Reducing cumulative layout shift for responsive images - core web vitals
In preparation for Core Web Vitals becoming a ranking factor in May 2021, we are making efforts to reduce our Cumulative Layout Shift (CLS) on pages where the shift is being caused by images loading. The general recommendation is to specify both height and width attributes in the html, in addition to the CSS formatting which is applied when the images load. However, this is problematic in situations where responsive images are being used with different aspect ratios for mobile vs desktop. And where a CMS is being used to manage the pages with images, where width and height may change each time new images are used, as well as aspect ratios for the mobile and desktop versions of those.
So, I'm posting this inquiry here to see what kinds of approaches others are taking to reduce CLS in these situations (where responsive images are used, with differing aspect ratios for desktop and mobile, and where a CMS allows the business users to utilize any dimension of images they desire).
@seoelevated
I am facing issue of higher cumulative layout shift. The reason behind this is that I am loading css script at the end once complete page is rendered (in order to reduce page loading time. So page loading time is reduced on the cost of higher cumulative layout shift. I am new in SEO. Kindly suggest me, for improved google search ranking, whether it will matter and whether I should load css at the start itself for reducing cumulative layout shift. Also, being a pin code finder website, texts are limited only. Should I add more text in webpages for improved ranking. (for reference, the website is https://pincodeinfo.online ) -
I'm in the same exact situation as well! Feels like we are kind of stuck as I also have different aspect ratios for device and use a CMS that has a lot of limitations.
yes please, would love to know also, getting this error through aa gtmetrix and PSI reports
Sudden Drop in Mobile Core Web Vitals
Web Vitals Screengrab.PNG For some reason, after all URLs being previously classified as Good, our Mobile Web Vitals report suddenly shifted to the above, and it doesn't correspond with any site changes on our end. Has anyone else experience something similar or have any idea what might have caused such a shift? Curiously I'm not seeing a drop in session duration, conversion rate etc. for mobile traffic despite the seemingly sudden change.
Technical SEO | | rwat0 -
Looking for live web examples of Medical schema
Has anyone seen a hospital system or medical clinic properly employ schema markup to their sites? This seems like very new territory, and we want to do it right by our client. Are there any best practices I need to look out for?
Web Design | | Madgenius3 -
Https pages indexed but all web pages are http - please can you offer some help?
Dear Moz Community, Please could you see what you think and offer some definite steps or advice.. I contacted the host provider and his initial thought was that WordPress was causing the https problem ?: eg when an https version of a page is called, things like videos and media don't always show up. A SSL certificate that is attached to a website, can allow pages to load over https. The host said that there is no active configured SSL it's just waiting as part of the hosting package just in case, but I found that the SSL certificate is still showing up during a crawl.It's important to eliminate the https problem before external backlinks link to any of the unwanted https pages that are currently indexed. Luckily I haven't started any intense backlinking work yet, and any links I have posted in search land have all been http version.I checked a few more url's to see if it’s necessary to create a permanent redirect from https to http. For example, I tried requesting domain.co.uk using the https:// and the https:// page loaded instead of redirecting automatically to http prefix version. I know that if I am automatically redirected to the http:// version of the page, then that is the way it should be. Search engines and visitors will stay on the http version of the site and not get lost anywhere in https. This also helps to eliminate duplicate content and to preserve link juice. What are your thoughts regarding that?As I understand it, most server configurations should redirect by default when https isn’t configured, and from my experience I’ve seen cases where pages requested via https return the default server page, a 404 error, or duplicate content. So I'm confused as to where to take this.One suggestion would be to disable all https since there is no need to have any traces to SSL when the site is even crawled ?. I don't want to enable https in the htaccess only to then create a https to http rewrite rule; https shouldn't even be a crawlable function of the site at all.RewriteEngine OnRewriteCond %{HTTPS} offor to disable the SSL completely for now until it becomes a necessity for the website.I would really welcome your thoughts as I'm really stuck as to what to do for the best, short term and long term.Kind Regards
Web Design | | SEOguy10 -
SEO Issues From Image Hotlinking?
I have a client who is hotlinking their images from one of their domains. I'm assuming the images were originally stored on the first domain (let's call it SiteA.com) and when they were putting together SiteB.com, they decided to just link to the images directly on SiteA.com instead of moving the images to Site B. Essentially hotlinking. Site A is not using the images in any way and in essence is just a gateway for their other sites and in this case a storage for their images. It doesn't use those images at all, so it really doesn't get any benefits of the images being referenced since I read that Google sometimes counts that hotlinking as a "vote" for the original image. But again, since ite A doesn't use the images that are being hotlinked at all, there's no benefit for Site A. My concern is that it's affecting their SEO for Site B because it makes it look like Site B is simply scraping data by hotlinking those images from Site A. Their programmer suggested creating a virtual directory so that it "looked" like it was coming from Site B. My guess is that Google can see this, so then not only will it look like Site B is scaping/hotlinking images, but also trying to hide it which may send up red flags to Google. My suggesstion to them was to just upload the images correctly into their own images directory on Site B. They own the images, so there's not any copyright issue, but that if they want proper SEO credit for that content, it all needs to be housed on the correct server and not hotlinked. Am I correct in this or will the virtual directory serve just as well?
Web Design | | GeorgiaSEOServices1 -
Best layout pages for SEO
Dear all, what would be the ideal layout of a webpage for SEO? How would a homepage and landingspage look like? Thanks in advance! Best regards, Ben
Web Design | | HMK-NL0 -
Over Optimization & Footer Links for Crediting Web Design to a Company
With the recent updates to the algorithm having to do with link networks and over optimization it has got me to thinking about the footer links we add to each site that we build and do web design for linking back to ours. I could certainly see how Google could make the assumption that these are all on the same server, pointing back to one main site, and penalize us for that. Should we no=follow these links? They may say something like, "Website Designed By: Company Name". They do provide a valuable source to some extent of traffic to the site from people interested in our designs. Any thoughts?
Web Design | | JoshGill270 -
Live Text in Navigation Vs. Image - Does this affect SEO
I recently was asked the question if having live text in the navigation vs and image affect seo. For example, refer to this link http://markup.io/v/avsaenq856kw the navigation highlighted is seperate images. The html elements read : /images/procedures.png"> Live text html reads like this: Breast » What is better for seo value, or does it now matter having live text or an image?
Web Design | | Red_Spot_Interactive0 -
Does anyone think the <figcaption>attribute from HTML5 will have any influence for image search?</figcaption>
There is a <figure>element that is supposed to provide better descriptions of image on the web in HTML5 - do you think that will replace the importance of the "Alt" tag? Link to figcaption description </figure>
Web Design | | RankSurge2
