Crawling Problem : No-data Of My Site
Hey, Folks!!
So It's Been More than a Month.And Moz is not crawling my website http://www.trickypedia.com/.I have seen Moz Last update I thought they will crawl my site but No results Disappointing. My Sites Domain Authority and Page Authority is still 1. But In other Seo Tools, they are Perfectly Crawling My Website. What Would Be the reason? Can anyone Please Explain.
If your website is experiencing a "no-data" issue during crawling by search engines, several factors may be at play. Check your robots.txt file, ensure proper HTTP status codes, examine your meta tags, confirm content accessibility, and investigate for technical errors. cloaking facebook ads consider the quality of your content, the efficiency of your crawl budget, mobile compatibility, and overall site security. Additionally, use webmaster tools for insights and, if needed, consult web development or SEO professionals for a comprehensive audit and solutions.
robots.txt
file, ensure proper HTTP status codes, examine your meta tags, confirm content accessibility, and investigate for technical errors. Consider the quality of your content, the efficiency of your crawl budget, mobile compatibility, and overall site security. Additionally, use webmaster tools for insights and, if needed, consult web development or SEO professionals for a comprehensive audit and solutions. -
<h2>why my site not get verified from moz??</h2>
I created a website and I have ranked 1 in most of my keywords. and my site's traffic is normal and I have a fine domain authority but Moz still doesn't show any data on my website
could you guys check it and fix that problem for me??
my website (https://دندانپزشک.net/)
this is the address of my website
thank you<3 -
Hi there!
It sounds like you're wondering why we haven't got link data for you in OSE. There are a few possible reasons why your site might not be indexed.
The first thing to check is if your site uses a custom Top Level Domain (TLD), like .agency or .london. If so, then you won't see data for your site in our index, as we don't currently support custom TLDs. Unfortunately there isn't a good workaround for this—it's a technical limitation of the tool. I can see you site http://www.trickypedia.com/ doesn't use a custom TLD, so you're good.
If your site isn't linked to by one of the seed URLs used to build our index, then our bot won't be able to find it and add it to our map. Learn more about how we index the web.
In addition to this, Mozscape focuses on a breadth-first approach. Therefore we almost always have content from the homepage of websites, externally linked-to pages, and pages higher up in a site's information hierarchy. However, deep pages that are buried beneath many layers of navigation are sometimes missed, and it may be several index updates before we catch all of these.
If our crawlers or data sources are blocked from reaching those URLs, they may not be included in our index (though links that point to those pages will still be available).
Finally, the URLs seen by Mozscape must be linked-to by other documents on the web or our index will not include them.
If links to your pages have not been indexed and you have links from high Authority pages, you might want to check to see if we have indexed the pages linking to your site. Enter the URL that you know if linking you into Open Site Explorer and see if we've got those in our index. You'll also want to make sure that we aren't blocked from crawling the site. If our web crawlers are blocked from crawling certain pages (i.e., with "noindex" or a Robots.txt exclusion), they may not be included in the index.
I hope this helps, please do let me know if you would like more clarification or have any other queries.
Jo
Data Analysis Tool - No data found for this domain
For some reason, about a week ago, my clients website nolonger appears on the moz analysis tool ( www.movietrailersarea.org ) which it previously was. now i get the error "Bummer! No data found for this domain" and now nearly all traffic has also depleted.
Moz Bar | | Mike569
site is still indexed by google & robots isnt blocking any crawlers.
any idea?3 -
Does data-bind hurt SEO?
sleepcountry.ca uses Oracle Commerce Cloud which uses Knockout data-binds syntax to attach events to DOM elements like this (A <a id="s0207useresourcesinwidgets01"></a>Knockout custom binding named ‘widgetLocaleText’ - I am not familiar this technology stack): Same applies to H1 tag - you can't find H1 tag in Source. In short, the text binding causes the associated DOM element to display the text value of your parameter. Data binding is applied to all DOM elements on pages of sleepcountry.ca even that this technique doesn't pass W3C markup validation: Error: Element title must not be empty. MOZ reports that all H1 Tags are missing on ALL PAGES of the site. Same is reported by Semrush and other respected services. However, it seems like Google automatically adds tagging to all data-bind(ed) elements including Title! site:sleepcountry.ca I'm no expert in Oracle Commerce Cloud or Knockout, but I'm confused.
Moz Bar | | allagringaus
QUESTION: Does this data-bind hurt organic search and if it does, why Google still sees all TITLES while Moz and other services report it as a major problem - titles are missing. ? Thank you so much in advance! (I'm not an SEO expert but this problem might be related to my project)0 -
Why keywords have zero data for UAE?
I have searched for food delivery keyword for the United Arab Emirates, EN, and AR. Monthly volume has no data whereas difficulty, organic and priority has figures. When I change the country to US; monthly volume has more data. Can you explain; how can I use your service?
Moz Bar | | Twenzy1 -
Limit MOZ crawl rate on Shopify or when you don't have access to robots.txt
Hello. I'm wondering if there is a way to control the crawl rate of MOZ on our site. It is hosted on Shopify which does not allow any kind of control over the robots.txt file to add a rule like this: User-Agent: rogerbot Crawl-Delay: 5 Due to this, we get a lot of 430 error codes -mainly on our products- and this certainly would prevent MOZ from getting the full picture of our shop. Can we rely on MOZ's data when critical pages are not being crawled due to 430 errors? Is there any alternative to fix this? Thanks
Moz Bar | | AllAboutShapewear2 -
Site crawl only shows homepage
Hi everyone, A client of us has a quite new website with a lot of URLs. (Google Search Console indicates around 5300.) However, when I execute a site crawl with screaming frog, or a crawl test in MOZ, it only shows me one URL, the homepage. Does somebody have an idea why the other pages of the website are not showing up? Thanks,
Moz Bar | | WeAreDigital_BE
Jens0 -
Crawling password protected sites such as dev or staging areas to look at sites b4 going live ?
Hi Ive instructed clients to password protect dev areas so dont get crawled and indexed but how do we set up Moz crawl software so we can crawl theses sites for final check of any issues before going live ? Is there an option i havnt seen to add logins/passwords for crawl software to access ? cheers dan
Moz Bar | | Dan-Lawrence0 -
Weird back link showed in moz crawl
Some time ago somebody from this site: http://dianibeach.com created a weird link to our site which had on the end db. Later we have realized that the link was coming from every footer on each page. I believe that the back links from footer does not have realy value and even the more of them the less value. We have asked the guy to remove that links as I thought it might harm our site more then help. Now I I was very surprised to find this link in moz crawl error as second top page on our site in current index??? Can somebody explain how is this possible?? The most ridiculous thing is that when I click on that link it realy opens our site! How is that possible, what is it? This is the link: http://villasdiani.com/?db Thank you very much for any help with this
Moz Bar | | Rebeca10 -
How do you stop Moz crawling a page?
Hello, I have a contact form which generates thousands of duplicate crawl errors. I'm going to use to block Google indexing these pages. Will this also block MOZ from crawling these pages and displaying the error? Thanks!
Moz Bar | | Seaward-Group0
