How to Fix 404 Errors
Hey Moz'ers - I just added a new site to my Moz Pro account and when I got the crawl report back there was a ton of 404 errors (see attached). I realize the best way to fix these is to manually go through every single error and see what the issue is... I just don't have time right now, and I don't have a team member that can jump on this either, but realize this will be a huge boost to this client if/when I get these resolved... So my question is:
Is there a quicker way to get these resolved? Is there an outsourcing company that can fix my clients errors correctly? Thanks for the help in advance:)
Thanks Joe - I'll check the settings right now for NextGen and see what I find. I appreciate it.
Travis
Good morning Travis,
I put your site in the system last night and have all the errors to see now. I do see what is going wrong ... but not exactly sure why.
I pulled up a few of the error codes: http://www.felco-ind.com/products/roller-attachment/nggallery/page/1?page_id=27 Example: if you remove nggallery/page/1?page_id=27 and use this link http://www.felco-ind.com/products/roller-attachment/ you do not get an error.
I did the same process for a few different 404 errors you have.
So the question is why are the urls adding the N Gallery code and the extra page id. I am thinking there could be a setting in next gen gallery you can fix. I would check all the plugin settings in the backend. You should also check Next Gen Gallery support forums as well to get the quickest fix from a Next gen gallery ninja over there that knows the plugin inside out. That way you have an idea if it is the plugin itself or a conflict with another issue or plugin on your website.
I also noticed these links in your source code that I would change to absolute links instead
About | FAQ's You should change
all of these links to the full url Page title HereSorry i could not figure out an exact answer of how to fix it for you, but hope I pointed you in the right direction to get it figured out.
Joe
Michael - thanks for the reply. I'd send you a screenshot of what I have for permalinks but now I can't even use the backend without getting a fatal error. Something went haywire in this last update we did it seems...?
Once we get this issue fixed, I'll send over a screen grab of our permalinks settings, and yes will replace our current SEO plugin with Yoast. Much appreciated.
- Travis
Hey Travis, 404 status codes pages are soft errors but causes problems if you have large number of 404 pages. I would suggest to use screaming frog to list up all your 404 pages and redirect all 404 pages to newly create corresponding pages. This is the best solution ever seen and could boost your trust rank, site performance and indexing.
moreover, If error is associated with WP plugin, then better to deactivate it or use SEO Yoast, as said by Michael Edwards.
I am agree with you.
Follow this instruction Travis Wiley. I think this instruction help you.
I have run the site through ScreamingFrog. You have masses and masses of 301 redirects going on which you need to resolve. It looks like you could have some permalinks issue going on. What do have set in Settings >> Permalinks? I'd also look at installing Yoast Wordpress SEO as I recall there are options in there to handle permalinks as well.
Joseph,
No need to keep private I need all the help I can get:) Here's the site : www.felco-ind.com.
It appears that most of the 404 errors are coming from a plugin that is used on the site called NGGallery... Not sure what the deal is with it, but looks like it is creating a handful of URL's that do not exist? Any ideas would be much appreciated.
Travis
Hey Travis,
Can you send me the website url, or a few of the 404 error urls and links and I'll have a closer look for you.
If it's a website you want to keep private you can send them in a private message as well.
Joe
Unsolved Link Tracking List Error
"I have been maintaining 5 directories of backlinks in the 'Link Tracking List' section for several months. However, I am unable to locate any of these links at this time. Additionally, the link from my MOZ profile is currently broken and redirects to an error page, no to Elche Se Mueve. Given the premium pricing of MOZ's services, these persistent errors are unacceptable."
Moz Pro | | Alberto D.0 -
How to overcome Connection Timeout Status Error?
My website contains 110+ pages in which 70 are CONNECTION TIMEOUT while checking in Screaming Frog. Can someone help me in getting this solved? My website Home Page Sanctum Consulting.
Moz Pro | | Manifeat90 -
Ive been using moz for just a minute now , i used it to check my website and find quite a number of errors , unfortunately i use a wordpress website and even with the tips , is till dont know how to fix the issues.
ive seen quite a number of errors on my website hipmack.co a wordpress website and i dont know how to begin clearing the index errors or any others for that matter , can you help me please? ghg-1.jpg
Moz Pro | | Dogara0 -
What's the best way to eliminate "429 : Received HTTP status 429" errors?
My company website is built on WordPress. It receives very few crawl errors, but it do regularly receive a few (typically 1-2 per crawl) "429 : Received HTTP status 429" errors through Moz. Based on my research, my understand is that my server is essentially telling Moz to cool it with the requests. That means it could be doing the same for search engines' bots and even visitors, right? This creates two questions for me, which I would greatly appreciate your help with: Are "429 : Received HTTP status 429" errors harmful for my SEO? I imagine the answer is "yes" because Moz flags them as high priority issues in my crawl report. What can I do to eliminate "429 : Received HTTP status 429" errors? Any insight you can offer is greatly appreciated! Thanks,
Moz Pro | | ryanjcormier
Ryan0 -
404 even after Successful 301 Redirection
Hi, I've got quite few 404 error links on my site and I manually redirected all of them one by one with 301. They are redirecting successfully. But when I check my MOZ analysis, it still shows me as 404 error. I've done this about 4 days ago and MOZ crawled to my site couple times after that if it's not everyday. Do you know what the issue could be? And how can I fix it? PS: I've used Wordpress Redirection tool for it first and redirection did not work. Then I had to install the Simple 301 Redirects plugin to get it done.
Moz Pro | | nunobaronio0 -
How to resolve Duplicate Content crawl errors for Magento Login Page
I am using the Magento shopping cart, and 99% of my duplicate content errors come from the login page. The URL looks like: http://www.site.com/customer/account/login/referer/aHR0cDovL3d3dy5tbW1zcGVjaW9zYS5jb20vcmV2aWV3L3Byb2R1Y3QvbGlzdC9pZC8xOTYvY2F0ZWdvcnkvNC8jcmV2aWV3LWZvcm0%2C/ Or, the same url but with the long string different from the one above. This link is available at the top of every page in my site, but I have made sure to add "rel=nofollow" as an attribute to the link in every case (it is done easily by modifying the header links template). Is there something else I should be doing? Do I need to try to add canonical to the login page? If so, does anyone know how to do it using XML?
Moz Pro | | kdl01 -
How to fix problem with google analytics connection?
In the Organic Traffic Data Report I receive always the same message: "It appears there's a problem with our connection to your Google Analytics account. Please go to your Settings page to update your connection." In the settings I've choosen the correct Google Analytics Account with the correct profile. Thanks for any hints. Is it because using www. in the GA Profil but *.xyz.ch without www in the campaigns settings?
Moz Pro | | FlorianMuff760 -
Error 403
I'm getting this message "We were unable to grade that page. We received a response code of 403. URL content not parseable" when using the On-Page Report Card. Does anyone know how to go about fixing this? I feel like I've tried everything.
Moz Pro | | Sean_McDonnell0
