How does a canonical work and is it necessary to also have a no index, follow tag in place?
Across our site, we have canonical tags in place for URLs that contain duplicate content and for URLs without a trailing slash since we are using URLs WITH a trailing slash for all URLs across our site. We also recently added a no index, follow tag to all non-canonical URLs since we noticed a high number of duplicate content URLs in Google Webmaster Tools.
The first part of my question is: How does a canonical work? Does the robot read the canonical and immediately go to the canonical URL or does it continue to read past the canonical tag and get to the no index, follow tag if there is one present?
The second part of my question is: Is it necessary to have both a canonical tag and no index, follow tag in place? Or should the canonical tag be sufficient to avoid duplicate content?
And lastly, if both a canonical tag and no index, follow tag are in place, should they be in a specific order? Canonical tag first then no index, follow tag second or no index, follow tag first then canonical tag second?
I would appreciate any insight you can give. Thank you!
Thank you for you responses and advice!
Very nice addition John.
Ryan, spot on as always.
One other thing, it sounds like some of the canonicals you're placing on pages would be better suited to 301 redirects, like correcting a URL for not having a trailing slash or not. If you can avoid using canonicals and use 301 redirects instead, that's the preferred method for resolving duplicate content issues. Canonicals are more for when there are parameters on the URLs, and you can't get away from serving the pages with those parameters.
The first thing to understand is the canonical tag is a suggestion, not an order. While a search engine will usually honor the canonical tag, there are instances where Google or other SEs may determine the canonical tag is not being used correctly so they disregard the canonical tag. Based on this understanding, yes the robot will read the entire page regardless of the canonical tag status.
The two tags you mention conflict. You would never use both tags on the same page.
Noindex means you do not wish the page to appear in the search index. The canonical tag means you do wish the content to be included in the search index, but use the canonical URL in the index.
The order of meta tags does not matter. If a page was marked with both a canonical tag and a noindex tag, the noindex tag would take effect and the page would not be indexed, so the canonical tag would not have any effect.
In short, you want to use the canonical tag to resolve duplicate content issues, not the noindex tag.
Rel canonical tag from shopify page to wordpress site page
We have pages on our shopify site example - https://shop.example.com/collections/cast-aluminum-plaques/products/cast-aluminum-address-plaque That we want to put a rel canonical tag on to direct to our wordpress site page - https://www.example.com/aluminum-plaques/ We have links form the wordpress page to the shop page, and over time ahve found that google has ranked the shop pages over the wp pages, which we do not want. So we want to put rel canonical tags on the shop pages to say the wp page is the authority. I hope that makes sense, and I would appreciate your feeback and best solution. Thanks! Is that possible?
Intermediate & Advanced SEO | | shabbirmoosa0 -
Rel=canonical and internal links
Hi Mozzers, I was musing about rel=canonical this morning and it occurred to me that I didnt have a good answer to the following question: How does applying a rel=canonical on page A referencing page B as the canonical version affect the treatment of the links on page A? I am thinking of whether those links would get counted twice, or in the case of ver-near-duplicates which may have an extra sentence which includes an extra link, whther that extra link would count towards the internal link graph or not. I suspect that google would basically ignore all the content on page A and only look to page B taking into account only page Bs links. Any thoughts? Thanks!
Intermediate & Advanced SEO | | unirmk0 -
Fast/Easy Way to Implement Canonical tags in Bulk in Magento CMS?
Hello Amazing SEO Community! Quick Q for a client with a TON of duplicate content. (yikes!) My client is currently undertaking a large SEO project around canonical tagging for their thousands of duplicate pages. Currently, one product sits on multiple URLs and they are being indexed as different pages (with the same content). The issue is found across all products and other pages, and across their international sites as well. One core challenge they face now is lack of time/resources from their developer side. The solution we see to the duplicate content is to manually add a canonical tag to each of our tens of thousands of pages. Their content management system is Magento. Has anyone ever tackled canonicalization for a large site that uses Magento? Any more efficient solutions to manual tagging is ideal. Thanks in advance for your input. -Bonnie
Intermediate & Advanced SEO | | accpar0 -
Proper 301 in Place but Old Site Still Indexed In Google
So i have stumbled across an interesting issue with a new SEO client. They just recently launched a new website and implemented a proper 301 redirect strategy at the page level for the new website domain. What is interesting is that the new website is now indexed in Google BUT the old website domain is also still indexed in Google? I even checked the Google Cached date and it shows the new website with a cache date of today. The redirect strategy has been in place for about 30 days. Any thoughts or suggestions on how to get the old domain un-indexed in Google and get all authority passed to the new website?
Intermediate & Advanced SEO | | kchandler0 -
301s being indexed
A client website was moved about six months ago to a new domain. At the time of the move, 301 redirects were setup from the pages on the old domain to point to the same page on the new domain. New pages were setup on the old domain for a different purpose. Now almost six months later when I do a query in google on the old domain like site:example.com 80% of the pages returned are 301 redirects to the new domain. I would have expected this to go away by now. I tried removing these URLs in webmaster tools but the removal requests expire and the URLs come back. Is this something we should be concerned with?
Intermediate & Advanced SEO | | IrvCo_Interactive0 -
Canonical tag - but Title and Description are slightly different
I am building a new SEO site with a "Silo" / Themed architecture. I have a travel website selling hotel reservations. I list a hotel page under a city page - example, www.abc.com/Dallas/Hilton.html Then I use that same property under a segment within the city - example www.abc.com/Dallas/Downtown/Hilton.html, so there are two URLs with the same content Both pages are identical, except I want to customize the Title and Description. I want to customize the title and description to build a consistent theme - for example the /Downtown/Hilton page will have the words "Near Downtown" in the Title and Description, while the primary city Hilton page will not. So I have two questions about this. First, is it okay to use a canonical tag if the Title and Description are slightly different? Everything else is identical. If so, will Google crawl and comprehend the unique Title and Description on the "Downtown" silo? I want Google to see that I have several "supporting" pages to my main landing page(s). I want to present to Google 5 supporting pages in each silo that each has a supporting keyword theme. But I'm not sure if Google will consider content of pages that point to a different page using the canonical tag. Please see this supporting example: http://d.pr/i/aQPv Thanks for your insights. Rob
Intermediate & Advanced SEO | | partnerf0 -
Best way to implement canonical tags on an ecommerce site with many filter options?
What would be the best way to add canonical tags to an ecommerce site with many filter options, for example, http://teacherexpress.scholastic.com? Should I include a canonical tag for all filter options under a category even though the pages don't have the same content? Thanks for reading!
Intermediate & Advanced SEO | | DA20130 -
How do you de-index and prevent indexation of a whole domain?
I have parts of an online portal displaying in SERPs which it definitely shouldn't be. It's due to thoughtless developers but I need to have the whole portal's domain de-indexed and prevented from future indexing. I'm not too tech savvy but how is this achieved? No index? Robots? thanks
Intermediate & Advanced SEO | | Martin_S0
