When should a variant be a variant and when should it be a separate product from an SEO POV?
Hi all,
We are looking at changing our current e-commerce store to a new platform and in doing so thinking of making some changes to how we list products in sub-categories. We have seen related questions asking about splitting a single product into multiple products to rank for different terms, but we are wondering about combining multiple products into a single product page? The examples we have seen have been about fashion items with variants of colour and size. However, the products we sell have variances that change the appearance, dimensions and technical specification, so we would like to ask the MOZ community if combining products with these variances would still be deemed good practice?
We sell wood burning stoves and a good example of a product that we are considering combining is the Scan 85 stove, which is available in eight different configurations: 85-1, 85-2, 85-3 etc. Scan themselves refer to each version as a separate product and they are bought, stocked and sold as separate products. Wood burning stoves like this typically have a firebox in the centre and then design options that can change the top, side, base, door, colour and fuel. In this example, the firebox is the Scan 85 and the variation is the last number, each of which corresponds to a different design option changing both the appearance and dimensions (see attached image).
We have them listed as eight different products on our current site, one for each version. Primarily because each option has its own name (albeit 1-digit difference) which when we created the pages we thought that more pages would present us with more ranking opportunity. However, we have since learnt that because these eight pages are all so similar and it is difficult to write unique content about each product (with the 85-1 and 85-2 the only difference between the models are the black trim on the 85-1 and the silver trim on 85-2). Especially as when talking about the firebox itself, how well the fire burns, how controllable it is etc, will be the same for all versions. Likewise, earning backlinks to eight separate pages is also very difficult.
Exploring this lead, us to the question, when is a variant a variant and when is it a separate product? Are there hard and fast rules for what defines variants and products? Or does it simply vary from industry to industry product to product, and if so should we be looking at it from a UX or SEO POV, when making that decision?
Our hope is that if we combine these eight products into a single high-quality page, it will present us with a greater ranking opportunity for that one page over eight individual pages. We also hope that in doing so will allow us to create a more intuitive UX on a single page with a unique description, more reviews focused on one page and an explanation of the options available, all of which should lead to more conversions. Finally, by creating a better UX and unique detailed description we hope that there is a higher chance of us earning product level backlinks then we do with eight lower quality pages.
One of the issues in creating a single product page for all the variants is the sub-category/results pages, as we would be removing eight simple products and replacing them with one complex product. We have questions over how this would work from a filter/facet level whereby when you apply a filter there is an expectation that the image shown will match the criteria, so if we filter for stoves with a silver trim for example, there is an expectation to only see stoves that have a silver trim in the results. When you have separate product pages you have separate listings which makes this easier to only bring back the models matching the criteria. However, when you have a single page this is more complex as you will need a default image for non-filtered results and then the ability to assign an image to lots of different attributes so that the correct image is always shown that matches the criteria selected. All of which we have been assured is do-able but adds an extra level of complexity to the process from an admin side.
The alternative to doing this would be to create eight simple/child products and link them to one configurable/parent product. We could them list the simple products into the results pages and have them all linking back to the main configurable product which could load with the options of the simple product that was selected. From an SEO POV this brings in some more work, redirecting each page to the parent, but ultimately this could provide a better UX and might be the better solution. Has anyone got any experience in doing either of these options before?
Both options above with affect the number of products we have available, so does the number of products in a sub-category effect the ability for that category page to rank? We currently have around 500 products in our wood burning stoves category, with perhaps an additional 300 to add. If we go down the combining into a single product page route this will reduce the number of products by around a third. If we keep all the simple/child products, then this will stay around the same.
So, have we missed something obvious? Is there a glaring issue that we have overlooked from an SEO point of view as well as from the customer experience? We would appreciate your thoughts on this.
Thanks, Reece
Appreciate the thoroughness of the response Ed, thanks for taking the time.
I'd say you're way to close to your products here and need to start asking your customers. For example, the stoves in the picture - to me - are all the same stove.
I have the same problem with dental products. Are 'All on Four Implant retained Dentures' the same 'topic' in the eyes of google as 'Dental Implants' and then are they going to internally compete with my dentures and Implants pages? It can be a nightmare and the way around it is with testing and also taking a more global view of things and taking a step back from the technicalities.
People don't want a 'black trim 85/1 wood burner. They want to feel warm and have a beautiful addition to their home that makes them feel aspirational or romantic or happy. This is what you sell. Not technical specifications. People want simplicity not complexity and they want benefits not features. So bundle it all up into one page with some really evocative and emotionally charged sales copy about how having a stove like this is going to change their hoes and make their lives better.
From a technical perspective there's going to be a hopeless amount of internal competition that's going to be depressing your rankings like crazy. So experiment with bringing the pages all together and having variations available on page.
I got some headphones the other day and there were about a hundred variations of colour, size, type of ear bud and it was all just available to me with dropdown menus that brought up an image of what i'd chosen. People don't want to have to navigate around from page to page to page to find what they want. They want to get the general picture and then decide on the specifications later. If I listed everything we did at our dental practice do you think that would make patients want to buy?
How about a root canal with a .0012/in burr and chlorhexadine irrigation? High-speed or low-speed handpiece? Would you like a rubber-dam with that or take your chances with a file in the windpipe?? Perhaps you'd like me to irrigate with hypochlorite instead?
OK i'm being silly but this is actually kind of like what you're doing here.
Keep it simple. Merge the pages together and watch your rankings creep up for all your high traffic high purchase intent keywords. This (as you say) helps with links and also helps users stay on one page for longer and it's this implicit user feedback like time on site, scroll depth and bounce rate that google is looking at.
When customers get lost and bounce this also MASSIVELY depresses your results. i see it with my visitor recording software. and it's a very strongly correlating ranking factor.
I'm not ecommerce but i've had HUGE success figuring out which topics google considers to be topics and which are separate and the only way you can find this out is with testing it. For words and search terms it's easy. If you type in "wood burner cost" and "wood fireplace price" comes up in bold in someone's meta description then google considers them to be the same. So price is the same as cost etc. Sometimes that can be a good place to start. Also do a search using site:www.yoursite.com wood burner and see how many pages come up. If it's hundreds then you've got internal competition problems. Use more and more granular searches like this to determine if you're getting stacking or competition or even cannibalisation in the SERPS (which is getting filtered altogether)
Hope this helps!
# Tag - opacity and SEO impact
Technical SEO | | Tiffany_Barn
I have a query animation 'fade-in-up' on my website: tiffanybarnard.com which moves the H1 tag slightly and fades it in from zero opacity to 1. Will this affect the SEO value of the H1 tag?
Thank you!0 -
Breadcrumbs on Mobile How important are they for SEO?
Due to Poor unsightly look of breadcrumbs and the space it takes up above the fold we only employ breadcrumbs on our desktop version. Breadcrumbs are hidden from view on mobile version. However as mobile first indexing is now in play what technical SEO impacts will this have? one thing that comes to mind is crawling deeper pages where breadcrumbs made them accessible in less than 3 link clicks? But i am unsure now of the impacts of not having breadcrumbs visible for mobile version of our site.
Technical SEO | | oceanstorm0 -
Is Removing Breadcrumbs Detrimental for SEO?
We have full navigational breadcrumbs on our site for the menu and the brand menu. i.e. Home > Clothing > Jackets Brand > Brand Name > Brand Jackets There's been talk of removing this and having it like Chico's does, where on item pages they just have a link at the top to previous category (i.e. you're on a shirt product page and at the top it says "Back to Tops" instead of listing Home > Clothing > Tops) Is doing something like this detrimental to SEO? From what I've read Breadcrumbs are for user experience but I just want to be sure.
Technical SEO | | AliMac260 -
Express js and SEO?
Hi fellow Mozzers, I have been tasked with providing some SEO recommendations for a website that is to be built using express.js and Angular. I wondered whether anyone has had any experience in such a framework? On checking a website built in this and viewing as a GoogleBot etc using the following tools it appears as though most of the content is invisible: http://www.webconfs.com/search-engine-spider-simulator.php http://www.browseo.net/ Obviously this is a huge issue and wonder if there are any workarounds, or reccomendations to assist (even if means moving away from this - would love to hear about it)
Technical SEO | | musthavemarketing2 -
Loading images below the fold? Impact on SEO
I got this from my developers. Does anyone know if this will be a SEO issue? We hope to lazy-load images below the fold where possible, to increase render speed - are you aware of any potential issues with this approach from an SEO point of view?
Technical SEO | | KatherineWatierOng1 -
How do you build your pre-sales seo audit
Hello Moz community, I'd like to know if you build "pre-sales seo audit" when selling your services to a prospect. I think the main idea of a pre-sales audit is to show your prospect that you understand his industry (trends & competition) understand the opportunities know the roadblocks on his website If so, i'd be interested in discussing the information you put into your pre-sales audit and how you organise it. If you know ressources i should read as regards to mini seo audit / pre-sales seo audit just paste the link 🙂 Thanks for your answers
Technical SEO | | Sindicic_Alexis0 -
Product Pages Outranking Category Pages
Hi, We are noticing an issue where some product pages are outranking our relevant category pages for certain keywords. For a made up example, a "heavy duty widgets" product page might rank for the keyword phrase Heavy Duty Widgets, instead of our Heavy Duty Widgets category page appearing in the SERPs. We've noticed this happening primarily in cases where the name of the product page contains an at least partial match for the desired keyword phrase we want the category page to rank for. However, we've also found isolated cases where the specified keyword points to a completely irrelevent pages instead of the relevant category page. Has anyone encountered a similar issue before, or have any ideas as to what may cause this to happen? Let me know if more clarification of the question is needed. Thanks!
Technical SEO | | ShawnHerrick0 -
Restaurant menu SEO: PDF or HTML?
Is it better to use a PDF or hard code restaurant menus (or any document for that matter) in HTML? I want the content to be indexed and thought PDF was the way to go for several reasons, but I wanted to get confirmation on this before I move forward.
Technical SEO | | BostonWright0
