Primary versus secondary keyword
Can someone give a example of what primary and secondary keywords are and how to implement that in a sentence ?
Thank you,
Hi seoanalytics
I have spent hours trying to help you on this thread and the other two or three you have started! I have patiently answered every question you have asked, in detail. If you still don't understand what I am saying after acres and acres of help and advice then that's it from me.
https://cloudz.click/community/q/sentences-rdf-format
https://cloudz.click/community/q/asking-a-natural-question-in-h-tags
https://cloudz.click/community/q/bolded-words-in-search-results
https://cloudz.click/community/q/user-intent-and-ranking
This comment is simply idiotic, but more than that it is insulting:
"I have more chances of winning the lottery than ranking..."
Please don't bother me again.
Have a good weekend.
Nigel
I am trying but let's be honest I have more chances of winning the lottery than ranking...
It is a matter of what words goes with which word surrounded by other words and only the computer know that, doesn't it ?
In the past I managed to get from 3 rd page to 3 rd position on a requested keyword just by adding 3 lines of text and the reason was just that the words used correlated well with the other words but honestly this was luck.
If someone has a technic that works that isn't luck I can't wait to hear it
I have no idea what Alchemy API is.
No, write your own content with your own researched keywords.
How about I I used alchemy api and use all the keywords of someone ranking 1 st to write my text, could it also work ?
Hi seoanalytics
I think you get the idea. I'm not saying that tablet is a perfect synonym for laptop but I think you do understand what I am saying!
Good luck with it
Regards
Nigel
Thank you for sharing the link about rank brain.
I do understand that it isn't necessary to pepper my content with all the possiblity semantically connected keywords are it won't look natural. However, from what I understand the idea is still to use those semantically connected keyword but naturally.
For example about Laptop chargers if I wrote a sentence like this would ok ? I have used semantically related keyword such as voltage, battrary, tablet and transformer.
"Laptop charger come with different voltages, 110 and 220. Once you have selected the battery that matches the voltage of your tablet you are good to go. If you can't find the correct voltage by a transformer and then plug it in. "
Hi seoanalytics
The whole area of primary and secondary keywords (or Keyphrases) has largely been overtaken by Google's new Rankbrain AI system of determining themes and relevancy. So don't think in terms of these terms - also please don't listen to anyone focusing too heavily on LSI's as these have mostly been debunked as a load of flannel used by SEO's to impress, although leading SEO Brian Dean still insists that they have some effect on SEO. If you start researching LSI's you will end up in a rabbit hole from which you will never emerge! to advise - 'use your primary keyword a couple of times is nonsense'.
Think of your website like this:
Each page represents a theme - for example as Alick300 has used 'Laptop chargers' You need to think about writing chunky, relevant content around the term 'Laptop Chargers' but you do not need to mention every 'secondary keyword' you can think of to pepper the text with. Write compelling copy using semantically connected words like batteries within the content.
By all means, search related terms like batteries, tablets and transformers (are they still a thing?) but if you think in the way of 'Primary keywords' and 'secondary keywords' you will risk overusing certain terms, not having free-flowing writing and turning your intended customer into a brief visitor. Think of the use of synonyms as well - (the Bike/Bicycle analogy is a good one).
Modern SEO is about writing semantically connected and lexically relevant content in such a way that you engage your website visitor and ultimately convert them into customers. The more you engage, the longer the 'dwell time' and the more you satisfy user intent.
Have a read of Brian's latest post on Rankbrain - it's pretty brilliant and you should come away inspired!
https://backlinko.com/google-rankbrain-seo
There is no way of outsmarting Google by determining and hoofing in endless keywords and phrases. Modern content needs to be well written with perfect grammar and spelling and theme focused.
Also, break it down into easily readable chunks - this helps the user to stay engaged as opposed to being lost in long paragraphs. Pretty much like I have here.
Use Google search box to help and 'related search terms' at the bottom of the page to find semantically related phrases.
I hope this helps,
Regards
Nigel
Great answer Alick300! I would also add that the primary keyword and secondary keywords (sometimes referred to as LSI keywords) should all work together to help the search intent of the user. Writing longer, quality content that naturally uses your primary keyword a couple times and a ton of secondary keywords that still relate to your primary is a great way to get a page ranked quicker than normal.
For example if your a handyman that wants to rank for electrician + "your city", it's helpful to talk about electrical repairs, panel installations, electrical service, house wiring, etc. integrating this secondary keywords into your page not only helps your ranking for electrician + "your city", but also electrical repairs + "your city", panel installations + "your city", etc.
Primary keywords are the main keywords for which you want to rank. You are optimizing this keyword so that you can rank in Search engines. e.g Laptop chargers has the highest search volume
Secondary keywords mean those keywords which plays supporting role.
E.g Laptop batteries and chargers and Universal laptop chargers
Hope this helps.
Keyword Ranking Fluctuations
Hi Guys I am currently working on a website where one of the keyword targets is fluctuating. The keyword is fluctuating between page 2 and page 5. What makes this strange is that we are not experiencing the issue with any other keyword targets. They are all ranking fine. It is only 1 keyword. The keyword target happens to be the main homepage keyword target - not sure if this makes a difference? The homepage targets 2 keyword e.g. Business Offices & Accessories. The homepage ranks perfectly fine for e.g. Business Accessories but is fluctuating for e.g. Business Offices! Very strange. What makes it even stranger - the keyword variations of the fluctuating keyword e.g. office for business - these variations are all fine and not fluctuating. Its only 1 keyword. If anyone has any ideas or feedback that would be great! Thanks, Duncan
Intermediate & Advanced SEO | | CayenneRed890 -
Title tag: Long tail words or keyword dilution?
Hi all, I am a newbie to SEO. Lately, I have been struggling to optimize my title tag. Ones say that we should have long tail words in title tags because long tail words improve click through rate and generate quality leads. On the other hand, ones say that putting other words in the title tag will dilute the main keyword that my page ranks for. Do keywords really dilute each other in the title tags? I am really confused. Let me give this an example: Web Design Services | Company Name Web Design Services with Conversion Focused | Company Name Which one would you prefer and why? Thank you. 😄 Best, Raymond
Intermediate & Advanced SEO | | Raymondlee0 -
My website is not ranking for primary keywords in Google
I need help regarding some SEO strategy that need to be implemented to my website http://goo.gl/AiOgu1 . My website is a leading live chat product, daily it receives around 2000 unique visitors. Initially the website was impacted by manual link penalty, I cleaned up lot of backlinks, the website revoked from the penalty some where around June'14. Most of the secondary and longtail Keywords started ranking in Google, but unfortunately, it do not rank well for the primary keywords like (live chat, live chat software, helpdesk etc). Since I have done lot of onsite changes and even revamped the content but till now I dont find any improvement. I am unable to understand where I have got structed.
Intermediate & Advanced SEO | | sandeep.clickdesk
can anyone help me out?0 -
How to combine 2 pages (same domain) that rank for same keyword?
Hi Mozzers, A quick question. In the last few months I have noticed that for a number of keywords I am having 2 different pages on my domain show up in the SERP. Always right next to each other (for example, position #7 and #8 or #3 and #4). So in the SERP it looks something like: www.mycompetition1.com www.mycompetition2.com www.mywebsite.com/page1.html
Intermediate & Advanced SEO | | rayvensoft
4) www.mywebsite.com**/page2.html**
5) www.mycompetition3.com Now, I actually need both pages since the content on both pages is different - but on the same topic. Both pages have links to them, but page1.html always tends to have more. So, what is the best practice to tell Google that I only want 1 page to rank? Of course, the idea is that by combining the SEO Juice of both pages, I can push my way up to position 2 or 1. Does anybody have any experience in this? Any advice is much appreciated.0 -
Ranking for local searches without city specific keywords?
Hey guys! I had asked this question a few months ago and now that we are seeing even more implicit information determining search results, I want to ask it again..in two parts. Is is STILL best practice for on-page to add the city name to your titles, h1s, content etc? It seems that this will eventually be an outdated tactic, right? If there is a decent amount of search volume without any city name in the search query (ie. "storefont signs", but no search volume for the phrase when specific cities are added (ie. "storefront signs west palm beach) is it worth trying to rank and optimize for that search term for a company in West Palm Beach? We can assume that if there are 20,000 monthly searches for the non-location specific term that SOME of them would be fairly local, so do we optimize the page without the city name and trust Google to display results with a local intent...therefore showing our client's site in the SERPS when someone searches "sign company" and they are IN West Palm Beach? If there is any confusion, please just ask me to clarify! I think this would be a great WhiteBoard Friday topic for Rand!
Intermediate & Advanced SEO | | RickyShockley0 -
Meta Keywords Good or Bad
Hi All, I've been reading more about the meta keyword tag and why it may not be a good idea to include them on pages and am looking for thoughts/feedback on this idea. If you have employed this tactic, can you give me some insight into any results you saw. If you decided to not employ this tactic, why did you choose not to? I wan to understand all sides of this before employing any changes to my company's websites. Thank you for your help!
Intermediate & Advanced SEO | | airnwater0 -
Proper way to include Location & Zipcode Keywords
I have a client that is insisting that I add a list of approximately 50 cities and 80 zipcodes that their business serves within the keyword meta tag. Based on what I have been reading this will do absolutely nothing to help improve their search ranking. What would be the proper way today to let inform search engines of the geolocations a business serves?
Intermediate & Advanced SEO | | mmurphy0 -
Google and keywords with and without accents. How to approach optimization for both?
This is more of a problem for people optimizing for keywords in spanish, french, german and such. It is well known that SERPs for keywords with and without accents are different. However, I haven't been able to discover how do I make the incorrectly misspelled keywords rank without messing up the site's content. Another fact to take into account is that more than half the searches made in these languages are done without accents because, let's face it, it's just too much work. An example of my specific problem: The misspelled keyword "cursos de ingles" is currently ranking higher than the correctly spelled keyword "cursos de inglés". However, the misspelled keyword "clases de ingles" is not ranking at all and the correctly spelled keyword "clases de inglés" is on the first page. How is this possible? Now, how can I optimize the misspelled keywords to rank higher without misspelling the content on my site? Thank you! Capture.PNG
Intermediate & Advanced SEO | | 7decode0
