How to fix duplicate content for homepage and index.html
I know this probably gets asked quite a lot but I haven't found a recent post about this in 2018 on Moz Q&A, so I thought I would check in and see what the best route/solution for this issue might be. I'm always really worried about making any (potentially bad/wrong) changes to the site, as it's my livelihood, so I'm hoping someone can point me in the right direction.
Moz, SEMRush and several other SEO tools are all reporting that I have duplicate content for my homepage and index.html (same identical page).
According to Moz, my homepage (without index.html) has PA 29 and index.html has PA 15. They are both showing Status 200. I read that you can either do a 301 redirect or add rel=canonical
I currently have a 301 setup for my http to https page and don't have any rel=canonical added to the site/page. What is the best and safest way to get rid of duplicate content and merge the my non index and index.html homepages together these days? I read that both 301 and canonical pass on link juice but I don't know what the best route for me is given what I said above.
Thank you for reading, any input is greatly appreciated!
OK, Paul, I hear what you are saying. It's a very open and obvious diss.
I'm not sure what you are saying makes any difference to the argument that the canonical way here is not the way to go. I was explaining in the simplest way, I would not want, and I'm sure you would not want either, a live page like this - the home page, live and canonicalised.
(It's a given that the canonical works like a 301, passing link juice to the preferred version.)
So thanks but it makes no difference - delete & 301 every time.
Google is heightening its distrust of canonicals - the new Seach Console tool reveals which pages are the preferred canonical and it's something of a surprise to SEOs!
If you feel like playing top trumps again then why not PM me? - it's so much better and the uninitiated do not need to see it!
Cheers Nigel
A proper canonical tag does a lot more than "just be telling Google not to rank it" When used properly (i.e. pages that truly do contain the same content), the canonicalised page passes its ranking signals back to the canonical source.
I agree with Kristina - while a 301 would be preferable (it's a directive, while canonical tags are taken as suggestions), a canonical tag would be vastly better than not doing anything about the issue. At least until the dev can get the problem with the 301-redirect properly resolved.
It's best practice to redirect, but if that's not an option, the canonical route should help the problem a lot! You'll probably lose some link equity with this route, but it should clear up duplicate content issues from Google's side.
Hi Dre
If you just do a canonical then the page will still be live, you will just be telling Google not to rank it. Best practice is to remove it all together and 301. It is bad practice having more than one version of your home page, (any page) live!
Regards Nigel
Thank you so much for all the responses. So it sounds like 301 redirect through htaccess is the way to go. What is the difference between using the 301 through htaccess vs using rel=canonical in my case? Does the 301 provide better link juice vs rel=canonical or is canonical just not applicable in this case? Thanks for all the replies and helpful suggestions again!
EDIT: I spoke to my developer (who is hosting and maintaining my site now).. he said he tried to do 301 through htaccess but it seems to be crashing the site (and trust me he is very good at what he does). Part of the problem is that my site is VERY old (originally build about 10 years ago and NOT updated once since).. he has been slowly updating and cleaning up the site slowly and he will try to figure out why the 301 is crashing the site and not working but in the mean time how safe is it to use rel=canonical instead of a 301?
Thanks again!
Hi dre
Your site really shouldn't be generating an index.html in the first place but if it is you must make sure that there is a 301 in the htaccess file sending all traffic to the single homepage URL as Lynn correctly points out this will be a permanent redirect.
It is very simple to do. Both versions are treated as separate pages (as http and https) so you are essentially showing a duplicate site to Google so your rankings will be terrible until you change.
Regards Nigel
Hello there,
You can use .htaccess URL rewrite to remove all the .html from your URL, here's the rewrite rules.
RewriteEngine On
RewriteRule ^index.html$ / [R=301,L]
RewriteRule ^(.*)/index.html$ /$1/ [R=301,L]Once you added this rules you should also fix all your internal links make sure they link to the URL without .html
Hope this helps,
Joseph Yap
"I currently have a 301 setup for my http to https page" - great! Also, you should check if your inner pages redirecting from HTTP-versions to HTTPS too.
index.html should redirect to the homepage main version with 301 Permanent Redirect.
Google consider HTTP and HTTPS as two separate protocols. Since the contents are same on both versions, google bots consider it as duplicate content. Adding a canonical URL will solve this problem. If you have any doubts, feel free to ask.
Duplicate content with tagging and categories
Hello, Moz is showing that a site has duplicate content - which appears to be because of tags and categories. It is a relatively new site, with only a few blog publications so far. This means that the same articles are displayed under a number of different tags and categories... Is this something I should worry about, or just wait until I have more content? The 'tag' and 'category' pages are not really pages I would expect or aim for anyone to find in google results anyway. Would be glad to here any advice / opinions on this Thanks!
On-Page Optimization | | wearehappymedia1 -
How does Indeed.com make it to the top of every single search despite of having aggregated content or duplicate content
How does Indeed.com make it to the top of every single search despite of having duplicate content. I mean somewhere google says they will prefer original content & will give preference to them who have original content but this statement contradict when I see Indeed.com as they aggregate content from other sites but still rank higher than original content provider side. How does Indeed.com make it to the top of every single search despite of having aggregated content or duplicate content
On-Page Optimization | | vivekrathore0 -
Duplicate page titles and Content in Woocommerce
Hi Guys, I'm new to Moz and really liking it so far!
On-Page Optimization | | jeeyer
I run a eCommerce site on Wordpress + WooCommerce and ofcourse use Yoast for SEO optimalisation I've got a question about my first Crawl report which showed over 600 issues! 😐 I've read that this is something that happens more often (http://cloudz.click/blog/setup-wordpress-for-seo-success). Most of them are categorized under:
1. Duplicate Page Titles or;
2. Duplicate Page Content. Duplicate Page Titles:
These are almost only: product category pages and product tags. Is this problem beeing solved by giving them the right SEO SERP? I see that a lot of categories don't have a proper SEO SERP set up in yoast! Do I need to add this to clear this issue, or do I need to change the actual Title? And how about the Product tags? Another point (bit more off-topic) I've read here: http://cloudz.click/community/q/yoast-seo-plugin-to-index-or-not-to-index-categories that it's advised to noindex/follow Categories and Tags but isn't that a wierd idea to do for a eCommerce site?! Duplicate Page Content:
Same goes here almost only Product Categories and product tags that are displayed as duplicate Page content! When I check the results I can click on a blue button for example "+ 17 duplicates" and that shows me (in this case 17 URLS) but they are not related to the fist in any way so not sure where to start here? Thanks for taking the time to help out!
Joost0 -
Duplicate Content - Blog Rewriting
I have a client who has requested a rewrite of 250 blog articles for his IT company. The blogs are dispersed on a variety of platforms: his own website's blog, a business innovation website, and an IT website. He wants to have each article optimised with keyword phrases and then posted onto his new website thrice weekly. All of this is in an effort to attract some potential customers to his new site and also to establish his company as a leader in its field. To what extent would I need to rewrite each article so as to avoid duplicating the content? Would there even be an issue if I did not rewrite the articles and merely optimised them with keywords? Would the articles need to be completely taken by all current publishers? Any advice would be greatly appreciated.
On-Page Optimization | | StoryScout0 -
Duplicate Content from on Competitor's site?
I've recently discovered large blocks of content on a competitors site that has been copy and pasted from a client's site. From what I know, this will only hurt the competitor and not my client since my guy was the original. Is this true? Is there any risk to my client? Should we take action? Dino
On-Page Optimization | | Dino640 -
Does schema.org assist with duplicate content concerns
The issue of duplicate content has been well documented and there are lots of articles suggesting to noindex archive pages in WordPress powered sites. Schema.org allows us to mark-up our content, including marking a components URL. So my question simply, is no-indexing archive (category/tag) pages still relevant when considering duplicate content? These pages are in essence a list of articles, which can be marked as an article or blog posting, with the url of the main article and all the other cool stuff the scheme gives us. Surely Google et al are smart enough to recognise these article listings as gateways to the main content, therefore removing duplicate content concerns. Of course, whether or not doing this is a good idea will be subjective and based on individual circumstances - I'm just interested in whether or not the search engines can handle this appropriately.
On-Page Optimization | | MarkCA0 -
Percentage of duplicate content allowable
Can you have ANY duplicate content on a page or will the page get penalized by Google? For example if you used a paragraph of Wikipedia content for a definition/description of a medical term, but wrapped it in unique content is that OK or will that land you in the Google / Panda doghouse? If some level of duplicate content is allowable, is there a general rule of thumb ratio unique-to-duplicate content? thanks!
On-Page Optimization | | sportstvjobs0 -
Quick and easy Joomla 1.5 Duplicate content fix?
www.massduitrialalwyers.com has a TON of duplicate content based on the way joomla 1.5 uses articles. Do you have a tried and true method to eliminate (automated would be preferred) the issues>? if not, might you suggest a plug in that takes care of the rel canonical?
On-Page Optimization | | Gaveltek-173238
Cheers0
