How to Boost Your WordPress Website Speed to 95+ (Without Premium Plugins)
I'm reaching out for some advice on improving my WordPress website's speed. I'm currently using a free theme for this fusion magazine and aiming for a score of 95+ on Google PageSpeed Insights. I'm aware that premium plugins can significantly enhance performance, but I'm hoping to achieve similar results using primarily free solutions and manual optimizations.
Optimize Images: Compress and resize images to reduce their file size, improving page load times. Tools like TinyPNG or WP's built-in options can help achieve this.
Leverage Browser Caching: Configure browser caching through your .htaccess file or a free caching plugin to store static resources locally in users' browsers, decreasing load times for returning visitors.
Minify CSS, JavaScript, and HTML: Remove unnecessary code and whitespace from your website's files. This can be done using free plugins or by manually editing the files to enhance performance.
For comprehensive improvements, consider utilizing professional WordPress Development Services to tailor optimizations specific to your site's needs.
Use LiteSpeed cache free version for speed optimization. Upload images in webp format. If possible, host images on a subdomain. Could you check this website as a sample?
@mohammadrehanseo Hello Friend!
In my observation and results now I only use the LiteSpeed cache plugin to increase the speed as LiteSpeed cache plugin has updated its features and more user-friendly interface you have to choose the pre-written template to increase the speed you can check one by one all the template to increase speed. I have increased my speed from 55 to 99 on my two websites you can check them if you want and you can also take my help if you want here these are my two websiteThis is one of the most easy method to increase the speed I have ever used
@mohammadrehanseo I am eager to tell you that WordPress speed optimization is my profession. So you may just focus on this list and forget about the rest. You should consider the following:
- HTML caching on the CDN (not only the host)
- Redesign or rethink about the main thread of work (JavaScript execution)
- rearrange the ATF objects and dont lazy load if image or video and don't use web fonts if paragraph or any kind of text.
- Extract the Critical Path CSS style definitions and put it into the head section and request for the rest as a separate external CSS file
- configure asset caching
You may find some other useful tips on WordPress Speed Optimization page on Stack Exchange
For boosting your WordPress site's speed, especially for a site like whatsgb, focusing on optimizing images, leveraging caching, and minimizing plugins can make a big difference. Consider using a lightweight theme and ensure your hosting provider is optimized for WordPress. These steps, combined with careful optimization, can lead to significant improvements without solely relying on premium plugins.
Please look at my website, there is no way to achieve a result of more than 45. (((
the process of boosting you WordPress website speed is first to optimize your images, CSS files and clear the caches of your website
Choose a fast hosting provider with SSD storage.
Use a lightweight theme and delete unused plugins.
Compress images and use lazy loading.
Set browser caching and use caching plugins.
Minify CSS and JavaScript files.
Use a CDN like Cloudflare.
Optimize the database and enable GZIP compression.
Address server response time issues.
Optimize the homepage and landing pages.
Use Google PageSpeed Insights for analysis. -
I am sharing my experience of boosting the WordPress website. If you will follow my suggestions then you will be boost your website speed. Wp rocket is the best plugin for optimizing the website speed.
So sit on Gazebos take your laptop and work on your WordPress website and boost up. -
Great tips! Improving WordPress speed without premium plugins is a game-changer. Your guide provides practical insights for optimizing performance, making it accessible to all. Website globalfist.com speed is crucial for user experience and SEO, and your suggestions offer a valuable solution for WordPress users. Thanks for sharing these effective strategies!
I tried very hard to work on climateretrofit.co.uk for page speed especially by minimizing the and using webp images but still performance is very very bad and webpage loading time is very high. Additionally DA is very low, i am working on this website almost from 2 years but still not very satisfied. What should I do?
@mohammadrehanseo I just analyzed your site:
Desktop score is OK, mobile one needs some work.
Here is what I would do based on my optimization experience and what PageSpeed Insights for your site are suggesting:
- Install a free caching plugin, I've heard a free module Cache Enabled from KeyCDN is OK, just google for alternatives
- Move Javascript to the bottom to improve Start Render Time, there are free plugins for it
- Convert images to WebP and AVIF formats for lower weight. Use picture HTML5 tag to fallback to png or jpeg for browsers that don't support WebP/AVIF
- Use bigger TTL (about a year) for static content
@mohammadrehanseo You can use the LiteSpeed cache free plugin for speed optimization and no need to buy premium. I am also using it on a site FIFA 23 for Android and it's working well.
@mohammadrehanseo
<a href="faisalmover.com.pk">faisal movers</a> Please guide me.
Best redirect destination for 18k highly-linked pages
Technical SEO question regarding redirects; I appreciate any insights on best way to handle. Situation: We're decommissioning several major content sections on a website, comprising ~18k webpages. This is a well established site (10+ years) and many of the pages within these sections have high-quality inbound links from .orgs and .edus. Challenge: We're trying to determine the best place to redirect these 18k pages. For user experience, we believe best option is the homepage, which has a statement about the changes to the site and links to the most important remaining sections of the site. It's also the most important page on site, so the bolster of 301 redirected links doesn't seem bad. However, someone on our team is concerned that that many new redirected pages and links going to our homepage will trigger a negative SEO flag for the homepage, and recommends instead that they all go to our custom 404 page (which also includes links to important remaining sections). What's the right approach here to preserve remaining SEO value of these soon-to-be-redirected pages without triggering Google penalties?
Technical SEO | | davidvogel0 -
Unsolved Need Wordpress Front-end Plugin With Moz API
Hi Guys,
On-Page Optimization | | mrezair
I'm looking for Moz SEO Front-end Wordpress Plugin To Audit My Visitors Website And Show Results in my site. Like This plugin for Moz DA Checker: https://www.724ws.net/domain-authority-checker/ It's not important to be a free plugin or Premium one. I need to increase leads and traffic by it. Any suggestion will be appreciated.0 -
Unsolved Need Moz SEO Wordpress Plugin With API
Re: Moz WordPress Plugin? Hi guys,
Moz Pro | | mrezair
I need some Moz SEO Wordpress Plugins For my website working with Moz API. I've already found Moz DA-PA Checker plugin Moz DA-PA Checker But Need SEO Plugins too. Any Suggestion will be appreciated.0 -
Unsolved Question about a Screaming Frog crawling issue
Hello, I have a very peculiar question about an issue I'm having when working on a website. It's a WordPress site and I'm using a generic plug in for title and meta updates. When I go to crawl the site through screaming frog, however, there seems to be a hard coded title tag that I can't find anywhere and the plug in updates don't get crawled. If anyone has any suggestions, thatd be great. Thanks!
Technical SEO | | KyleSennikoff0 -
Google Not Indexing Pages (Wordpress)
Hello, recently I started noticing that google is not indexing our new pages or our new blog posts. We are simply getting a "Discovered - Currently Not Indexed" message on all new pages. When I click "Request Indexing" is takes a few days, but eventually it does get indexed and is on Google. This is very strange, as our website has been around since the late 90's and the quality of the new content is neither duplicate nor "low quality". We started noticing this happening around February. We also do not have many pages - maybe 500 maximum? I have looked at all the obvious answers (allowing for indexing, etc.), but just can't seem to pinpoint a reason why. Has anyone had this happen recently? It is getting very annoying having to manually go in and request indexing for every page and makes me think there may be some underlying issues with the website that should be fixed.
Technical SEO | | Hasanovic1 -
Wordpress Redirect Plugin Vs Manual .htaccess?
Hi everyone, I need to 301 redirect my old pages to new ones but i am confused between whether to choose plugin for this or i should manually rewrite the code on .htaccess file. Please give your suggestion and if you think i should use plugin then which one?
Technical SEO | | himanshu3019890 -
Why is my website banned?
IMy website is Costume Machine at www.costumemachine.com . My site has been banned for 1 year now. I have requested that google reconsider my site 3 times without luck. The site is dynamic and basically pulls in feeds from affiliate sites. We have added over 1,500 pages of original content. The site has been running great since 2008 without any penalties. I don't think I got hit with any linking penalty. I cleaned up all questionable links last November when the penalty hit. Am I being hit with a "thin" site penalty? If that is the issue what is the best way to fix the problem?
Technical SEO | | tadden0
