Exact Domain Match does it help or distract?
Does owning / buying an exact domain match help or not necessary?
For example our main website ranks for nearly 14,800 Keywords but one KW we are trying to get in the top spot for we are currently at the bottom of page #1. We do see an exact domain match available so we purchased it but i don't know if it would actually help us or distract us.
I was thinking we could create an article about the keyword on that exact domain then do some on page seo and back linking. But would that be more of a distraction VS. just focusing on getting more high quality back links to the main website we have ranked on Page 1 at the bottom?
Any ideas or benefits to use an exact domain match to help boost also?
We see this quite often; sometimes, an exact match domain will rank much higher than websites that seem to have better organic SEO.
I don’t think it will do much. Unless you’re current domain is really no doing well.
It would need constant content to rank well.
The keyword is Multiple Listing Service. The domain we purchased is multiplelistingservice.com do you think we should write one article based around the keywords Multiple Listing Service then have internal links that point back to our main website that is already ranked for this KW?
or will that not do much? As multiplelistingservice.com is a new domain with no domain authority or links so even though its an exact match its not going to pass along much Link Juice .
They matter a little bit but only for that one keyword if you have a great brand it is much better for you to use that brand name. Recently it seems Google is giving less and less attention to exact match domains I would not rush out and buy one.
Will be creating a doorway page and even if it ranks number one you'll have to put a lot of good content into it not just by the domain
I haven't looked at the age of the domain or if it was used. I have a feeling it is a fresh domain that wasn't used for anything.
But I'm trying to weigh out if we should create content, an article on that domain based around that exact keyword then do backlinking OR if we should just get more anchored text back links to our main page. or if we have any other options to use an exact domain match to help us rank either that domain or our main domain for the KW ya know?
Exact keyword match in case of domain is always a good thing, however I wouldn't personally be able to predict if steps mentioned by you will help you rank for this KW for one particular reason. The reason is links - their quality and numbers. Also, what's the domain age? Did you check "Wayback machine"? If you didn't then have a look what was domain previously used for. Exact match is not everything now with more and more experts stating that you have to have good mixture of exact keyword match and url's. Hope that helps.
Backlinks from ads on parked domains? Is this possible?
Hello Moz Friends, So as I was researching some competitive backlinks and I noticed a lot of backlinks that a clients competitor has are on parked domains and they appear to be google ads from some point. You know the pages that this page no longer exists, or hey do you want to buy this domain? and it has like 6 google ads on it? Yep those pages. My clients industry is construction and their competitor has links from zombie websites, foreign, websites and more. But the links are no longer on the page. Like when it was crawled, their ad was showing. Does this make any sense and is it usually temporary? Thank you for your thoughts friends!
Link Building | | asbchris0 -
Is it okay to post my blog posts to both an internal blog on our domain and an external blog?
We have a blog internally at kay-grant.com/blog and also created an external blog at ActiveRain.com Is it okay to post the same blog posts to both sites or should I have different content for each blog?
Link Building | | geoff81510 -
Moving blogs to different domain
Hey guys, We currently have some blogs on one of our pages (fraserisland.com.au) and we are launching a complete rebranding of our sites. We want to move the blogs from fraserisland.com.au to the new parent page of travelfreedom.com.au (but still link it to fraserisland.com.au), however I don't know what affect this will have on the ranking of the blogs. The biggest thing I'm worried about is that the domain will be completely different, and not a sub domain, but I'm not sure what impact this will have on the effectiveness of SEO on the blog. Thanks guys
Link Building | | Mysites0 -
Root-Domain vs Subdomain Linkbuilding
Hello Mozzers! Couple of days ago I received a request to start optimizing a wordpress website, the domain itself has been around for around 10-12 years so it's it can be considered as one that has real history behind it. The page has been moved from HTML/FLASH to wordpress about 3 - 4 years ago and hasn't been any SEO maintenance on it. The site used to rank for first position with several keywords, but now understandably, it has greatly decreased. My main question would be, that when I've checked the root domain's and the subdomain's metrics with MOZ Open Site Explorer, the sub domain (with "www.") showed a PA 40 and 90 external links while the root domain (without "www.") only has 27 PA and 6 External links. I know that the 301 or server redirects only transfers about 90% of the link juice to the targeted URL but the difference between the 2 results seem way too big for me. What do you think? Is this normal?
Link Building | | adamdankhazi
During future link building is it more beneficial to target the root domain so the page won't lose that "10%" by redirecting the new link from sub-domain to root domain?
Is it possible to get more juice transferred? Thank you very much,
Adam0 -
Separate blog url helpful?
I am managing a website for a hotel brokerage firm. The main URL is www.hotelassetsgroup.com but we started a new blog with the URL www.hotelsforsaleblog.com. We chose the blog URL because it has the words "hotels for sale." The main website has a tab at the top titled "Blog" which links to the blog URL. I am not sure if this is helping us or not because the main URL and blog URL are both competing for the name of the business "Hotel Assets Group." The blog has very little interlinking within the same URL because it mainly links to the main website. Should we combine the two URLs together and just have the blog URL be the same like- hotelassetsgroup.com/blog or something like that?
Link Building | | lwilkins0 -
Your Experience with Exact Match Anchor Text Penalties
Hi Moz community! I was wondering if anyone has ever seen a site penalized or dampened because of too many exact match anchor links or know of any examples. I don't want to be overly concerned about it if it is a low risk. Thanks!
Link Building | | SparkplugDigital0 -
Does linking to a subdomain give link juice to the main domain?
I have a few domains that I'm going to use for link building, will the link juice from the sub domains transfer to the main domain?
Link Building | | Vsky0
