Conversion optimization with Optimizely, impact on SEO
I am looking into signing up with www.optimizely.com for conversion testing. They put scripting on my site which will then redirect half of my site visitors to an alternate home page. The site I want to test on is ranking quite well with Google and I do not want to hurt my rankings.
And with this set up,what Google will think is my home page is not and so I am essentially sending visitors to a different page than Google reads as my home page in source code.
So, my concern is whether this will have a negative impact on my SEO rankings to redirect 50% of site visitors to a different page using this testing tool?
I would use Google Web Site Optimizer, but many of my sites are in Wordpress and it seems that Wordpress and web site optimizer are not so compatible.
Advice would be appreciated.
Thank you,
Robert
I realise this response is almost a year old, but I've only just found it. I am about to start using Optimizely, but am concerned about affecting my ranking especially now that we have a new Penguin update due any time now.
The nice guy at Optimizely told me today (during the webinar for newbies) that you could use Optimizely to permanently direct different sorts of visitors to different content. For example, he pointed out that people who today run IE 6 are very different from people who run IE 9. And depending on your market it might make sense to give those two groups different messaging. But Google specifically say don't deliver different content based on user-agent.
http://googlewebmastercentral.blogspot.co.uk/2012/08/website-testing-google-search.html And on the last point in that article, how long is too long?
Thank you for all of your responses. Dan Siroker, nice to see you responding- too thank you. I suppose I am left with that if I do use/need the function in Optimizely where I need to re-route to new url is to potentially use rel-canonical and block the second page in robot.txt. I feel that for basic landing page testing, I would not re-route and Optimizely seems like a great and easy solution and I will use it. For tests which would require re-routing, I am thinking perhaps Google optimizer is better because I am confident they will not penalize for re-route when they are the ones doing it. Dan, if you feel different, I'd be happy to get on phone to chat. Thank you all. Best, Robert
Yes, I've used Optimizely, and Ryan is completely correct in that you only create one page, just add javascript to make it different views for different visitors.
Hi Robert,
This is a great question. You are right that there are a few ways to run an experiment with Optimizely. The default and easiest way to get up and running is to run an experiment on the same URL without redirecting to another page. Alternatively you can redirect to another URL. Customers commonly use both techniques and neither will negatively impact SEO.
Here is a more detailed explanation of how Optimizely affects SEO: http://support.optimizely.com/kb/advanced/does-optimizely-affect-my-search-ranking-or-seo
Here is Google's stance on this: http://www.google.com/support/websiteoptimizer/bin/answer.py?hl=en&answer=63382
Hope that helps answer your question!
Thanks,
Dan Siroker
Co-Founder & CEO, Optimizely
Then you'll want to ask him if that necessitates a separate URL. If it does, you should rel=canonical the test page to point at the original home page, and noindex the test page to avoid any duplicate content situations.
You may also want to run this by the optimizely guys to see what their thoughts are, since they'll know exactly how their technology is altering your site.
Hi Ryan, thank you for response. There are two ways to test with them. The type of testing I would want to do would apparently (according to sales guy) require an alternative landing/home page.
My understanding is that the same URL is used for both test and control versions of your home page, meaning its not actually redirecting. Instead the changes are inserted using the javascript code dynamically. I'm not sure whether Google ignores the javascript change or incorporates it. Either way your test changes should be done with both SEO and user experience in mind, so don't run tests that would hurt your SEO and you'll be golden.
Will Landing Page Design with Large Areas of White Background Enjoy a Higher Conversion Rate?
My designer has created a landing page with a dark background. Text is white and other colors. Does a dark background impact the conversion rate? Is it better to have a white background? I am concerned that a dark background may distract visitors. The landing page is: http://www.nyc-officespace-leader.com/MidtownLawOfficeSublet3300SFBelowMarket We plan on using this landing page for LinkedIn advertising. Thanks!!
Conversion Rate Optimization | | Kingalan10 -
Weighted number of conversions - any explanation?
Do any of you know meaning of "weighted number of conversions" in attribution models? How google analytics calculate it? Any example? Thank you.
Conversion Rate Optimization | | Tormar0 -
Attribution model - the weighted number of conversions - GA
Hi, 1.Can someone explain me with an example what is "The weighted number of conversions under the custom selected attribution model"? How Analytics calculate it? 2. If I increase e.g social source for 1.4 in my attribution model, my organic or direct source are loosing that weighted number of conversions. Could it be because of organic or direct getting lower credit, or for some other reason? Ty. Br.
Date of Review on productpage - important for SEO?
Hi Have a questions. We have lots of products on the website. A lot have reviews and some do not.
Conversion Rate Optimization | | RetailClicks
Is it harming that review dates (post dates) are older then let's say 1-2 months? Cause we do not have fresh reviews every month. So is it better to then let the dates behind and not show? Or is it better to show 'old' dates. How important are fresh review dates on the website? We have hreview tags around the reviews and dates.0 -
Is it possible to set a Goal conversion tracking from a subdomain to a root domain?
Hi Mozzers, Here is an issue I am going through: I have a root domain(www.example.com) that is the core website where you are able to schedule a service I have a subdomain (sub.example.om) that is part of content strategy offering free tips and follows a different branding strategy. There are internal links from sub to root domain I have a GA subdomain tracking code installed on every page for both domains I would love to set goal tracking on GA for visitors coming to my subdomain, then going to root domain and then schedule a sevices? Is this possible? If it is, can someone show me a How To because I tried it anddidn't work? Thanks mozzers!
Conversion Rate Optimization | | Ideas-Money-Art0 -
How to track full path of website visitors until conversion, not just landing page?
hi, This is my first question in the forums and I'm looking forward to be part of a great SEO community. I was wondering ow to track full path of website visitors until conversion, not just landing page? I've been using Wordpress jetpack site stats for while, which shows great data like keywords used in google, landing page etc. But I would like to have access to the full path for each separate visitors (including their IP address and country is possible) to improve my website and conversions. Example: step 1: Visitor X types "seo" on Google step 2: visitor lands on my homepage step 3: visitor visits to order page and buys Is there such tool available as a Wordpress plugin? Or do I have to use Google analytics for this? thank you for your help, Marc
Conversion Rate Optimization | | marcandre0 -
Advice on SEO for Chinese Website in China
Hey folks, I am a little out of my depth here because I have never SEO'd a website that is not in English - and especially in China. I have a few questions that I hope someone can help with? What are the primary SE's in China Are there any specifics with regards Keyword Research Are there any specifics around SEO techniques and climbing up the SERPs? I know I don't speak Chinese but I will need to be advising. Thanks, Andy
Conversion Rate Optimization | | Andy.Drinkwater0 -
Can Changing Meta Descriptions Negatively Impact SERP's?
I have just had a page start ranking well in key SERP's and I would like to change the meta description and add a price as we are extremely competative in that line. Could changing the meta description now a page is ranking negatively impact the SERP placing? Does anyone have any experience with this?
Conversion Rate Optimization | | robertrRSwalters0
