Best way to handle Breadcrumbs for Blog Posts in multiple categories?
The site in question uses Wordpress. They have a Resources section that is broken into two categories (A or B). Underneath each of these categories is 5 or 6 subcategories. The structure looks like this:
- /p/main-category-a/subcategory/blog-post-name
- /p/main-category-b/subcategory/blog-post-name
All posts have a main category, but other posts often have multiple subcategories while some posts also fall into both main categories.
What would be the easiest or most effective way to auto-populate the breadcrumb based on from where the person reached the blog post? So for example, a way to set Home -> Main Category -> Subcategory 1 as the breadcrumb if they reach it from the Subcategory 1 landing page.
Or is this not possible and we should just set the breadcrumb manually based on where we feel it best lives?
Thanks.
Set it manually on where it lives best, or programmatically let them pick the one that is most relevant. I would not implement any logic based on where users are coming from. You're likely well of by spending your engineering resources better than doing that for SEO.
Breadcrumbs with JSON-LD
Just a quick question re implementation of JSON-ID breadcrumbs You are here: Acme Company → Electronics → Computers → Laptops So in this example laptops is my current page without a link on the visible on-page breadcrumb. When implementing JSON-LD BreadcrumbList should Laptops be included in the schema snippet, or commence from Computers to home?
Technical SEO | | MickEdwards0 -
What's the best way to test Angular JS heavy page for SEO?
Hi Moz community, Our tech team has recently decided to try switching our product pages to be JavaScript dependent, this includes links, product descriptions and things like breadcrumbs in JS. Given my concerns, they will create a proof of concept with a few product pages in a QA environment so I can test the SEO implications of these changes. They are planning to use Angular 5 client side rendering without any prerendering. I suggested universal but they said the lift was too great, so we're testing to see if this works. I've read a lot of the articles in this guide to all things SEO and JS and am fairly confident in understanding when a site uses JS and how to troubleshoot to make sure everything is getting crawled and indexed. https://sitebulb.com/resources/guides/javascript-seo-resources/ However, I am not sure I'll be able to test the QA pages since they aren't indexable and lives behind a login. I will be able to crawl the page using Screaming Frog but that's generally regarded as what a crawler should be able to crawl and not really what Googlebot will actually be able to crawl and index. Any thoughts on this, is this concern valid? Thanks!
Technical SEO | | znotes0 -
Handling of Duplicate Content
I just recently signed and joined the moz.com system. During the initial report for our web site it shows we have lots of duplicate content. The web site is real estate based and we are loading IDX listings from other brokerages into our site. If though these listings look alike, they are not. Each has their own photos, description and addresses. So why are they appear as duplicates – I would assume that they are all too closely related. Lots for Sale primarily – and it looks like lazy agents have 4 or 5 lots and input the description the same. Unfortunately for us, part of the IDX agreement is that you cannot pick and choose which listings to load and you cannot change the content. You are either all in or you cannot use the system. How should one manage duplicate content like this? Or should we ignore it? Out of 1500+ listings on our web site it shows 40 of them are duplicates.
Technical SEO | | TIM_DOTCOM0 -
Blogs are best when hosted on domain, subdomain, or...?
I’ve heard the it is a best practice to host your blog within your site. I’ve also heard it’s best to put it on a subdomain. What do you believe is the best home for your blog and why?
Technical SEO | | vernonmack0 -
Handling 301s: Multiple pages to a single page (consolidation)
Been scouring the interwebs and haven't found much information on redirecting two serparate pages to a single new page. Here is what it boils down to: Let's say a website has two pages, both with good page authority of products that are becoming fazed out. The products, Widget A and Widget B, are still popular search terms, but they are being combined into ONE product, Widget C. While Widget A and Widget B STILL have plenty to do with Widget C, Widget C is now the new page, the main focus page, and the page you want everyone to see and Google to recognize. Now, do I 301 Widget A and Widget B pages to Widget C, ALTHOUGH Widgets A and B previously had nothing to do with one another? (Remember, we want to try and keep some of that authority the two page have had.) OR do we keep Widget A and Widget B pages "alive", take them off the main navigation, and then put a "disclaimer" on the pages announcing they are now part of Widget C and link to Widget C? OR Should Widgets A and B page be canonicalized to Widget C? Again, keep in mind, widgets A and B previously were not similar, but NOW they are and result in Widget C. (If you are confused, we can provide a REAL work example of what we are talkinga about, but decided to not be specific to our industry for this.) Appreciate any and all thoughts on this.
Technical SEO | | JU19850 -
URL rewriting from subcategory to category
Hello everybody! I have quite simple question about URL rewriting from subcategory to category, yet I can't find any solution to this problem (due to lack of my deeper apache programming knowledge). Here is my problem/question: we have two website url structures that causes dublicate problems: www.website.lt/language/category/ www.website.lt/language/category/1/ 1 and 2 pages are absolutely same (both also returns 200 OK). What we need is 301 redirect from 2 to 1 without any other deeper categories redirects (like www.website.com/language/category/1/169/ redirecting to .../category/1/ or .../category/). Here goes .htaccess URL rewrite rules: RewriteRule ^([^/]{1,3})/([^/]+)/([^/]+)/([^/]+)/([^/]+)/([^/]+)/$ /index.php?lang=$1&idr=$2&par1=$3&par2=$4&par3=$5&par4=$6&%{QUERY_STRING} [L] RewriteRule ^([^/]{1,3})/([^/]+)/([^/]+)/([^/]+)/([^/]+)/$ /index.php?lang=$1&idr=$2&par1=$3&par2=$4&par3=$5&%{QUERY_STRING} [L] RewriteRule ^([^/]{1,3})/([^/]+)/([^/]+)/([^/]+)/$ /index.php?lang=$1&idr=$2&par1=$3&par2=$4&%{QUERY_STRING} [L] RewriteRule ^([^/]{1,3})/([^/]+)/([^/]+)/$ /index.php?lang=$1&idr=$2&par1=$3&%{QUERY_STRING} [L] RewriteRule ^([^/]{1,3})/([^/]+)/$ /index.php?lang=$1&idr=$2&%{QUERY_STRING} [L] RewriteRule ^([^/]{1,3})/$ /index.php?lang=$1&%{QUERY_STRING} [L] There are other redirects that handles non-www to www and related issues: RedirectMatch 301 ^/lt/$ http://www.domain.lt/ RewriteCond %{HTTP_HOST} ^domain.lt RewriteRule (.*) http://www.domain.lt/$1 [R=301,L] RewriteCond %{REQUEST_FILENAME} !-f RewriteCond %{REQUEST_URI} !(.)/$RewriteRule ^(.)$ http://www.domain.lt/$1/ [R=301,L] At this moment we cannot solve this problem with rel canonical (due to our CMS limits). Thanks for your help guys! If You need any other details on our coding, just let me know.
Technical SEO | | jkundrotas0 -
Best 404 Error Checker?
I have a client with a lot of 404 errors from Web Master Tools, and i have to go through and check each of the links because Some redirect to the correct page Some redirect to another url but its a 404 error Some are just 404 errors Does anyone know of a tool where i can dump all of the urls and it will tell me If the url is redirected, and to where if the page is a 404 or other error Any tips or suggestions will be really appreciated! Thanks SEO Moz'rs
Technical SEO | | anchorwave0 -
Which is the best wordpress sitemap plugin
Does anyone have a recommendation for the best xml sitemap plugin for wordpress sites or do you steer clear of plugins and use a sitemap generator then load it up to the root manually?
Technical SEO | | simoncmason0
