Is using REACT SEO friendly?
Hi Guys
Is REACT SEO friendly? Has anyone used REACT and what was the results? Or do you recommend something else that is better suited for SEO?
Many thanks for your help in advance.
Cheers
Martin
@martin1970 said in Is using REACT SEO friendly?:
React itself isn't inherently bad for SEO, but extra care must be taken with regards to optimizing its use for search. Many successful websites use React, yet SEO optimization remains essential.
Consider frameworks such as Next.js, which handles server-side rendering for SEO-friendly development. For ultimate efficiency, however, a static site generator might be better.
If you're interested in SEO, you can join a digital marketing course in Kolkata!
React can be SEO-friendly, but there are considerations to keep in mind due to its default client-side rendering. When search engines crawl websites, they traditionally expect server-rendered HTML for indexing. React applications often render content on the client side, which can pose challenges for search engine optimization (SEO).
To address this issue, there are a few strategies:
Server-Side Rendering (SSR):
- SSR involves rendering React components on the server before sending HTML to the client. This ensures that search engines receive fully rendered HTML, making content easily indexable.
- Tools like Next.js, a React framework, support SSR, providing a smoother SEO experience.
Static Site Generation (SSG):
- SSG generates static HTML files during the build process. This approach ensures that content is pre-rendered, enhancing SEO performance.
- Next.js also supports SSG, making it a versatile choice for projects requiring strong SEO.
Prerendering:
- Prerendering involves generating static HTML for specific pages at build time. This approach combines the benefits of SSR and SSG, allowing developers to target critical pages for SEO optimization.
Several companies and developers have successfully implemented React with SEO in mind. By using SSR or SSG, they've achieved positive results in search engine rankings and overall visibility.
It's essential to note that while React can be SEO-friendly, other frameworks like Angular or Vue.js may also offer SEO solutions. The choice depends on the project's specific requirements and the developer's familiarity with the framework.
In summary, React can be made SEO-friendly through practices like SSR, SSG, or prerendering. Many developers have experienced success in maintaining good SEO performance with React, especially when using tools like Next.js. However, the decision should be based on the project's needs, available resources, and the development team's expertise. Always ensure that your chosen approach aligns with current SEO best practices to achieve optimal results.
I have doing some research on this issue since there are lots of mixed opinion on this. Per my friends who work on this matter closely, Google, Bing, Yahoo, and DuckDuckGo should all be able to fetch the React based single page applications.
Custom Mat Board (which cuts customized mat boards for any Amazon or IKEA picture frames) is a React based application, and it works well. Please check out Fetch as Google and note if there are any major difference between what Google bot sees and what humans can see. If there are significant differences, you should do something about it. But per my experience, Google bots and humans do see the same thing.
PM me if you have any questions. Cheers!
WJ
Thanks for discussing this, Martijn.
Aside from Google, is there any concern that other search engines would have issues rendering a JS website, whether the site uses React, Angular or another framework?
-SB
Hi Martin,
It can be, that's the actual answer. As React is using JavaScript to load its pages and load the content in most cases. Google and other search engines are able to read the content but it's always required in these cases to check what the actual result is. I've worked with many sites using React and it depends if they're using server or client-side rendering. Start there, to figure out what you can be using for your client/company. Some teams are really drawn to the client side rendering which is a little bit more dangerous as not always can Google see the actual content. In case of server-side rendering, I've seen it go well for most of these.
Let me know if you have any specific questions, happy to answer them!
Martijn.
How important are author bios to SEO?
I'm trying to understand the importance of author bios to Google and its latest algorithms. Some say author bios affect rankings, but others say that has not been specifically stated by Google — but it does affect the user experience. Anyone have input on this? Thanks!
Algorithm Updates | | SallieJ0 -
How do you optimize a blog post for SEO after the RankBrain?
Hi Guys Just curious to hear what you guys do to rank blog posts in the top in Google especially onsite, after the RankBrain update? Do you still use SEO tools to optimize this or are the SEO tools outdated for this? If yes which tools do you use to get success with? Cheers John
Algorithm Updates | | igniterman751 -
Having 2 domains with same name - Impact on SEO
Hi AllAs we still dwindle with the rankings not coming in line with the efforts.I have a question: We have 2 websites 1. http://www.example.com/ (which lost traffic and rank in Jan 2013). So we assumed that it was due to some penguin penalty. So we worked on disavow extra but nothing actually helped.Though there was no manual penalty mentioned in the GWT. Frustrated with this we thought of having another website 6 months back: 2. https://example.org/ - we did all the right things and by the book. But we are not seeing ranking here too. We did backlink analysis on all competitors and worked on only quality links they had. So all our links are highly highly relevant. But still the ranks are not moving beyond third page...in fact they moved to 6-7 page in last 2-3 days. Please suggest .. 1. is it due to same name of domain (our brand name) causing the issue. If yes should we go for 302 or 301 redirect to save ourselves from any penalty that our last website may have got. We can not leave that name unattended as our cataloges etc have that website mentioned. i will expect a scientific reply here not gut feeling please. 2. Is it to do with .org domain extension that it should not be with commercial organizations like us Kindly reply at the earliest Regards Aman
Algorithm Updates | | Aman_1230 -
Should we use brand name of product in URL
Hi all, What is best for SEO. We sell products online. Is it good to mention the brand in the product detail page URL key if (part of) the brand is also in the home url? So our URL is: www.brandXstore.com Is it best to do: www.brandXstore.com/brandX-productA.html of just do: www.brandXstore.com/ProductA.html Thanks for quick answering 😉
Algorithm Updates | | RetailClicks1 -
With regards to SEO is it good or bad to remove all the old events from our website?
Our website sells tickets for various events across the UK, we do have a LOT of old event pages on our website which simply say SOLD OUT. What is the best practice? Should these event pages be removed and a 301 redirect added to redirect to the home page? Or should these pages remain in tact with simply SOLD OUT on the page?
Algorithm Updates | | Alexogilvie0 -
Local SEO-How to handle multiple business at same address
I have a client who shares the same address and suite number with multiple business. What should be done to optimize their website and citations for local SEO? Is this a huge issue? What should we do so our rankings aren't affected. Will changes take a long time to take place? Thanks
Algorithm Updates | | caeevans0 -
Does the use of an underscore in filenames adversely affect SEO
We have had a page which until recently was ranked first or second by Google UK and also worldwide for the term "Snowbee". It is now no longer in the top 50. I ran a page optimization report on the url and had a very good score. The only criticism was that I had used an atypical character in the url. The only unusual character was an underscore "_" We use the underscore in most file names without apparent problems with search engines. In fact they are automatically created in html files by our ecommerce software, and other pages do not seem to have been so adversely affected. Should we discontinue this practice? It will be difficult but I'm sure we can overcome this if this is the reason why Google has marked us down. I attach images of the SEO Report pages 8fDPi.jpg AdLIn.jpg
Algorithm Updates | | FFTCOUK0 -
Singular vs plural SEO
Hi everyone, OK I've been looking at the Google adwords keyword tool and it's thrown some of my On-page SEO into question (everything said here are examples, I haven't used any real life terms or figures). Lets say my page is about "Green Apples", let's say the keyword tool shows that the singular version "Green Apple" gets more searches (as an example). Should I optimize for the singular or the plural? Also lets say my title tag for that page is "Green Apples | Apples Galore UK" would Google/SEOmoz count that as an optimisation for the singular "Green Apple" or do the search engines take the title literally and don't differenciate between singular and plurals? Thanks in advance everyone! Regards, Ash
Algorithm Updates | | AshSEO20112
