Max-snippet max length
Regarding Google's new
max-snippet:[number]
, this is specifically for the length of the meta description?Also, does anyone know what the max character length is?
I try to structure the meta description to describe what is on the landing page in a way to encourage click-throughs under the max-constraint. If you are shorter, no biggie! Good luck
Thanks. If we don't plan on shortening our meta description displayed in SERPs, do we need to do anything with max snippet length? Is it only for people who want to shorten the description showed?
For Google, typically between 920 and 923 pixels (or roughly 160 characters). However, this does change periodically.
Thank you Daniel!
The new max-snippet feature is used for you to limit up to which length of characters you want to display the meta description for the page. You should be able to put any positive integer there.
The issue stands by the Meta Description best practices. If your meta description is over 160 characters, then Google will shorten it not to take too much search results space, so ideally you would want to put a max-snippet length of up to 160.
You can find more information about Meta description best practices here.
Daniel Rika - Dalerio Consulting
https://dalerioconsulting.com/
[email protected]
What is the importance of exact match keywords for local SEO in service industry businesses?
I am working with a local service contractor. Several of his competitors have domain names with exact match keywords. Audits of competitor sites and use of other research tools reveals that their sites are behind in content and technical SEO. The competitor sites consistently rank higher in organic search results. I am new to SEO and I understand that some of my lack of clarity here is a result of not understanding the value of key word use in local SEO vs. wider efforts.
Technical SEO | | Andrew Woffenden3 -
Why have my positions dropped after implementing recommended changes?
Hello! I have taken a Moz free trial and am really enjoying using this service. But, after implementing the recommended changes by Moz my rankings have really dropped. Is this normal? I was averaging around 17 but now averaging 40. Here is my website if anyone has any ideas of what I might be doing wrong, I would greatly appreciate any help.
Technical SEO | | NicoleChambers
Thank you
Nicole1 -
How to fix core web vital issue on shopify website , any recommned app from shopfiy store?
I'm facing challenges optimizing Core Web Vitals on my Shopify store. Does anyone have experience with Shopify apps that effectively address LCP, FID, and CLS issues? Any specific recommendations would be greatly appreciated.
Technical SEO | | faizalialiali0 -
URLs dropping from index (Crawled, currently not indexed)
I've noticed that some of our URLs have recently dropped completely out of Google's index. When carrying out a URL inspection in GSC, it comes up with 'Crawled, currently not indexed'. Strangely, I've also noticed that under referring page it says 'None detected', which is definitely not the case. I wonder if it could be something to do with the following? https://www.seroundtable.com/google-ranking-index-drop-30192.html - It seems to be a bug affecting quite a few people. Here are a few examples of the URLs that have gone missing: https://www.ihasco.co.uk/courses/detail/sexual-harassment-awareness-training https://www.ihasco.co.uk/courses/detail/conflict-resolution-training https://www.ihasco.co.uk/courses/detail/prevent-duty-training Any help here would be massively appreciated!
Technical SEO | | iHasco0 -
Google will index us, but Bing won't. Why?
Bing is crawling our site, but not indexing it, and we cannot figure out why -- plus it's being indexed fine in Google. Any ideas on what the issue with Bing might be? Here's are some details to let you know what we've already checked/established: We have 4 301’s and the rest of our site checks out We’ve already established our Robots is ok, and that we are fixing our site map/it's in fine shape We do not see anything blocking bingbot access to the site There is no varnish or any load balancers, so nothing on that end that would be blocking the access We also don't see any rules in the apache or the .htaccess config that would be blocking the access
Technical SEO | | Alex_RevelInteractive1 -
Meta Description VS Rich Snippets
Hello everyone, I have one question: there is a way to tell Google to take the meta description for the search results instead of the rich snippets? I already read some posts here in moz, but no answer was found. In the post was said that if you have keywords in the meta google may take this information instead, but it's not like this as i have keywords in the meta tags. The fact is that, in this way, the descriptions are not compelling at all, as they were intended to be. If it's not worth for ranking, so why google does not allow at least to have it's own website descriptions in their search results? I undestand that spam issues may be an answer, but in this way it penalizes also not spammy websites that may convert more if with a much more compelling description than the snippets. What do you think? and there is any way to fix this problem? Thanks!
Technical SEO | | socialengaged
Eugenio0 -
DISQUS COMMENTS backlinks-good for seo? YES/NO?
DISQUS COMMENTS backlinks-good for seo? YES/NO? I have just started commenting on "powered by disquus" websites in the Disqus comments box and left a link to my website in the name field! Having googled whether Disqus comments backlinks are any good for seo purposes i have discovered that there is a 50/50 view on the subject with some people saying they are a "goldmine" for getting high PR backlinks and others saying they are a waste of time because googlebot cannot read Java. My own experience of commenting on Disqus powered websites is that wordpress blogs powered by disqus comments ARE INDEXED by GOOGLE and the "BACKLINK IS IN THE SOURCE OF THE PAGE" When i comment on normal websites using the Disqus comment system i have found that my Disqus comments ARE NOT indexed by Google and there IS NO BACKLINK in the page source! Has anybody got any views on whether Disqus comments backlinks are any good?
Technical SEO | | Freebetsuk2 -
Where should a knowledge base be hosted for max. SEO benefit?
A client would like to set up a knowledge base to work in conjunction with their website and we are tossing up whether to go with a hosted solution (and therefore set up as a subdomain) or find a solution that we host on the clients domain (which will presumably have more SEO benefit). We are leaning towards the latter (although are mindful that we need to balance the client’s desire for a quality KB solution). Appreciate your feedback.
Technical SEO | | E2E0
