How much will changing IP addresses impact SEO?
So my company is upgrading its Internet bandwidth. However, apparently the vendor has said that part of the upgrade will involve changing our IP address. I've found two links that indicate some care needs to be taken to make sure our SEO isn't harmed:
http://followmattcutts.com/2011/07/21/protect-your-seo-when-changing-ip-address-and-server/
http://www.v7n.com/forums/google-forum/275513-changing-ip-affect-seo.html
Assuming we don't use an IP address that has been blacklisted by Google for spamming or other black hat tactics, how problematic is it?
(Note: The site hasn't really been aggressively optimized yet - I started with the company less than two weeks ago, and just barely got FTP and CMS access yesterday - so honestly I'm not too worried about really messing up the site's optimization, since there isn't a lot to really break.)
TTL is Time To Live (set in seconds), and is the interval that your computer will refresh its DNS information.
Usually it's set for 12 or 24 hours. So the day before an IP change, set your TTL to 5 minutes. That way, when you do change your IP, it should only take 5 minutes for the DNS change to propagate. Once it propagates, change it back to its original value.
I am also looking at moving server - How do we check if the ip/dns server we're moving to was blacklisted in the past or not?
TTL = ??? (Sorry so ignorant...)
There's little or no evidence that changing the IP by itself will effect on your rankings or traffic, unless you move to a really slow server or a blacklisted neighborhood - but it doesn't seem like something you need to worry about.
Hopefully the speed improvements will be a big boost to your visitors, which may indirectly effect your SEO in a positive way!
Will not matter much especially if it is only done only once in awhile.
Except for geolocation purposes, your IP has no real effect on your SEO. The only thing I would suggest is making your TTL on your DNS records very low about a day before you move so when you do move you minimize the chance that you're hitting the old IP.
I was looking at this 2 URL'S you post here and did some research on my own few months ago and i don't really think that will make any different , you need to make sure this dns server you put it on not flagged by Google.
not much but hope that help you
Mike
How does changing sitemaps affect SEO
Hi all, I have a question regarding changing the size of my sitemaps. Currently I generate sitemaps in batches of 50k. A situation has come up where I need to change that size to 15k in order to be crawled by one of our licensed services. I haven't been able to find any documentation on whether or not changing the size of my sitemaps(but not the pages included in them) will affect my rankings negatively or my SEO efforts in general. If anyone has any insights or has experienced this with their site please let me know!
Technical SEO | | Jason-Reid0 -
How do I "undo" or remove a Google Search Console change of address?
I have a client that set a change of address in Google Search Console where they informed Google that their preferred domain was a subdomain, and now they want Google to also consider their base domain (without the change of address). How do I get the change of address in Google search console removed?
Technical SEO | | KatherineWatierOng0 -
How much difference does .co.uk vs .com for SEO make?
My Website has a .com domain. However I have noticed that for local businesses all of them have a .co.uk (UK business) TLD (check plumbers southampton for example). I have also noticed that on checking my serp rankings, I'm on page 1 if searched on Google.com but page 2 if searched on google.co.uk. Now being UK based I would assume most of my customers will be redirected to google.co.uk so I'm wondering how much of an impact this actually makes? Would it be worth purchasing .co.uk domain and transferring my website to that? Or run them both at the same time and set up 301 direct on my .com to .co.uk? Thanks
Technical SEO | | Marvellous0 -
Loading images below the fold? Impact on SEO
I got this from my developers. Does anyone know if this will be a SEO issue? We hope to lazy-load images below the fold where possible, to increase render speed - are you aware of any potential issues with this approach from an SEO point of view?
Technical SEO | | KatherineWatierOng1 -
Will a CSS Overflow Scroll for content affect SEO rankings?
If I use a CSS overflow scroll for copy, will my SEO rankings be affected? Will Google still be able to index my copy accurately and will keywords used in the copy that are covered by the scroll be recognized by Google?
Technical SEO | | moliver10220 -
How to change noindex to index?
Hey, I've recently upgraded to a pro SEOmoz account and have realised i have 14574 issues to do with 'blocked by meta-robot' and that 'This page is being kept out of the search engine indexes by the meta tag , which may have a value of "noindex", keeping this page out of the index.' How can i change this so my pages get indexed? I read somewhere that i need to change my privacy settings but that thread was 3 years old and now the WP Dashboard has updated.. Please let me know Many thanks, Jamie P.s Im using WordPress 3.5 And i have the XML sitemap plugin And i have no idea where to look for this robots.txt file..
Technical SEO | | markgreggs0 -
How do I check if my IP is blocked?
We changed servers and where our sites once ranked very highly (page 1 for all sites), they now are nowhere to be seen. Someone suggested that our IP might be blocked. Someone else suggested SEOMoz was the place to go to get it checked. Any help would be GREATLY appreciated. With thanks. Bryan
Technical SEO | | FortressLearning0 -
Changing DNS -- SEO implications?
Hey Moz, We're migrating an old site on an old server over to a new server/DNS. The plan is to keep the same URL structure and reuse our existing URL's. As long as we make minimal changes to each page's content, we should be able to update our DNS entry and get all the pages recreated and assigned to their correct URLs without any reduction in SEO rankings. Is this correct? This site gets a lot of organic traffic and ranks highly on some challenging keywords, so it's key that we retain our rankings as much as possible. I've read that it's wise to lower the DNS time-to-live to one hour, about a day before the move, to help Google crawl the DNS a little quicker. Are there any other recommendations you guys can offer or past experiences?
Technical SEO | | stephen_reply0
