Intermittent 404 - What causes them and how to fix?
Hi!
I'm working on a client site at the moment and I've discovered a couple of pages that are 404ing but producing a 200 OK response.
However, I have checked these URLs again and some are now producing a 404 Error response. No changes have been made (that I'm aware of) so it appears that the URLs are returning both 200 OK and 404 Error responses intermittently.
Any ideas what could cause this and the best solution?
Hi Daniel,
That does seem very odd!
There can be various different things at play here in my experience:
- Publishing and un-publishing in the CMS - Sometimes clients and CMS users will switch the page publish status around which can make it difficult to keep track of whether the page exists or not
- Removal of redirects - Much the same as above, there's the possibility that someone is adding/removing redirects. This could also be something to do with the removal of the server level redirects file, be that htaccess or IIS.
- Crawling tool issue - If you're using a crawling tool (especially if doing so with JS rendering active), sometimes this can put a lot of pressure on the server and it can spit out the occasional error where there actually isn't one
It could also be a problem with how you're handing hard 404 errors vs soft 404s - i.e. actual not founds vs pages that don't function but the server is under the impression that they're fine.
Best of luck!
Sean
What could cause Google to not honor canonical URLs?
I have a strange situation on a website, when I do a Google query of site:example.com all the top indexed results appear to be queries that users can perform on the website. So any random term the user searches for on the website for some reason is causing the search result page to get indexed - like example.com/search/query/random-keywords However, the search results page has a canonical tag on it that points to example.com/search, but that doesn't seem to be doing anything. Any thoughts or ideas why this could be happening?
Technical SEO | | IrvCo_Interactive0 -
Does using a canonical with ?utm_source=gmb cause any issues?
All of our URLs in Google My Business are tagged with ?utm_source=gmb. This way when people click on it within a Google Map listing, knowledge graph, etc we know it came from there. I'm assuming using a canonical on all ?_utm_source _pages (we have others, including some in the index) won't cause any problems with this, correct? Since they're not technically traditional organic SERPs? Dumb question I know, but better safe than sorry. Thanks.
Technical SEO | | Alces1 -
Cookies disabled pointing to a 404 page
Hi mozzers, I am running an audit and disabled cookies on our homepage for testing purposes, this pointed to a 404 http response? I tried on other pages and they were loading correctly. I assume this is not normal? Why this is happening? and could this harm the site's SEO? Thanks!
Technical SEO | | Taysir0 -
Find all external 404 errors/links?
Hi All, We have recently discovered a site was linking to our site but it was linking to an incorrect url, resulting in a 404 error. We had only found this by pure chance and wondered if there was a tool out there that will tell us when a site is linking to an incorrect url on our site? Thanks 🙂
Technical SEO | | O2C0 -
Wordpress categories causing too many links/duplicate content?
I've just added categories to my wordpress site and some of the posts show in several of the categories. Will this cause me duplicate content problems as I want the category pages to be indexed? Also as I add more categories I'm creating more links on the page. They can't be seen to the user as I have a plugin that creates drop down categories. When I go to 'view source' though all the links are there so google will see lots of links. How can I fix the too many links problem? And should I worry about duplicate content issue?
Technical SEO | | SamCUK1 -
404 Errors After Site Migration
Hello - I'm working on a website selling fashion accessories. The site just went through a site migration from Yahoo! to Big Commerce. Now we have a high level of warnings and errors from the crawl. Few are mentioning sites I never seen before on the Yahoo! platform. I also notice that the pages crawled has doubled. How can I fix or did I do something wrong with migration? I was running the website with minimal errors and now overwhelmed with errors all the error updates. If I can get some assistance on what could be wrong, I would greatly appreciate. Thanks.
Technical SEO | | ShopChameleon0 -
How do I fix the h1 tag?
No More Than One H1 Tag Easy fix <dl> <dt>Number of H1s</dt> <dd>2</dd> <dt>Explanation</dt> <dd>Best practices for both SEO and accessibility require only a single H1 tag. The H1 is meant to be the page's headline, and thus, multiple H1s are confusing. Consider employing H2, H3 or CSS styles to achieve the same results with text visualization.</dd> <dt>Recommendation</dt> <dd>Remove multiple instances of the H1 tag, so that only one exists on the page.</dd> <dd>I get this error yet it does not tell me how to fix it. I'm not even sure what the H1 tag is?
Technical SEO | | 678648631264
</dd> </dl>0 -
No Search Results Found - Should this return status code 404?
A question came up today on how to correctly serve the right status code on pages where no search results are found. I did a couple searches on some major eccomerce and news sites and they were ALL serving status code 200 for No Search Results Found http://www.zappos.com/dsfasdgasdgadsg http://www.amazon.com/s/ref=nb_sb_noss?url=search-alias%3Daps&field-keywords=sdafasdklgjasdklgjsjdjkl http://www.ebay.com/sch/i.html?_trksid=p5197.m570.l1313&_nkw=dfjakljgdkslagklasd&_sacat=0 http://www.cnn.com/search/?query=sdgadgdsagas&x=0&y=0&primaryType=mixed&sortBy=date&intl=false http://www.seomoz.org/pages/search_results?q=sdagasdgasdgasg I thought I read somewhere were it was recommended to serve a status code 404 on these types of pages. Based on what I found above, all sites were serving a 200, so it appears this may not be the best practice. Any thoughts?
Technical SEO | | WEB-IRS0
