Schema for blogs
When I run a wordpress blog through the structured data testing tool I see that there is @type hentry. Is this enough for blogs etc? Is this a result of Wordpress adding in this markup?
Do you recommend adding @blogposting type and if so why? What benefit to add a specific type of schema? How does it help in blogging?
Dan, do you recommend using AMP for the 'in depth' article spots?
Thanks Dan. That is interesting about what you say about using the Article Schema as opposed to Blog post one. Also the fact that you have a chance for the "in depth" spots.
Many thanks
Hello! Roman's answers are really good, but thought I would add some info as well.
Article or BlogPosting Schema can help in some of the following ways (vs hentry)
- Give search engines backend / structured info about the contents of the page
- Google's reference on Article schema shows all the snippet and SERP features
- Using article schema is the only way to get into 'in depth' article spots on Google
- I've had luck with Google showing the 'Last Updated' date in search results, which shows a newer date when using it in conjunction with article schema
So even though you'd technically be doing a 'blog post' I would use the parent Article schema as it's more widely recognized.
henry means text entry, it can be a recipe, an article, a blog post is most basic type of schemas. The hEntry schema consists of the following properties:
hentry
entry-title. required. text.
entry-content. optional (see field description). text. []
entry-summary. optional. text.
updated. required using datetime-design-pattern. []
published. optional using datetime-design-pattern.
author. required using hCard. [*]
bookmark (permalink). optional, using rel-bookmark.
tags. optional. keywords or phrases, using rel-tag.If you ask how is structure a paragraph. A logical answer will tell you a paragraphs is formed it by words and letters is the same case here
I already answer that question (No is not enough)Is this a result of Wordpress adding in this markup?
Wordpress do not markup anything by defaultDo you recommend adding @blogposting type and if so why?
This the hierarchy of schemas
Thing > CreativeWork > Article > SocialMediaPosting > BlogPostingWhat benefit to add a specific type of schema?
I already answer that questionHow does it help in blogging?
I already answer that questionIn Summary
Sorry I wasn't trying to bother you, in fact I was trying to help and apparently you didn't noticed.Sources
Thanks Roman for trying to help. I guess what I was asking is from a Rich Snippets point of view, why bother with specific schema types- what is the difference in the search results to using specific types such as blogposting types versus article types. I understand the difference between articles and blogs and what they represent but why bother using specific schema types? Do they present differently as rich snippets?
There is two main type of text content on schemas
An article, such as a news article or piece of investigative report. Newspapers and magazines have articles of many different types and this is intended to cover them all.
blogPost A posting that is part of this blog.
So in theory, an article is like an acedemic document and a blog post is like an informal document, in the real world there's no big difference at least from seo perspective of blog running of wordpress.
Thanks. I do see the benefit of schema but my question was about the value of what wordpress adds as @type hentry versus adding in specific types such as @type BlogPosting? What value is adding in specific blog posting types? Is there a difference in the rich snippets?
Scheme are a great way to help Google to understand your content, there is no limit of how many information you provide to Google.
The snippets will help you not only with crawler but also with your CTR a good example for that are rating snippet, so when a user see your article the plugin allows to the users to rate your post, and the rating will be visible for users and crawlers
Example. you have a tutorial in your post about SEO, when someone have been looking for a tutorial like your post, before to enter your website google will show to that user the rating of other users for that post. This will impact your CTR and if there are to many people clicking for the specific query probably Google will rank your post in better position even when other post has a better Pagerank or Authority.
Basically for Google your post meet the needs of the users so it deserve a better place
This just an explanation about the utility of schemas in an ideal world, so it will not rank your site but might help.
I always install this plugins on my wordpress websites
WP-PostRatings > This is mandatory
All In One Schema.org Rich Snippets > General purpose
Product Schema Markup for All Products
Hi Team, Google search console used to allow you to use their structured data markup helperhttps://www.google.com/webmasters/markup-helper/u/0/ to markup multiple product pages at once that were similar. I do not see this feature anymore with the new search console. Does anyone have a recommendation for marking up multiple product pages without having to have schema markup firing in GTM for each product page?
Technical SEO | | agrier0 -
Schema.org product offer with a price range, or multiple offers with single prices?
I'm implementing Schema.org, (JSON-LD), on an eCommerce site. Each product has a few different variations, and these variations can change the price, (think T-shirts, but blue & white cost $5, red is $5.50, and yellow is $6). In my Schema.org markup, (using JSON-LD), in each Product's Offer, I could either have a single Offer with a price range, (minPricd: $5, maxPrice $6), or I could add a separate Offer for each variation, each with its own, correct, price set. Is one of these better than the other? Why? I've been looking at the WooCommerce code and they seem to do the single offer with a price range, but that could be because it's more flexible for a system that's used by millions of people.
Technical SEO | | 4RS_John1 -
We switched the domain from www.blog.domain.com to domain.com/blog.
We switched the domain from www.blog.domain.com to domain.com/blog. This was done with the purpose of gaining backlinks to our main website as well along with to our blog. This set us very low in organic traffic and not to mention, lost the backlinks. For anything, they are being redirected to 301 code. Kindly suggest changes to bring back all the traffic.
Technical SEO | | arun.negi0 -
If I change Tags and Categories in Wordpress blog post, will it negatively affect SEO and cause 404s?
Hi, I have belatedly come to the conclusion that I have been using tags and categories when blogging in wordpress incorrectly. The result is that Google seems to prefer to show my archives and tags in search results rather than the post itself. Not good UX. As the site is only a few months old, am I best to learn my lesson and tag and categorize correctly moving forward or Should I go back in to these posts and clean them up & categorize and tag correctly. If I do this, will it cause 404s and hurt my SEO? Thanks!
Technical SEO | | johnyfiveisalive2 -
Blog Page Titles - Page 1, Page 2 etc.
Hi All, I have a couple of crawl errors coming up in MOZ that I am trying to fix. They are duplicate page title issues with my blog area. For example we have a URL of www.ourwebsite.com/blog/page/1 and as we have quite a few blog posts they get put onto another page, example www.ourwebsite.com/blog/page/2 both of these urls have the same heading, title, meta description etc. I was just wondering if this was an actual SEO problem or not and if there is a way to fix it. I am using Wordpress for reference but I can't see anywhere to access the settings of these pages. Thanks
Technical SEO | | O2C0 -
Referencing links in Articles and Blogs
Hi I am wondering if the <sup>tag in html is picked up by google as a reference point?</sup> I.e when you put a superscript in word it puts a small number next to your sentence. Then you have a list of reference at the end of the blog/article does google recognise this?
Technical SEO | | Cocoonfxmedia0 -
Is it worth adding schema markup to articles?
I know things like location, pagination, breadcrumbs, video, products etc have value in using schema markup. What about things like articles though? Is it worth all the work involved in having the pages mark up automatically? How does this effect SEO, and is it worthwhile? Thanks, Spencer
Technical SEO | | MarloSchneider0 -
Blog article URL - with or without date?
Quick question to all you folks: does including the date in a blog article's permalink affect rankings? For example, here's an article with the month and year, as well as the blog title: http://www.ayzanyc.com/blog/2012/12/difference-between-hot-chocolate-hot-cocoa/ Is it better to omit the date and just put the blog title? Also, if is better to avoid using the date, is it worth it to change the link structure of our previous articles (given that the URL will now be different), or should we just focus on future articles? Thanks ahead of time for your advice.
Technical SEO | | onurkiyak0
