Adding Schema and No index tags via GTM
If we were to deploy schema and noindex tags to our website via Google tag manager, would these tags be viewed and respected by other search engines?
Take a look at this post on Moz - https://cloudz.click/blog/seo-changes-using-google-tag-manager. Also, take a look at https://productforums.google.com/forum/#!topic/tag-manager/Ilxks3tQKrg. Personally, I wouldn't recommend doing this via GTM. Noindex and Schema specially. They are both important for SEO and are better off done via the CMS.
Sudden Indexation of "Index of /wp-content/uploads/"
Hi all, I have suddenly noticed a massive jump in indexed pages. After performing a "site:" search, it was revealed that the sudden jump was due to the indexation of many pages beginning with the serp title "Index of /wp-content/uploads/" for many uploaded pieces of content & plugins. This has appeared approximately one month after switching to https. I have also noticed a decline in Bing rankings. Does anyone know what is causing/how to fix this? To be clear, these pages are **not **normal /wp-content/uploads/ but rather "index of" pages, being included in Google. Thank you.
Technical SEO | | Tom3_150 -
Size of image for article Schema
Hi, I implemented schema markup for an article and all tested fine and I can see it being fired in preview mode of Google Tag Manager. But when I run the URL which has it applied through Google Structured Testing tool it is not appearing. I have now read that the image needs to be a certain size. For AMP articles this appears to be 12oo pixels wide http://www.thesempost.com/google-changes-image-size-requirements-amp-articles/ But what about non-AMP articles? Does it need to be that big too?
Technical SEO | | AL123al0 -
Indexing product attributes in sitemap
Hey Mozzers! I'm battling a few questions about the sitemap for my ecommerce store. Could you help me out? Is it necessary to include your product attributes in the sitemap? I'm not sure why it would matter to have a sitemap that lists everything in the color cherry. Also, if the attributes were included in the sitemap, would that count as duplicate content for the same products to show up in multiple attributes? Is there any benefit to submitting the sitemaps individually? For example, submitting /product-sitemap.xml, /product_brand-sitemap.xml versus just /sitemap.xml? Any other best practices for managing my ecommerce sitemap, or great resources, would be very helpful. Thank you! a1vUz
Technical SEO | | localwork0 -
Multiple H1 tags in Squarespace
Hi. I'm using Squarespace, and I've noticed they assign the page title and site title h1 tag status. So if I add an on-page h1 tag, that's three in total. I've seen what Matt Cutts said about multiple h1 tags being acceptable (although that video was back in 2009 and a lot has changed since then). But I'm still a little concerned that this is perhaps not the best way of structuring for SEO. Could anyone offer me any advice? Thanks.
Technical SEO | | The_Word_Department0 -
Schema.org how long does it take?
Since 5 days ago I changed my html template in my ecommerce to comply with schema.org for products. How long does it take to be seen on google, our keyword 4700DN, its one that appears in the top 10 results, but it still doesnt show it with schema.org (price+starts+ratings) What should I do? http://www.google.com/webmasters/tools/richsnippets?view=cse&url=http%3A%2F%2Fwww.theprinterdepo.com%2Fhp-color-laser-4700dn-printer-q7493a
Technical SEO | | levalencia10 -
Where to put Schema On Page
What part of my page should I put Schema data? Header? Footer? Also All pages? or just home page?
Technical SEO | | bozzie3114 -
Header Tags
Ok so I am writing different pages and the first heading is an H3 just because I wanted to it be a certain size. Then as you see the content, I have an H1 tag. Example page: http://www.oxfordmshomes.net/condos/acadia-court-Oxford-MS you can see that "Acadia First" is the first thing you see on the page and it uses an H3 element. Long story short, my hierarchy is wrong. Does this have any negative effect on my SEO efforts?
Technical SEO | | blake-766240 -
Why google index my IP URL
hi guys, a question please. if site:112.65.247.14 , you can see google index our website IP address, this could duplicate with our darwinmarketing.com content pages. i am not quite sure why google index my IP pages while index domain pages, i understand this could because of backlink, internal link and etc, but i don't see obvious issues there, also i have submit request to google team to remove ip address index, but seems no luck. Please do you have any other suggestion on this? i was trying to do change of address setting in Google Webmaster Tools, but didn't allow as it said "Restricted to root level domains only", any ideas? Thank you! boson
Technical SEO | | DarwinChinaSEO0
