offer SaaS solutions with various different prices.
How I resolved this problem was by changing the Entity Type from Product to Service. Then you no longer need Sku or product related parameters.
Can I use a 301 redirect to pass 'back link' juice to a different domain?
Hi, I have a backlink from a high DA/PA Government Website pointing to www.domainA.com which I own and can setup 301 redirects on if necessary. However my www.domainA.com is not used and has no active website (but has hosting available which can 301 redirect). www.domainA.com is also contextually irrelevant to the backlink. I want the Government Website link to go to www.domainB.com - which is both the relevant site and which also should be benefiting from from the seo juice from the backlink. So far I have had no luck to get the Government Website's administrators to change the URL on the link to point to www.domainB.com. Q1: If i use a 301 redirect on www.domainA.com to redirect to www.domainB.com will most of the backlink's SEO juice still be passed on to www.domainB.com? Q2: If the answer to the above is yes - would there be benefit to taking this a step further and redirect www.domainA.com to a deeper directory on www.domianB.com which is even more relevant?
Technical SEO | | DGAU
ie. redirect www.domainA.com to www.domainB.com/categoryB - passing the link juice deeper.0 -
What's the best way to handle product filter URLs?
I've been researching and can't find a clear cut answer. Imagine you have a product category page e.g. domain/jeans You've a lot of options as to how to filter the results domain/jeans?=ladies,skinny,pink,10 or domain/jeans/ladies-skinny-pink-10 or domain/jeans/ladies/skinny?=pink,10 And in this how do you handle titles, breadcrumbs etc. Is the a way you prefer to handle filters and why do you do it that way? I'm trying to make my mind up as some very big names handle this differently e.g. http://www.next.co.uk/shop/gender-women-category-jeans/colour-pink-fit-skinny-size-10r VS https://www.matalan.co.uk/womens/shop-by-category/jeans?utf8=✓&[facet_filter][meta.tertiary_category][Skinny]=on&[facet_filter][variants.meta.size][Size+10]=on&[facet_filter][meta.master_colour][Midwash]=on&[facet_filter][min_current_price][gte]=6.0&[facet_filter][min_current_price][lte]=18.0&per=36&sort=
Technical SEO | | RodneyRiley0 -
Reviews on Product Page or Separated
Good Afternoon We currently have our individual product information pages set-up with a link through to a separate review page optimised for the term "Product A Reviews" I was reading about structured data and if I read correctly, the reviews should sit with the marked up product data so I was wondering whether to merge them back into one page. We have many reviews so the review pages are paginated in blocks of 25 My options are: Leave as it is, product info page and separate review page Merge the review content back in to the main page and have the pagination work on that page Include the first 25 reviews on the product info page then when user clicks through to page 2, 3 etc they're taken to the separated review page. In that way the product page would regularly get new content and we can still have a page specifically targeted for reviews. From the users point of view, they probably aren't even aware they're being taken to a separate reviews page so with that in mind as I'm typing this maybe they should be one page again
Technical SEO | | Ham19790 -
URL Structure On Site - Currently it's domain/product-name NOT domain/category/product name is this bad?
I have a eCommerce site and the site structure is domain/product-name rather than domain/product-category/product-name Do you think this will have a negative impact SEO Wise? I have seen that some of my individual product pages do get better rankings than my categories.
Technical SEO | | the-gate-films0 -
Product Variations (rel=canonical or 301) & Duplicate Product Descriptions
Hi All, Hoping for a bit of advice here please, I’ve been tasked with building an e-commerce store and all is going well so far. We decided to use Wordpress with Woocommerce as our shop plugin. I’ve been testing the CSV import option for uploading all our products and I’m a little concerned on two fronts: - Product Variations Duplicate content within the product descriptions **Product Variations: - ** We are selling furniture that has multiple variations (see list below) and as a result it creates c.50 product variations all with their own URL’s. Facing = Left, Right Leg style = Round, Straight, Queen Ann Leg colour = Black, White, Brown, Wood Matching cushion = Yes, No So my question is should I 301 re-direct the variation URL’s to the main product URL as from a user perspective they aren't used (we don't have images for each variation that would trigger the URL change, simply drop down options for the user to select the variation options) or should I add the rel canonical tag to each variation pointing back to the main product URL. **Duplicate Content: - ** We will be selling similar products e.g. A chair which comes in different fabrics and finishes, but is basically the same product. Most, if not all of the ‘long’ product descriptions are identical with only the ‘short’ product descriptions being unique. The ‘long’ product descriptions contain all the manufacturing information, leg option/colour information, graphics, dimensions, weight etc etc. I’m concerned that by having 300+ products all with identical ‘long’ descriptions its going to be seen negatively by google and effect the sites SEO. My question is will this be viewed as duplicate content? If so, are there any best practices I should be following for handling this, other than writing completely unique descriptions for each product, which would be extremely difficult given its basically the same products re-hashed. Many thanks in advance for any advice.
Technical SEO | | Jon-S0 -
Schema markup for products is missing "price": Is this bad?
Hey guys, So a current client of mine has an e-commerce shop with a few hundred products. They purposely choose to keep the prices off of their website, which is causing errors in Google Webmaster Tools. Basically the error shows: Error: Structured Data > Product (markup: schema.org) Error type: missing price 208 items with error Is this a huge deal? Or are we allowed to have non-numerical prices for schema ie. "call for quote"
Technical SEO | | tbinga1 -
Http to https - is a '302 object moved' redirect losing me link juice?
Hi guys, I'm looking at a new site that's completely under https - when I look at the http variant it redirects to the https site with "302 object moved" within the code. I got this by loading the http and https variants into webmaster tools as separate sites, and then doing a 'fetch as google' across both. There is some traffic coming through the http option, and as people start linking to the new site I'm worried they'll link to the http variant, and the 302 redirect to the https site losing me ranking juice from that link. Is this a correct scenario, and if so, should I prioritise moving the 302 to a 301? Cheers, Jez
Technical SEO | | jez0000 -
How do I handle duplicate content of the same product in Multiple product categories?
I am building a BigCommerce store for selling framed art. Many of the pieces of art will fall in more than one product category. Let's say I have a framed print of a photograph of a western landscape. This piece of art would fit into these categories; "western", "landscape", and "photography". I would have three pages with duplicate content for just this one framed print. Will google give me less page rank due to this? Can all the link juice be given to just one of the three categories by use of rel=canonical? If so, does anyone know how to do this for a bigcommerce site? I would appreciate any feedback. Thanks, Kelly
Technical SEO | | Kelly_S0
