My direct traffic went up and my organic traffic went down. Help!
So on Oct. 21, our direct traffic increased 3x and our organic traffic decreased 3x. And it has been that way ever since. Almost like they flip flopped. Additionally, that was the same day I started retargeting to our site. I have tagged all the links from the ads and they're being counted as google paid clicks in GA. And our accounts are linked. I am just dumbfounded as to how this could happen.
Hey Arnold Ambiel,
cheguei a esse tópico porque estava tendo um problema como o seu. O tráfego orgânico e direto foram revertidos. Vi que você tinha esse problema em 2016 e o meu ocorreu em junho.
Você encontrou alguma solução para esse problema? -
haven't checked yet but did find this article about serp sitelink changes on the exact day i saw traffic drop.
Awh, shucks! Thanks for the kind words!
I look forward to seeing what you find! Let me know if I can help any further!
Regards,
Trenton -
It's contributions like Trenton's above that make me love the Moz community. I will check all that you suggested and report back.
I'm going to chime in here as the conversation has already started from which I want to reference a few items.
While Sean is correct that there is a redirect on page load, - which is weird & not likely optimal - the redirect isn't causing the UTM parameters to be dropped here.
If you check the Network tab of the debug console of Chrome you'll see the two requests for the URI you listed above. If you click the requested file (in the network tab) & navigate to the 'Headers' tab you will see that Query String Parameters are still there & being passed.
Now let's circle back to the original problem & see if we can't get to the bottom of it!I checked out the graph you linked and while it does seem that there's an inverse correlation there, I wouldn't assume too quickly that they switched. I would encourage you to dive into the data a little bit more. Specifically:
I would use Google Search Console's Search Analytics (the actual interface, not the section in Google Analytics) & look to see if the number of clicks around that same time changed much.
If there is a noticeable change, dive into the keywords & Landing Pages that saw the shift
If there is not a noticeable change, we can cross an actual organic change off our list.
I would also look at the change over that period in GA's landing page report. Look to see if there are any pages that saw a gain/loss over the period in question.
If there is, add a secondary dimension of medium & see where the change lies
If not, mark it off
The final door I would check is the changes that were made for remarketing
What if any changes were made within Google Analytics? Specifically the admin portion, while I'd check all changes you may have made here, I'm specifically curious if you may have added the URL Query Parameters as exclusions?
Were any tags, tracking codes, etc added during this time & are the implementations correct?
If you dive into these and summarize your findings here, I'll be more than happy to help you further. Though, I have a hunch that the answer is behind one of these doors.
Good luck!
Trenton -
thought i'd add the GA graph that shows the switch
so would a JS redirect make the session count as direct traffic?
Hey,
It looks like there was a JS redirect in place that redirects users to a fresh page view of the same page - don't know if this might be something having an effect?
I used Ayima Redirect Tool for chrome to find this - see the screenshot attached.
Hope this helps,
Sean
Thanks Sean!
Here is the final URL:
http://www.oneworldplayproject.com/buy-bulk-soccer-balls/?utm_medium=cpc&utm_source=google&utm_campaign=bulk&utm_content=bulk10&utm_term=300Here is the URL in the ad that people could type in. This is a redirect to the www. version:
oneworldplayproject.comAlso, these are only image ads so there is no display URL being shown.
I am also curious why Organic would drop though. But let's play this out first.
Hi there,
Although you say you've tagged your ad traffic correctly, it sounds like your UTM tracking isn't set up correctly - 95% of the time wrong tracking from ads forces a sudden unnatural increase in Direct traffic. The other possibility is that you're sending traffic to a page that's then redirecting to your site which may trim off the UTM tagging and force the traffic as 'Direct'.
Give me an example of one of the URLs you've tagged up and I'll see if anything is going wrong.
All the best,
Sean
direct traffic can be from bookmarks and such, as well as it could depend on proper implementation of ads and retargetting too.
That does seem a bit odd of a coincidence though, I have never dealt with such a switch scenario like that and to that degree, I have only seen more negligible or at least less worrisome amount of such changes in the past which we ended up not spending time to find out what was the underlying sitch with it as it corrected itself as a trend after a short period of time.
Help with force redirect HTTP to HTTPS
Hi, I'm unsure of where I should be putting the following code for one of my Wordpress websites so that they redirect all HTTP requests to HTTPS. RewriteEngine On RewriteCond %{HTTPS} !=on RewriteRule ^(.*)$ https://%{HTTP_HOST}%{REQUEST_URI} [L,R=301] This is my current htaccess file: *missing
Intermediate & Advanced SEO | | Easigrass0 -
Does removal of internal redirects(301) help in SEO
I am planning to completely remove 301 redirects manually by replacing such links with actual live pages/links. So there will be no redirects internally in the website. Will this boost our SEO efforts? Auto redirects will be there for incoming links to non-existing pages. Thanks, Satish
Intermediate & Advanced SEO | | vtmoz0 -
I think Google Analytics is mis-reporting organic landing pages.
I have multiple clients whose Google Analytics accounts are showing me that some of the top performing organic landing pages (in terms of highest conversion rates) look like this: /cart.php /quote /checkout.php /finishorder.php /login.php In some cases, these pages are blocked by Robots.txt. In other cases they are not even indexed at all in Google. These pages are clearly part of the conversion process. A couple of them are links sent out when a cart is abandoned, etc. - is it possible they actually came in organically but then re-entered via one of these links which is what Google is calling the organic landing page? How is it possible that these pages would be the top performing landing pages for organic visitors?
Intermediate & Advanced SEO | | FPD_NYC0 -
How can I stop spam Google Organic traffic?
Hey Moz, I'm a rather experienced SEO who just encountered a problem I have never faced. I am hoping to get some advice or be pointed in the right direction. I just started work for a new client. Really great client and website. Nicer than most design/content. They will need some rel canonical work but that is not the issue here. The traffic looked great at first glance 131k visits in April. Google Analytics Acquisition Overview showed 94% of the traffic as organic. When I dug deeper and looked at the organic source I saw that Google was 99.9% of it. Normal enough. Then I looked at the time on site and my jaw dropped. 118,454 Organic New Users for Google only stayed on the site for 3 seconds. There is no way that the traffic is real. It does not match what Google Webmaster tools, Moz, and Ahrefs are telling me. How do I stop a service that is sending fake organic Google traffic?
Intermediate & Advanced SEO | | placementLabs0 -
Why is my Bing traffic dropping?
In the middle of September we launched a redesigned version of our site. The urls all stayed the same. Since site launch traffic in Google has steadily increased but Bing traffic has dropped by about 50%. Any ideas on what I should look at?
Intermediate & Advanced SEO | | EcommerceSite0 -
Can a large fluctuation of links cause traffic loss?
I've been asked to look at a site that has lost 70/80% if their search traffic. This happened suddenly around the 17th April. Traffic dropped off over a couple of days and then flat-lined over the next couple of weeks. The screenshot attached, shows the impressions/clicks reported in GWT. When I investigated I found: There had been no changes/updates to the site in question There were no messages in GWT indicating a manual penalty The number of pages indexed shows no significant change There are no particular trends in keywords/queries affected (they all were.) I did discover that ahrefs.com showed that a large number of links were reported lost on the 17th April. (17k links from 1 domain). These links reappeared around the 26th/27th April. But traffic shows no sign of any recovery. The links in question were from a single development server (that shouldn't have been indexed in the first place, but that's another matter.) Is it possible that these links were, maybe artificially, boosting the authority of the affected site? Has the sudden fluctuation in such a large number of links caused the site to trip an algorithmic penalty (penguin?) Without going into too much detail as I'm bound by client confidentiality - The affected site is really a large database and the links pointing to it are generated by a half dozen or so article based sister sites based on how the articles are tagged. The links point to dynamically generated content based on the url. The site does provide a useful/valuable service/purpose - it's not trying to "game the system" in order to rank. That doesn't mean to say that it hasn't been performing better in search than it should have been. This means that the affected site has ~900,000 links pointing to is that are the names of different "entities". Any thoughts/insights would be appreciated. I've expresses a pessimistic outlook to the client, but as you can imaging they are confused and concerned. LVSceCN.png
Intermediate & Advanced SEO | | DougRoberts0 -
Crazy long weird URLs... help
I have a HTML website, mysite1.com, and I placed a link on the home page to another one of my sites, mysite2.com Today I checked the links to mysite2.com in Majestic and noticed 24 links coming from the mysite1.com instead of just one link. The URLs from mysite1.com that are showing in Majestic are like this mysite1.com/?epl=4donafvFK3fMXxZXMWQRQLodmPchoXCK5C7-kbBv_agkwlkJrZAoaSDVUlhqFmUqt0f8c2Q6jF6GO6DNMnbidqRsikriF-IEBEt5okmICLEB0FxP36GrsxoPGQ3SGBo1PVR7itDUA4CYmjypn5gi mysite1.com,was inherited from a friend and I believe that it was originally built in Frontpage. Can you tell me how I can get rid of these multiple links as I only want 1 showing from the home page Thanks in advance
Intermediate & Advanced SEO | | JohnPeters0 -
Google penguin penalty(s), please help
Hi MozFans, I have got a question out of the field about www.coloringpagesabc.com.
Intermediate & Advanced SEO | | MaartenvandenBos
Question is why the rankings and traffic are going down down down the last 4 months. Costumer thinks he got hit by google penguin update(s). The site has about 600 page’s/posts al ‘optimized’ for old seo:
- Almost all posts are superb optimized for one keyword combination (like … coloring pages) there is a high keyword density on the keyword titles and descriptions are all the same like: <keyword>and this is the rest of my title, This is my description <keyword>and i like it internal linking is all with a ‘perfect’ keyword anchor text there is a ok backlink profile, not much links to inner pages
- there are social signals the content quality is low The site to me looks like a seo over optimized content farm Competition:
When I look at the competition. The most coloring pages websites don’t offer a lot of content (text) on there page. The offer a small text and the coloring pages (What it is about :-)) How to get the rankings back:
What I was thinking to do. rewrite the content to a smaller text. Low keyword density on the keyword and put the coloring pages up front. rewrite all titles and descriptions to unique titles and descriptions Make some internal links to related posts with a other anchor text. get linkbuilding going on inner pages get more social signals Am I on the right track? I can use some advise what to do, and where to start. Thanks!!</keyword></keyword> Maarten0
