How many strong tags is too many
Hi everyone, just a quick question, what are your views on the use of strong tags in content? how many is too many?
What is you have strong tags around every keywords for a sentance etc?
Well yeah that wouldn't be too many at all, but then going back to what Marcus and EGOL said you're much better off using bold tags for readability reasons than simply using it on keywords really. It has little to no impact in terms of rankings (probably a tiny bit) but can have a much greater impact on keeping your visitors moving forward and converting if used to break the content up into more digestible chunks with a good scent of what's important to them and where their eyes should go next.
I'd probably use bold a few more times in a 500 word piece but use it as what it is, an emphasis tag
Not emphasising keywords for Google but whatever it is in the content that will encourage the user to feel they're in the right place... if that happens to combine with some keywords or keyword phrases then great, but don't see it as a game-changer for rankings
Its keywords that are bold, so i guess perhaps 1 or 2 for around 500 words would be about right?
I suppose if you were going to look at it as "how many is too many" though it would be a percentage density instead of an actual number because it would depend on the size of the piece.
If you had a 1,000 word page then 50 words in bold might look okay but if it were a 100 word page then 50 words in bold would be ridiculous.
Exactly (the everything is important bit, not agreeing with me).
I agree with Marcus... When you make everything important then nothing is important.
If you have to ask that question, I would say you are using too many.
The on page tool looks for one instance of a keyword in either a strong, bold or em tag so if you are doing this for SEO, the prevailing common sense would be that any more than that one is too many.
If the highlighting provides some kind of benefit for your users then you can do more but if you are looking at bolding lots of text for SEO - then forget it.
The best answer is to just use common sense and create something that is readable with the important keyword highlighted if you can do so in a natural way.
Hope it helps.
Marcus
Same H1 & H2 Tags
Is it bad to have the same H1 & H2 tag on one page? I found a similar question here on the moz forum but it didn't exactly answer my question. And will adding "about" on the H2 help, or should we avoid duplicate tags completely? Here is a link to the page in question (which will repeat throughout this site.) Thanks in advance!
Technical SEO | | Mike.Bean0 -
Exact Match Domain & Title Tag / URL
I currently own an exact match domain for my keyword. I have it set up with multiple pages and also a blog. The home page essentially serves as a hub and contains links to all the pages and the blog. My targeted keyword is on its own page and I made the title tag the same as my keyword. As an example the URL for my targeted post looks like this: benefitsofrunningshoes.com/benefits-of-running-shoes I have solid, non-spammy content and clean whitehat earned backlinks directing to that specific page. My concern right now is that the URL looks kinda spammy. The website has been live for about a week and the home page ranks well enough but my targeted page is no where to be found. (it does show up if I manually search via search command "site:benefitsofrunningshoes.com"). I'm wondering if it is acceptable to use the exact keyword in title tag / page url if it is also in the domain as an EMD? Should I change the title tag and leave the URL in? Or should I completely change the title tag and URL and 301 redirect to the new page? I appreciate any help!
Technical SEO | | Kusanagi170 -
Can I have an H1 tag below an H2?
Quick question for you all - Is there an issue with me having an H1 tag physically below an H2 tag on a web page??
Technical SEO | | Pete40 -
Special Characters in Title Tags & Meta Descriptions
Do special characters, such as the "&" symbol or a "," in title tags and meta descriptions negatively affect your ranking in search engines? Any feedback is much appreciated. Thank you!
Technical SEO | | ZAG1 -
For an image which is in the CSS and not the HTML, can you add an alt tag?
I would like to improve SEO on a page with three big images, which are currently hosted in the CSS. The sample I am working with is at http://xquisitevents.com/about-us/ and I put my cursor over the big picture of the wedding dress with bouquet, I inspected the element and saw this code in a div tag: #upperleft { background-image:url(images/AboutTopLeft.jpg); Can I add an alt tag to the CSS somehow, or can I have it added to the HTML? What is the best way to handle this, to include keywords like exquisite weddings and special event designs?
Technical SEO | | BridgetGibbons0 -
Too Many On-Page Links - caused by a drop down menu
Many of our e-com sites we build for customers have drop down menus to help the user easily find products without having to click - Example: http://www.customandcommercial.com/ But this then causes the report to trigger too many on page links We do have a site map and a google site map So should I put code in place not to follow the drop down menu link items or leave in place?
Technical SEO | | spiralsites0 -
Genesis WP Theme H1 Tag not properly Used?
I am in the process of redesigning my website, and I have been working on the Genesis framework a lot lately, so I used the Genesis framework to make my new site. The URL is http://protechig.com As I look at the H1 on the page (homepage only, every other page has solid h1s from an SEO perspective.) The first thing that I see is that the home page H1 is a links (to protech's home page). The second thing that I see is the the title text is replaced with an image (my logo) and there is a text-indent:-99999; and overflow:hiden; I just want to know from an SEO perspective if this is okay, and, if it isn't, what I could/should to to rectify it. Thanks Zach
Technical SEO | | Zachary_Russell0 -
Solving duplicate content with WP authors, tags, categories
I've been kind of neglecting wordpress installations on my websites and noticed many showing duplicate content for pages showing under author and tags, tags and single post, categories and single post. Should this be a concern? Whats the best way of fixing this? Thanks
Technical SEO | | cgman0
