Does removal of internal redirects(301) help in SEO
I am planning to completely remove 301 redirects manually by replacing such links with actual live pages/links. So there will be no redirects internally in the website. Will this boost our SEO efforts?
Auto redirects will be there for incoming links to non-existing pages.
Thanks,
Satish
Hi Dirk,
You got it right. All the pages we redirected were pointing to similar pages once, so probably they should be okay as u said.
Regarding disavow; what are the metrics to decide on a link? Some links might be good looking with decent DA and might be hurting us. What's the best way to findout actual back-links dropping us down. Disavow comes with risk as there are chances we may reject good links, so it's better to make sure about the links.
Thanks,
Satish
Hi Satish,
Not sure if I fully understand your answer.
Google will consider a redirect as a soft 404 if you redirect pages to non-related pages. Example: if you redirect a page about "shirts" to a page about "pants" or if you redirect this page to your homepage. If the pages are similar (example "green shirts" to "shirts") it's not considered as a soft 404. I understand that you are redirecting to similar pages - so that should be ok.
If you have pages with low quality incoming links (or a mix of high/low quality links) you can still redirect them - but in case of low quality links it's probably a good idea to disavow them (using the search console) - check https://support.google.com/webmasters/answer/2648487?hl=en
Hope this helps,
Dirk
Hi Dirk,
Thanks for the response with a detailed answer. Very informative. We have decent number of redirects from homepage and top tier pages too. So I decided for this activity.
Regarding "auto redirects", we have redirected tens of links these days in the process of link reclamation to increase the back-links and pagerank/da. But we have significantly dropped post such redirects even though we have cross examined to make sure the incoming links are relevant to current pages we are linking. However, those external links were pointing to our pages in past. But as we deleted many pages in process of website redesign and content update, we replaced such pages. Why actually they consider such as soft 404 even we redirect non-existing pages to almost same pages with high relevancy? I think some of the links we reclaimed are kind of spammy and pushed us down. What's your idea on this. Thank you.
-Satish
The crawl by Googlebot will be more efficient if it can go directly to the destination page rather than having to go trough a redirection.
There is some discussion whether 3xx redirections do have an impact on page rank / page authority - Google official point of view is that it doesn't.
Redirects do however indicate have an impact on speed (check here: https://developers.google.com/speed/docs/insights/mobile: "we strongly encourage webmasters to minimize the number, and ideally eliminate redirects entirely" - context is mobile but is applicable on all redirects) - but again for most sites this won't make a huge difference on total load time.
I doubt that simply cleaning your site and removing the 301 will give a boost to your search traffic, but it just something you need to from time to time (idem for internal 4xx errors) to improve the general health of your site.
Dirk
PS I am a bit puzzled about the remark "auto redirects" - you must make sure if you redirect that you redirect to a page which is similar to the page that has disappeared. Google considers most other type of redirects as "soft 404". If the page never existed - like domain.com/kklfjklgjkldfjg - it should return 404 and not be redirect.
I need help in doing Local SEO
Hey guys I hope everyone is doing well. I am new to SEO world and I want to do local SEO for one of my clients. The issue is I do not know how to do Local SEO at all or where to even start. I would appreciate it if anyone could help me or give me an article or a course to learn how to do it. Main question The thing that I want to do is that, I want my website to show up in top 3 google map results for different locations(which there is one actual location). For example I want to show up for
Intermediate & Advanced SEO | | seopack.org.ofici3
online clothing store in new york
online clothing store in los angeles or... Let's assume that we can ship our product to every other cities. So I hope I could deliver what I mean. I'd appreciate it if you could answer me with practical solutions.0 -
Using a Reverse Proxy and 301 redirect to appear Sub Domain as Sub Directory - what are the SEO Risks?
We’re in process to move WordPress blog URLs from subdomains to sub-directory. We aren’t moving blog physically, but using reverse proxy and 301 redirection to do this. Blog subdomain URL is https://blog.example.com/ and destination sub-directory URL is https://www.example.com/blog/ Our main website is e-commerce marketplace which is YMYL site. This is on Windows server. Due to technical reasons, we can’t physically move our WordPress blog to the main website. Following is our Technical Setup Setup a reverse proxy at https://www.example.com/blog/ pointing to https://blog.example.com/ Use a 301 redirection from https://blog.example.com/ to https://www.example.com/blog/ with an exception if a traffic is coming from main WWW domain then it won’t redirect. Thus, we can eliminate infinite loop. Change all absolute URLs to relative URLs on blog Change the sitemap URL from https://blog.example.com/sitemap.xml to https://www.example.com/blog/sitemap.xml and update all URLs mentioned within the sitemap. SEO Risk Evaluation We have individual GA Tracking ID and individual Google Search Console Properties for main website and blog. We will not merge them. Keep them separate as they are. Keeping this in mind, I am evaluating SEO Risks factors Right now when we receive traffic from main website to blog (or vice versa) then it is considered as referral traffic and new cookies are set for Google Analytics. What’s going to happen when its on the same domain? Which type of settings change should I do in Blog’s Google Search Console? (A). Do I need to request “Change of Address” in the Blog’s search console property? (B). Should I re-submit the sitemap? Do I need to re-submit the blog sitemap from the https://www.example.com/ Google Search Console Property? Main website is e-commerce marketplace which is YMYL website, and blog is all about content. So does that impact SEO? Will this dilute SEO link juice or impact on the main website ranking because following are the key SEO Metrices. (A). Main website’s Avg Session Duration is about 10 minutes and bounce rate is around 30% (B). Blog’s Avg Session Duration is 33 seconds and bounce rate is over 92%
Intermediate & Advanced SEO | | joshibhargav_200 -
302 > 302 > 301 Redirect Chain Issue & Advice
Hi everyone, I recently relaunched our website and everything went well. However, while checking site health, I found a new redirect chain issue (302 > 302 > 301 > 200) when the user requests the HTTP and non-www version of our URL. Here's what's happening: • 302 #1 -- http://domain.com/example/ 302 redirects to http://domain.com/PnVKV/example/ (the 5 characters in the appended "subfolder" are dynamic and change each time)
Intermediate & Advanced SEO | | Andrew_In_Search_of_Answers
• 302 #2 -- http://domain.com/PnVKV/example/ 302 redirects BACK to http://domain.com/example/
• 301 #1 -- http://domain.com/example/ 301 redirects to https://www.domain.com/example/ (as it should have done originally)
• 200 -- https://www.domain.com/example/ resolves properly We're hosted on AWS, and one of my cloud architects investigated and reported GoDaddy was causing the two 302s. That's backed up online by posts like https://stackoverflow.com/questions/46307518/random-5-alpha-character-path-appended-to-requests and https://www.godaddy.com/community/Managing-Domains/My-domain-name-not-resolving-correctly-6-random-characters-are/td-p/60782. I reached out to GoDaddy today, expecting them to say it wasn't a problem on their end, but they actually confirmed this was a known bug (as of September 2017) but there is no timeline for a fix. I asked the first rep I spoke with on the phone to send a summary, and here's what he provided in his own words: From the information gathered on my end and I was able to get from our advanced tech support team, the redirect issue is in a bug report and many examples have been logged with the help of customers, but no log will be made in this case due to the destination URL being met. Most issues being logged are site not resolving properly or resolving errors. I realize the redirect can cause SEO issues with the additional redirects occurring. Also no ETA has been logged for the issue being reported. I do feel for you since I now understand more the SEO issues it can cause. I myself will keep an eye out for the bug report and see if any progress is being made any info outside of this I will email you directly. Thanks. Issue being Experienced: Domains that are set to Go Daddy forwarding IPs may sometimes resolve to a url that has extra characters appended to the end of them. Example: domain1.com forwards to http://www.domain2.com/TLYEZ. However it should just forward to http://www.domain2.com. I think this answers what some Moz users may have been experiencing sporadically, especially this previous thread: https://cloudz.click/community/q/forwarded-vanity-domains-suddenly-resolving-to-404-with-appended-url-s-ending-in-random-5-characters. My question: Given everything stated above and what we know about the impact of redirect chains on SEO, how severe should I rate this? I told my Director that I would recommend we move away from GoDaddy (something I don't want to do, but feel we _**have **_to do), but she viewed it as just another technical SEO issue and one that didn't necessarily need to be prioritized over others related to the relaunch. How would you respond in my shoes? On a scale of 1 to 10 (10 being the biggest), how big of a technical SEO is this? Would you make it a priority? At the very least, I thought the Moz community would benefit from the GoDaddy confirmation of this issue and knowing about the lack of an ETA on a fix. Thanks!0 -
Setting up 301 Redirects after acquisition?
Hello! The company that I work for has recently acquired two other companies. I was wondering what the best strategy would be as it relates to redirects / authority. Please help! Thanks
Intermediate & Advanced SEO | | Colin.Accela0 -
Any SEO Penalties from Removing RSS Feed?
Hi, I have a site that has a Feedburner feed that has been in place for 5+ years. I am considering getting rid of the feed or starting a new one to combat content scraping. Google continues to rank thieves' sites ahead of mine. Google and Bing have no issue and always get it right. I use Wordpress and have the plugin PubSubHubb, but that is no guarantee. Nonetheless, there is no monetary value of my subscribers whereas the content not being accredited to me takes money out of my pocket as my model is advertising. Is there any SEO issue if I do any of the following: Delete the feed and not have one? Change the feed address and drop all subscribers? Attachments: DMCA Dashboard; example of being outranked by scrapers. My site: www.furniturefashion.com Thanks for your time and hopefully I did not vent too much. OWmou6k f6W3xkq.png
Intermediate & Advanced SEO | | will21121 -
Is it ok to use both 301 redirect and rel="canonical' at the same time?
Hi everyone, I'm sorry if this has been asked before. I just wasn't able to find a response in previous questions. To fix the problems in our website regarding duplication I have the possibility to set up 301's and, at the same time, modify our CMS so that it automatically sets a rel="canonical" tag for every page that is generated. Would it be a problem to have both methods set up? Is it a problem to have a on a page that is redirecting to another one? Is it advisable to have a rel="canonical" tag on every single page? Thanks for reading!
Intermediate & Advanced SEO | | SDLOnlineChannel0 -
301 Redirect - What happens to backlinks
Hello... One of my sites is losing rankings in G. I received the webmaster notification of unnatural links... My question is, should i do a 301 redirect of every page on my site to a new domain? If so, do the backlinks (which i believe are causing my rankings to drop) carry over? How about the good backlinks? Also, what would happen to the rankings i currently have on page 1? Thanks
Intermediate & Advanced SEO | | Prime850 -
Redirect a subdomain to a subdirectory for SEO purposes.
Hi, I have a site on wordpress and I want to add eCommerce to it. We want to go with Shopify but Shopify only allows to host their platform on a subdomain. I like to have it on a subdorectory, so my question is: Would it make sense to redirect the whole subdomain to a subdirectory (move everything from shop.domain.com to domain.com/shop) for SEO purposes? Would Google see these pages as if they were part of the main domain? Thanks! Julien
Intermediate & Advanced SEO | | julienraby0
