US and UK Websites of Same Business with Same Content
Hello Community,
I need your help to understand, whether I can use the US website's content on my UK website or not?
US Website's domain: https://www.fortresssecuritystore.com
UK Website's domain: https://www.fortresssecuritystore.co.uk
Both websites are having same content on all the pages, including testimonials/reviews.
I am trying to gain business from Adwords and Organic SEO marketing.
Thanks.
Yup, but doesn't matter. Hreflang works for this situation whether cross-domain or on a subdirectory/subdomain basis (and in fact is even more effective when cross-domain as you're also getting the benefit of the geo-located ccTLD.)
P.
Hi Paul,
If I understood correctly, we are talking about two different websites, not a website with subdomains.
Hreflang can be used for other languages and countries although not for masking 100% duplicated content as I stated above.site A: https://www.fortresssecuritystore.com
site B: https://www.fortresssecuritystore.co.uk
The recommendations that Google gives are for the purpose of having the pages crawled and indexed not for having success with 100% duplicate content which do not serve a good UX, therefore gain a high bounce rate, then the overall SEO fall down.
Mª Verónica
Unfortunately, your information is incorrect, Veronica.
Hreflang is specifically designed for exactly this situation. As Google Engineer Maile Oye clearly states, one of the primary uses of hreflang markup is:
- Your content has small regional variations with** similar content in a single language**. For example, you might have English-language content targeted to the US, GB, and Ireland.
(https://support.google.com/webmasters/answer/189077?hl=en)
There's no question differentiating similar content in the same language for different regions/countries is more of a challenge than for totally different languages, but it can absolutely be done, and in fact is a very common requirement for tens of thousands of companies.
Hi CommercePundit,
Sadly, there is not "a non painful way to say it".
You cannot gain business from Adwords and Organic SEO marketing having 100% duplicated content.The options; canonical and hreflang would not work in this case.
The only option is language "localization", mean rewrite the whole content by a local writer.
Canonical can be used for up to 10% not for the whole 100%. Hreflang can be used for other languages and countries although not for masking 100% duplicated content.
Sorry to tell the bad news. Good luck!
Mª Verónica
The more you can differentiate these two sites, the better they will each perform in their own specific markets, CP.
First requirement will be a careful, full implementation of hreflang tags for each site.
Next, you'll need to do what you can to regionalise the content - for example changing to UK spelling for the UK site content, making sure prices are referenced in pounds instead of dollars, changing up the language to use British idioms and locations as examples where possible. It'll also be critical to work towards having the reviews/testimonials from each site's own country, rather than generic, This will help dramatically from a marketing standpoint and also help differentiate for the search engines, so a double win.
And finally, you'll want to make certain you've set up each in their own Google Search Console and used the geographic targeting for the .com site to specify its target as US. (You won't' need to target the UK site as the .co.uk is already targeted so you won't' get that option in GSC.). If you have an actual physical address/phone in the UK, would also help to set up a separate Google My Busines profile for the UK branch.
Bottom line is - you'll need to put in significant work to differentiate the sites and provide as many signals as possible for which site is for which country in order to help the search engines understand which to return in search results.
Hope that all makes sense?
Hi!
Yeap you can target UK market with US site version. Always keep in mind that its possible that you might perform as well as in the main market (US).
Also, before making any desition and/or implementing, take a look at these articles:
Multi-regional and multilingual sites - Google Search Console
International checklist - Moz Blog
Using the correct hreglang tag - Moz Blog
Guide to international website expansion - Moz Blog
Tool for checking hreflang anotations - Moz BlogHope it helps.
Best Luck.
GR.
What to do with old content after 301 redirect
I'm going through all our blog and FAQ pages to see which ones are performing well and which ones are competing with one another. Basically doing an SEO content clean up. Is there any SEO benefit to keeping the page published vs trashing it after you apply a 301 redirect to a better performing page?
Technical SEO | | LindsayE0 -
Problem with Yoast not seeing any of this website's text/content
Hi, My client has a new WordPress site http://www.londonavsolutions.co.uk/ and they have installed the Yoast Premium SEO plug-in. They are having issues with getting the lights to go green and the main problem is that on most pages Yoast does not see any words/content – although there are plenty of words on the pages. Other tools can see the words, however Yoast is struggling to find any and gives the following message:- Bad SEO score. The text contains 0 words. This is far below the recommended minimum of 300 words. Add more content that is relevant for the topic. Readability - You have far too little content. Please add some content to enable a good analysis. They have contacted the website developer who says that there is nothing wrong, but they are frustrated that they cannot use the Yoast tools themselves because of this issue, plus Yoast are offering no support with the issue. I hope that one of you guys has seen this problem before, or can spot a problem with the way the site has been built and can perhaps shed some light on the problem. I didn't build the site myself so won't be offended if you spot problems with it. Thanks in advance, Ben
Technical SEO | | bendyman0 -
Handling of Duplicate Content
I just recently signed and joined the moz.com system. During the initial report for our web site it shows we have lots of duplicate content. The web site is real estate based and we are loading IDX listings from other brokerages into our site. If though these listings look alike, they are not. Each has their own photos, description and addresses. So why are they appear as duplicates – I would assume that they are all too closely related. Lots for Sale primarily – and it looks like lazy agents have 4 or 5 lots and input the description the same. Unfortunately for us, part of the IDX agreement is that you cannot pick and choose which listings to load and you cannot change the content. You are either all in or you cannot use the system. How should one manage duplicate content like this? Or should we ignore it? Out of 1500+ listings on our web site it shows 40 of them are duplicates.
Technical SEO | | TIM_DOTCOM0 -
How do we keep Google from treating us as if we are a recipe site rather than a product website?
We sell food products that, of course, can be used in recipes. As a convenience to our customer we have made a large database of recipes available. We have far more recipes than products. My concern is that Google may start viewing us as a recipe website rather than a food product website. My initial thought was to subdomain the recipes (recipe.domain.com) but that seems silly given that you aren't really leaving our website and the layout of the website doesn't change with the subdomain. Currently our URL structure is... domain.com/products/product-name.html domain.com/recipes/recipe-name.html We do rank well for our products in general searches but I want to be sure that our recipe setup isn't detrimental.
Technical SEO | | bearpaw0 -
How to create unique content for businesses with multiple locations?
I have a client that owns one franchise location of a franchise company with multiple locations. They have one large site with each location owning it's own page on the site, which I feel is the best route. The problem is that each location page has basically duplicate content on each page resulting in like 80 pages of duplicate content. I'm looking for advice on how to create unique content for each location page? What types of information can we write about to make each page unique, because you can only twist sentences and content around so much before it just all sounds cookie cutter and therefore offering little value.
Technical SEO | | RonMedlin0 -
How to resolve this Duplicate content?
Hi , There is page i get when i do proper menu navigation Caratlane.com>jewellery>rings>casualsrings> http://www.caratlane.com/jewellery/rings/casual-rings/leaves-dew-diamond-0-03-ct-peridot-1-ct-ring-18k-yellow-gold.html When i do a site search in my search box by my product code number "JR00219" The same page is appears with different url http://www.caratlane.com/leaves-dew-diamond-0-03-ct-peridot-1-ct-ring-18k-yellow-gold.html So there is a duplicate content. How can we resolve it. Regards, kathir caratlane.com
Technical SEO | | kathiravan0 -
Duplicate content and http and https
Within my Moz crawl report, I have a ton of duplicate content caused by identical pages due to identical pages of http and https URL's. For example: http://www.bigcompany.com/accomodations https://www.bigcompany.com/accomodations The strange thing is that 99% of these URL's are not sensitive in nature and do not require any security features. No credit card information, booking, or carts. The web developer cannot explain where these extra URL's came from or provide any further information. Advice or suggestions are welcome! How do I solve this issue? THANKS MOZZERS
Technical SEO | | hawkvt10 -
Has google panelized us ? If so, why ? How do I know if our website is panelized ?
We were ranked on first page among top 5 position a year ago for most of our pages. On one fine day, google decided to drop us from the results although google keeps indexing our pages. Google index our pages regularly but doesn't show them in its results. All google traffic we receive is for our own site name and its variations. I wanted to know - how do we know if google has panelized us. Why has google panelized us ? If they have panelized us, what can we do to get out of it ? Also I wanted to know if any tool will help me identify such thing. We have not done any link building. Our site page rank is 4 (it was 5 few months ago). All we did was on page optimization. Thanks for your help!
Technical SEO | | seoidea0
