Translating meta tags using WPML and AIO SEO
Having a heck of a time finding info on this one...
We're working on a multilingual website which uses WPML. I've used the All in One SEO plugin to customize meta data (title, description, etc). These strings do not appear in the list of translations in WPML.
Does anyone have any experience with this setup? How do you enable WPML to translate meta data set via the AIO plugin?
Update here.
Long story short, you need to upgrade to All-in-One SEO Pack Pro to allow translation of meta fields.
Our implementation is somewhat complicated, with the aim being to make the workflow for our translators as easy as possible. We use a self-hosted server running Weblate to manage string translation (both for our websites and for our product). On the Wordpress site we use a customised version of the WPML plugin.
Things got complicated when exporting strings from WPML and importing to Weblate – talking to the sys admin who implemented it, the meta fields from All-in-One SEO were even trickier to get working.
In any case, all working now
Keep any eye out for our site update coming soon here: https://vivaldi.com
If anyone out there runs into this issue and needs details feel free to get in touch.
Still haven't resolved this one (unfortunately) - no response from AIO or WPML.
I'll make note to update here once I have some answers!
So Jon have you found the solution to the problem? If yes maybe you can mark this as answered? Thnks
Checking it out.
Will leave a comment in this thread once I hear back in case anyone is curious.
We're using the free version at the moment. Waiting for a response from AIO & WPML to confirm, but it's looking like this is a pro feature.
Thanks for your help in any case!
Hmm that could be, but you should confirm with AIO and WPML support
Hi Jon
Do you have the pro version of AIO? Apparently, if you do then the correct translation is sent to each of the language versions of a page or post.
https://wpml.org/documentation/plugins-compatibility/translating-all-in-one-seo/
Maybe it doesn't work with teh unpaid version?
Whatever you need the meta titles and descriptions to be in the correct language - little point having them in English.
Regards Nigel
Thanks! I did see that page. The confusing thing is that the strings shown in their screenshots don't display in our implementation. The custom fields for 'aioseo' aren't listed as available to translate.
Could this be a feature of their Pro version that they don't explicitly advertise...?
Thanks for the reply
We're all set re: hreflang tags for the pages. My concern is that I'm using the AIO plugin to customize the meta title & description. So, although the correct version of the page will be listed in SERPs (e.g example.com/fr/ for French users), the link preview will still display the English meta info.
Am I missing something here?
Jon
Hi Jon
I am with Joseph here - I use Yoast as well.
Just make sure that if you have multi-language version fo pages that you specify the hreflang tag on each.
https://cloudz.click/learn/seo/hreflang-tag
Regards
Nigel
Hello there,
I am using Yoast and there's the option to have translated version of metas with Yoast, I have never use AIO, but I did find this document from WPML maybe you can check it out and see if it answered your question?
Regards,
Joseph Yap
Is using a subheading to introduce a section before the main heading bad for SEO?
I have noticed a popular trend in web design which involves sections of content being started with what looks to be smaller sub heading something like <h3>, <h4> or <h5> and then followed by a bigger heading <h2>. My question is, what is the best way to deal with this visual structure and will having a structure like this hurt your SEO? <h5>Contact Us</h5> <h2>Get started with your next project in minutes!<h2> <p>Some text here ...</p> Here are some examples where the header structure is similar to above (smaller before bigger): https://www.snappr.com/ https://form.taxi/ https://fluz.app/ If that structure is bad for SEO, then it seems like a simple solution is to make it purely visual, mimicking a sub header with styling on a span or paragraph like these sites do: https://www.andrejilderda.nl/ https://nightwatch.io/ https://www.swingvy.com/ https://www.figma.com/ My only concern with that approach is because your section sub heading is no longer an actual header you will miss out on ranking important and relevant keyword information for that section. Is this correct something to be worried about? There is one last solution I stumbled upon that involves using headings for both but in reverse hierarchy so a <h3> is first but styled to be smaller, followed by a visually bigger <h4> which provides the addition context. https://avocode.com/ Anyone have thoughts, expertise or resources on the matter?
Intermediate & Advanced SEO | | si.analytics0 -
The main navigation is using JS, will this have a negative impact on SEO?
Hi mozzers, We just redesigned our homepage and discovered that our main nav is using JS and when disabling JS, no main nav links was showing up. Is this still considered bad practice for SEO? https://cl.ly/14ccf2509478 thanks
Intermediate & Advanced SEO | | Ty19861 -
Move to new domain using Canonical Tag
At the moment, I am moving from olddomain.com (niche site) to the newdomain.com (multi-niche site). Due to some reasons, I do not want to use 301 right now and planning to use the canonical pointing to the new domain instead. Would Google rank the new site instead of the old site? From what I have learnt, the canonical tag lets Google know that which is the main source of the contents. Thank you very much!
Intermediate & Advanced SEO | | india-morocco0 -
Better to use specific cities or counties for SEO geographics?
Hello SEO experts! We are encountering a difficult situation at our marketing firm with a client who wants to optimize her site for keyworks + counties, as she doesn't want to be restricted to one specific city. We have suggested alternate solutions like location pages, utilization of H2's, etc, however, she wants to know the effectiveness of using a specific city (ie: Winona, MN) vs a county (ie: Winona County, MN) for SEO purposes. The research I have conducted thus far hasn't gotten me very far, basically I'm seeing that it all comes back to what people search for (cleaning services in Winona, MN vs. cleaning services in Winona County, MN). Does anyone have any insight into this issue?
Intermediate & Advanced SEO | | MLTGroup0 -
Using href lang tag for multi-regional targeting on the same page
Hi, I have the site au.example.com and I ranked on google AustraliaI would like to be ranked also in Google New Zeland for the same page (au.example.com) Because they are geographically & culturally close Can I place href lang tag for both countries and present the same page The code should look like: OR should i have create a different page for New Zealand (for eample: http://au.example.com/EN-NZ) And the code will look like: What will work better or there is other solution? Hope I’m clear.. Thanks!
Intermediate & Advanced SEO | | Kung_fu_Panda0 -
Meta tags - are they case sensitive?
I just ran the wordtracker tool and noticed something interesting. The tool didn't pick up our meta description. It's strange as our meta descriptions appear in organic search results and Moz never reported missing meta descriptions.After reviewing other pages, I noticed our meta description tag is written as the following: name="Description" content=" I never thought about this, but are meta tags case sensitive? Should it be written as: name="description" content=" Thoughts?
Intermediate & Advanced SEO | | Bio-RadAbs0 -
Should I remove Meta Keywords tags?
Hi, Do you recommend removing Meta Keywords or is there "nothing to lose" with having them? Thanks
Intermediate & Advanced SEO | | BeytzNet0 -
If you have an unlimited SEO budget, what would you do?
Here's a bit of background information: I've achieved the targets and is now being offered what is essentially an unlimited budget. I have a nice list of ideas but thought I would the brilliant people here at the SEOMOZ community what they would do. So as to promote as much response as possible, I'm going to keep my list to myself for now. And by "SEO", I mean I can do things like content strategy, blogging, infographics, etc. Shoot away!
Intermediate & Advanced SEO | | andrep0
