How to fix problem with google analytics connection?
In the Organic Traffic Data Report I receive always the same message: "It appears there's a problem with our connection to your Google Analytics account. Please go to your Settings page to update your connection." In the settings I've choosen the correct Google Analytics Account with the correct profile. Thanks for any hints.
Is it because using www. in the GA Profil but *.xyz.ch without www in the campaigns settings?
I can't link my account from Moz to google analytics and I got the error message. https://www.seovision.se/
ERROR Massage
Sign in with Google has been temporarily disabled for this app
Google has not yet verified this Google Sign-In app
Hi Aaron
Thanks a lot for the help. I've also created a www. Campaign an there it worked out without any problem. In my case the solution also was to disconnect and reconnect to the GA Account.
Well finally, works great!
Great, thanks for the confirmation Aaron.
One of the accounts that I re-created actually came up with this issue and sure enough when I disconnected and reconnected it worked nicely.
I'm sure all the 'losing all your data' talk when disconnecting your account would scare the hell out of some people! Good to know that it will be re-populated in time anyway.
@sk That is definitely one of the solutions! There are a few reasons this might be happening. Usually, if you have the correct account and profile already selected, the only fix is to disconnect the GA account and then reconnect it. While it does say that you'll lose some data by doing this, the data loss is temporary because we'll repopulate it all when you reconnect from historical data in GA the entire re-population could take a few days though since we won't have it cached anymore). Also, make sure that you have selected the correct account and profile in GA.
You can verify this by going to your GA account, going to the profile that corresponds with your campaign, finding the number of that profile, and checking it against the profile number embedded in your homepage you're tracking. If they match up, you're gold! GA accounts and profiles can sometimes get mixed up so if you have more than one of either, try changing it to another profile. It might work that way.
You may have to wait for traffic data to repopulate but the current data in the Traffic Data tab will repopulate pretty quickly (immediately most of the time). Hope that helps! If you're still not able to get it to work, send us an email at [email protected] with your PRO email address, the campaign that's having issues, and examples/screenshots of your GA account if you can! We'll try to get you running ASAP.
Yep, your suspicions were right.
I just created another campaign based on the same settings as my *.domain campaign except this time with www.domain instead and the traffic data has shown up immediately.
Perhaps during the campaign creation there could be a note to explain that if the GA profile is a subdomain i.e. prefixed with www then the campaign must be set up to match. SEOmoz?
I'll have to go back and recreate my campaigns which isn't too bad for me but I can imagine if you had been running SEOmoz for a while and only just connected your analytics profile you would be going postal!
I'm having the same issue and also thinking the *.domain in campaign while www.domain issue might be the key.
The closest helpful thing I found is here http://seomoz.zendesk.com/entries/20031127-lesson-3-connect-google-analytics but all it says regarding troubleshooting is: "Sometimes you can’t connect a Google Analytics account if our servers time out while communicating with Google. If this happens, it’s best to try again later."
If I figure it out I'll let you know!
Ive been using moz for just a minute now , i used it to check my website and find quite a number of errors , unfortunately i use a wordpress website and even with the tips , is till dont know how to fix the issues.
ive seen quite a number of errors on my website hipmack.co a wordpress website and i dont know how to begin clearing the index errors or any others for that matter , can you help me please? ghg-1.jpg
Moz Pro | | Dogara0 -
Links to Your Site: No Data Available in Google Search Console
The site I am working on did not have their site submitted to Google Search Console (formerly Google Webmaster Tools). I submitted the site and a sitemap that auto updates. Google is crawling the site daily (about 30 pages a day). Under Search Traffic > Links to Your Site it shows no data is availible. I thought it was because it was a newly submitted site, but it has been two months now. Moz seems to have the same issue. Moz does show inbound links, but their are some that we think should really help us that are not shown. For instance, the Dallas Morning News wrote this article. They have a high DA and PA. Also, iliveindallas.com has an article about us that is still on the front page. That was a few weeks ago but also does not show up on Moz or Google SC. We are trying to be selective about the links we are getting. That they are follow links from reputable sites. Worried that both Google and Moz are not showing them.
Moz Pro | | TapGoods1 -
GOOGLE ANALYTIC SKEWED DATA BECAUSE OF GHOST REFERRAL SPAM ND CRAWL BOTS
Hi Guys, We are having some major problems with our Google Analytics and MOz account. Due to the large number of ghost/referral spam and crawler bots we have added some heavy filtering to GA. This seems to be working protecting the data from all these problems but also filtering out much needed data that is not coming through. In example, we used to get a hundred visitors a day at the least and now we are down to under ten. ANYBODY PLEASE HELP. HAVE READ THROUGH MANY ARTICLES WITH NO FIND TO PERMANENT SOLID SOLUTION (even willing to go with paid service instead of GA) Thank You so Much, S.M.
Moz Pro | | KristyKK0 -
GWMT / Search Analytics VS OpenSiteExplorer
Just had the experience of using OSE data to show what we call "linkrot" to a client -- only to find that GWMT / Search Analytics shows no such thing. Fortunately the client is an old friend and no face was lost, but it was dicey there for a bit as I have come to rely on and reference OSE again and again and again, OSE showed Domain Authority dropping by about 1/3 in the last 12 months, presumably due to old links getting broken, linking sites changing their architecture etc. And of course, ranking is tanking, as you would expect. But Google shows many more (and much more spammy looking!) backlinks. Has anyone had any experience benchmarking the 2 data sets of backlinks against each other? Dr Pete?
Moz Pro | | seo_plus
Does one update more frequently than another? Do you trust one more than another?? If so, why?? Thanks!0 -
How to Fix 404 Errors
Hey Moz'ers - I just added a new site to my Moz Pro account and when I got the crawl report back there was a ton of 404 errors (see attached). I realize the best way to fix these is to manually go through every single error and see what the issue is... I just don't have time right now, and I don't have a team member that can jump on this either, but realize this will be a huge boost to this client if/when I get these resolved... So my question is: Is there a quicker way to get these resolved? Is there an outsourcing company that can fix my clients errors correctly? Thanks for the help in advance:) wBhzEeV
Moz Pro | | 2Spurs0 -
Why is MOZ and Google search Volume so different?
A search term in MOZ shows the monthly search volume to be 49K. In Google, the same term shows the search volume at only 1300 monthly searches. Which do I trust? Thanks, Don
Moz Pro | | rcman0 -
Problem to log into moz
Every time the moz logs me out from the account and then I can not log in. It shows on the left side my name like I am logged in and then when I want go to community suddenly I am not logged in. It offen shows 502 error. It was first doing on firefox, then I manage to log in chrome and now I had to log in private browsing.
Moz Pro | | Rebeca12 -
Mozscape API Problem With Credentials
Yello everyone 🙂 Yesterday I generated Access ID and Secret Key to try the API, but it didn't work. It's said that it might need 5 minutes, so I gave it something like 8 hours but it still didn't work afterwards. I used the PHP sample and I checked it with the Sample Expires value and it produces the same Signature parameter as in the Sample Valid API Signature, so the PHP code sample and the Sample Valid API Signature are in sync. In case you wonder - yes I changed the PHP sample by adding the valid strings for $accessID and $secretKey - I'm a long time programmer and I know what I'm doing with it. I tried also the example URL from Sample Valid API Signature couple of times, refreshing each time to get new Expire parameter, but it's not working too. Both the PHP sample and the Sample Valid API Signature are giving me this: **{ "status" : "401", "error_message" : "Your authentication failed. Check your authentication details and try again. For more information on signed authentication, see: http://apiwiki.seomoz.org/w/page/29574176/SignedAuthentication" }** I am new here and if there is another place to look for support please just point it out and excuse me for wasting your time - I just couldn't see it and I really tried. Thank you for your time to read this! Calvin Your Access ID:
Moz Pro | | Calvin50
