Hreflang tags and canonical tags - might be causing indexing and duplicate content issues
Let's say I have a site located at https://www.example.com, and also have subdirectories setup for different languages. For example:
https://www.example.com/es_ES/
https://www.example.com/fr_FR/
https://www.example.com/it_IT/
My Spanish version currently has the following hreflang tags and canonical tag implemented:
My robots.txt file is blocking all of my language subdirectories. For example:
User-agent:*
Disallow: /es_ES/
Disallow: /fr_FR/
Disallow: /it_IT/
This setup doesn't seem right. I don't think I should be blocking the language-specific subdirectories via robots.txt
What are your thoughts?
Does my hreflang tag and canonical tag implementation look correct to you? Should I be doing this differently?
I would greatly appreciate your feedback and/or suggestions.
Hi... I'm sorry to tell you that the answer offered by Gaston is not totally correct.
So, in your Spanish page you have these hreflang and canonical annotations:
This is not correct because you are not adding also the self-referential hreflang annotation
Google is very precise about this, and it states its need in the help pages as well in many Googlers tweets and webmaster office hangouts.
The rel="canonical" is correct. Remember that the self-referential and the alternative href URLs must always be canonicals.
Finally, regarding the subfolders blocked via robots.txt, yes! that's totally incorrect:
if you're blocking Googlebot from accessing the Spanish, French and Italian subfolders, then Googlebot won't be able to parse the code of their pages, hence it won't be able to see also the hreflang annotations... with obvious erroneous consequences.
that's corect.
Yes. example.com/en-US/ redirects 301 to example.com
So, when referencing that version in hreflang will it look like this?
Is this correct?
So, every page of example.com/en-US/ redirects 301 to example.com/ ?
If that's the case, then there is no reason in having that folder (/en-US/), just when configuring Hreflang for en-US use the URL without that folder
What do you mean by "exactly the same then there should not be 2 sites"?
My https://www.example.com/en-US/ 301 redirects to https://www.example.com
Thoughts?
Yeap, those implementations are correct.
in order to avoid duplicate content between different language/countries websites, in each page that is present on each site, there should be their corresponding hreflang tag.
In your case:
And for a sample page: https://www.smarttechMKT.com/es-ES/gastonriera-espanolNOTE, in the case that site.com and site.com/en-us/ are exactly the same then there should not be 2 sites. Just the one without the folder and hreflang tag with en-US should point to that
Hope it helps.
Best luck.
GR -
Thank you for the response, Gaston! I really appreciate it.
So you are certain that my hreflang and canonical tags are implemented correctly? For example, my Spanish version (https://www.example.com/es_ES/
Is this implementation correct?
Also, will I have any duplicate content issues with these different language versions?
Hello there,
Watch out your question, there is a site there. If its your clients, edit it.
Canonical and hreflang seems OK.
Blocking other languages/countries is wrong. There you are allowing google to see ONLY the us version.For further reading, take a look at these articles:
Hreflang:
Multi-regional and multilingual sites - Google Search Console
International checklist - Moz Blog
Using the correct hreglang tag - Moz Blog
Guide to international website expansion - Moz Blog
Tool for checking hreflang anotations - Moz Blog Canonicals:
SEO Best Practices for Canonical URLs + the Rel=Canonical Tag - Whiteboard Friday Consolidate duplicate URLs - Google Search Console HelpHope it helps.
Best Luck.
GR.Hope it helps.
Best luck.
GR.
"Duplicate without user-selected canonical” - impact to SERPs
Hello, we are facing some issues on our project and we would like to get some advice. Scenario
International SEO | | Alex_Pisa
We run several websites (www.brandName.com, www.brandName.be, www.brandName.ch, etc..) all in French language . All sites have nearly the same content & structure, only minor text (some headings and phone numbers due to different countries are different). There are many good quality pages, but again they are the same over all domains. Goal
We want local domains (be, ch, fr, etc.) to appear in SERPs and also comply with Google policy of local language variants and/or canonical links. Current solution
Currently we don’t use canonicals, instead we use rel="alternate" hreflang="x-default": <link rel="alternate" hreflang="fr-BE" href="https://www.brandName.be/" /> <link rel="alternate" hreflang="fr-CA" href="https://www.brandName.ca/" /> <link rel="alternate" hreflang="fr-CH" href="https://www.brandName.ch/" /> <link rel="alternate" hreflang="fr-FR" href="https://www.brandName.fr/" /> <link rel="alternate" hreflang="fr-LU" href="https://www.brandName.lu/" /> <link rel="alternate" hreflang="x-default" href="https://www.brandName.com/" /> Issue
After Googlebot crawled the websites we see lot of “Duplicate without user-selected canonical” in Coverage/Excluded report (Google Search Console) for most domains. When we inspect some of those URLs we can see Google has decided that canonical URL points to (example): User-declared canonical: None
Google-selected canonical: …same page, but on a different domain Strange is that even those URLs are on Google and can be found in SERPs. Obviously Google doesn’t know what to make of it. We noticed many websites in the same scenario use a self-referencing approach which is not really “kosher” - we are afraid if we use the same approach we can get penalized by Google. Question: What do you suggest to fix the “Duplicate without user-selected canonical” in our scenario? Any suggestions/ideas appreciated, thanks. Regards.0 -
International SEO setup issues canonical URL
My site is www.grocare.com for one region and in.grocare.com for another region. Both of them have the same content except the currency for particular regions. Someone told me that google will take the content as duplicate and not rank either. I have setup hreflang and targeted different regions for both in the search console. I read many article which say canonical urls need to be setup for international seo sites. But Im not sure how to setup canonical urls and whether they are the right way to go . i just don't want my content deranked. Now i have setup hreflang properly after asking the moz community itself. So im hoping to get some help with this query too. TIA
International SEO | | grocare0 -
Correct Hreflang & Canonical Tags for Multi-Regional Website English Language Only having URL Parameters
Dear friends, We have a multi-regional website in English language only having the country selector on the top of each page and it adds countrycode parameters on each url. Website is built in Magento 1.8 and having 1 store with multiple store views. There is no default store set in Magento as I discussed with developer. Content is same for all the countries and only currency is changed. In navigation there are urls without url parameters but when we change store from any page it add parameters in the url for same page hence there are total 7 URLs. 6 URLs for each page (with country parameters) and 1 master url (without parameters) and making content duplicity. We have implemented hreflang tags on each page with url parameters but for canonical we have implemented master page url as per navigation without url parameters Example on this page. I think this is correct for master page but we should use URL parameters in canonical tags for each counry url too and there should be only 1 canonical tag on each country page url. Currently all the country urls are having master page canoncial tag as per the example. Please correct me if I am wrong and **in this case what has to be done for master page? **as google is indexing the pages without parameters too. We are also using GEOIP redirection for each store with country IP detection and for rest of the countries which are not listed on the website we are redirecting to USA store. Earlier it was 301 but we changed it to 302. Hreflang tags are showing errors in SEMRush due to redirection but in GWT it's OK for some pages it's showing no return tags only. Should I use **x-default tags for hreflang and country selector only on home page like this or should I remove the redirection? **However some of the website like this using redirection but header check tool doesn't show the redirection for this and for our website it shows 302 redirection. Sorry for the long post but looking for your support, please.
International SEO | | spjain810 -
Hreflang for bilingual website in the same region/location
Hi everyone, got a quick question concerning the hreflang tag. I have a website with 2 different language versions targeting to the same region(Reason: The area is bilingual however not everyone speaks the other language fluently) Question:
International SEO | | ennovators
Can I use hreflang in that case like: Many thanks in advance0 -
Is there any reason to get a massive decrease on indexed pages?
Hi, I'm helping on SEO for a big e-commerce in LatAm and one thing we've experienced during the last months is that our search traffic had reduced and the indexed pages had decreased in a terrible way. The site had over 2 Million indexed pages (which was way too much, since we believe that around 10k would be more than enough to hold the over 6K SKUs) but now this number has decreased to less than 3K in less than 2 months. I've also noticed that most of the results in which the site is still appearing are .pdf or .doc files but not actual content on the website. I've checked the following: Robots (there is no block, you can see that on the image as well) Webmaster Tools Penalties Duplicated content I don't know where else to look for. Can anyone help? Thanks in advance! cpLwX1X
International SEO | | mat-relevance0 -
Can multiple hreflang tags point to one URL? International SEO question
Moz, Hi Moz, Can multiple hreflang tags point to a single URL? For example, if I have a Canadian site (www.example.com/ca) that targets French and English speakers can I have the following: or would I use: Any insight would be very helpful and greatly appreciated! Thank you in advance!
International SEO | | DA20131 -
If I redirect based on IP will Google still crawl my international sites if I implement Hreflang
We are setting up several international sites. Ideally, we wouldn't set up any redirects, but if we have to (for merchandising reasons etc) I'd like to assess what the next best option would be. A secondary option could be that we implement the redirects based on IP. However, Google then wouldn't be able to access the content for all the international sites (we're setting up 6 in total) and would only index the .com site. I'm wondering whether the Hreflang annotations would still allow Google to find the International sites? If not, that's a lot of content we are not fully benefiting from. Another option could be that we treat the Googlebot user agent differently, but this would probably be considered as cloaking by the G-Man. If there are any other options, please let me know.
International SEO | | Ben.JD0 -
Showing different content according to different geo-locations on same URL
We would like our website to show different content according to different Geo-locations (but in the same language). For example, if www.mywebsite.com is accessed from the US, it would show text (in English) appealing to North Americans, but, if accessed from Japan, it would show text (also in English) that appeals more to Japanese people. In the Middle East, we would like the website to show different images than those shown in the US and Asia. Our main concern is that we would like to keep the same URL. How will Google index these pages? Will it index the www.mywebsite.com (Japan version) in its Asia archives and the www.mywebsite.com (US version) in its North American archives? Will Google penalise us for showing different content across Geo-locations on the same URL? What if a URL is meant to show content only in Japan? Are there any other issues that we should be looking out for? Kindest Regards L.B.
International SEO | | seoec0
