How can I block incoming links from a bad web site ?
Hello all,
We got a new client recently who had a warning from Google Webmasters tools for manual soft penalty. I did a lot of search and I found out one particular site that sounds roughly 100k links to one page and has been potentialy a high risk site.
I wish to block those links from coming in to my site but their webmaster is nowhere to be seen and I do not want to use the disavow tool.
Is there a way I can use code to our htaccess file or any other method?
Would appreciate anyone's immediate response.
Kind Regards
Hi Yiannis,
As far as I'm aware, there isn't really a way to "block" a link. The link is seen on the other site. Returning a 404 for the page being linked to doesn't change the fact that there are a 100K links from one site pointing at your site. The only options I'm aware of are to 1.) contact the owner of the website with the links and ask them to remove the links and 2.) if that doesn't work disavow the links.
I understand your hesitancy to use the disavow tool, but quite frankly, this is exactly what it is intended for.
If you feel comfortably with the links being there and think Google has already dealt with them, then do nothing, but if you want to do something about the links, you either have to get them removed or disavow them.
BTW - My understanding of the partial manual actions is that often times Google not only deals with the suspicious links (devaluing them), but they also penalize the pages/keywords they think you were attempting to manipulate. So, just because it was a partial action and not a full site action doesn't mean it's not effecting some of your rankings. It's just not going to affect all your rankings for all your pages.
Kurt Steinbrueck
OurChurch.Com -
Hi eyepaq and thanks for your reply, much appreciated
The reason I do not want to use the disavow tool is because
- Google sent on the message that "took targeted action on the unnatural links instead of on the site’s ranking as a whole", meaning they took care of the problem 2) Ranking and traffic looking solid
- I have seen a lot of cases where people used it and lost rankings (some never recovered).
My thoughts were to block the spammy links and monitor if the traffic will be affected (which I doubt as it seems most of it is for branded searches). If then I face de-index, drops then use the disavow/reconsideration request.
What do you think?
If you are talking about one or only a few sites then it's easy.
Just build a disavow file as there is no down side to that . The disavow with domain:domainname.com (not individual pages) and upload it via Web master Tools. After sumbiting the file - send a reconsideration request explaining the situation and mentioning the disavow file. You should be safe after that.
Alternatively - but to be honest I don't see the reason why not going with the first option - is to return a 404 if the referral is that domain.
Hope it helps.
Our clients Magento 2 site has lots of obsolete categories. Advice on SEO best practice for setting server level redirects so I can delete them?
Our client's Magento website has been running for at least a decade, so has a lot of old legacy categories for Brands they no longer carry. We're looking to trim down the amount of unnecessary URL Redirects in Magento, so my question is: Is there a way that is SEO efficient to setup permanent redirects at a server level (nginx) that Google will crawl to allow us at some point to delete the categories and Magento URL Redirects? If this is a good practice can you at some point then delete the server redirects as google has marked them as permanent?
Technical SEO | | Breemcc0 -
Tools/Software that can crawl all image URLs in a site
Excluding Screaming Frog, what other tools/software to use in order to crawl all image URLs in a site? Because in Screaming Frog, they don't crawl image URLs which are not under the site domain. Example of an image URL outside the client site: http://cdn.shopify.com/images/this-is-just-a-sample.png If the client is: http://www.example.com, Screaming Frog only crawls images under it like, http://www.example.com/images/this-is-just-a-sample.png
Technical SEO | | jayoliverwright0 -
URL Structure On Site - Currently it's domain/product-name NOT domain/category/product name is this bad?
I have a eCommerce site and the site structure is domain/product-name rather than domain/product-category/product-name Do you think this will have a negative impact SEO Wise? I have seen that some of my individual product pages do get better rankings than my categories.
Technical SEO | | the-gate-films0 -
Are links in menus to external sites bad for SEO?
We're building a blog on a subdomain of the main site. The main site is on Shopify and the blog will be on wordpress. I'd like to keep the user experience as simple as possible so I'd like to make the blog look exactly like the main Shopify site. This means having a menu in the blog that duplicates the Shopify menu. So is it bad for SEO to have someone click on the 'about us' button in the blog subdomain (blog.mainsite.com) which takes you to the 'about us page' on the main shopify website (mainsite.com)?
Technical SEO | | acs1110 -
Value of an embedded site vs. a direct link?
We have a new site that is a great resource for a serious subject (suicide). I have been getting many requests from various communities and clinics about help on embedding our site in their websites. Although I certainly don't want to keep this resource from being used as much as possible, I am curious about the SEO costs/benefit to having someone embed our site on their own website rather than provide a link to our website directly from theirs.
Technical SEO | | ron_adease1 -
Can dynamically translated pages hurt a site?
Hi all...looking for some insight pls...i have a site we have worked very hard on to get ranked well and it is doing well in search. The site has about 1000 pages and climbing and has about 50 of those pages in translated pages and are static pages with unique urls. I have had no problems here with duplicate content and that sort of thing and all pages were manually translated so no translation issues. We have been looking at software that can dynamically translate the complete site into a handfull of languages...lets say about 5. My problem here is these pages get produced dynamically and i have concerns that google will take issue with this aswell as the huge sudden influx of new urls....as now we could be looking at and increase of 5000 new urls. (which usually triggers an alarm) My feeling is that it could be risking the stability of the site that we have worked so hard for and maybe just stick with the already translated static pages. I am sure the process could be fine but fear a manual inspection and a slap on the wrist for having dynamically created content?? and also just risk a review trigger period. These days it is hard to know what could get you in "trouble" and my gut says keep it simple and as is and dont shake it up?? Am i being overly concerned? Would love to here from others who have tried similar changes and also those who have not due to similar "fear" thanks
Technical SEO | | nomad-2023230 -
What is the value of english links with foreign language anchor text for a foreign site?
I have a site in Spanish that is hosted in Spain with a .es TLD. I already have many Spanish-language links from websites in Spain, but I obviously want more and I'm finding I might need to look beyond typical Spanish sites. In talking to some of my link builders who work on my English/American sites, they are recommending that I build links on the normal article sites, blogs and web 2.0 sites that I normally build links on but that I make all the content English and insert the anchor text in Spanish. For example, if my site were about "weightloss", my keyword would be "perder peso" (in spanish). They are recommending that I have articles, reviews, etc written about weightloss in English with the anchor text "perder peso" worked into the English article. Most of the sites are English sites that are hosted in the US (article sites, web 2.0 properties, etc). My question is what is the value of these links? Does anybody have any experience with this?
Technical SEO | | jargomang0 -
Google.ca is showing our US site instead of our Canada Site
When our Canadian users who search on google.ca for our brand (e.g. Travelocity, Travelocity hotels, etc.), the first few results our from our US site (travelocity.com) rather than our Canadian site (travelocity.ca). In Google Webmaster Tools, we've adjusted the geotargeting settings to focus on the appropriate locale, but the wrong country TLD is still coming up at the top via google.ca. What's the best way to ensure our Canadian site comes up instead of the US site on google.ca? Thanks, Tory Smith
Technical SEO | | travelocitysearch
Travelocity0
