A charset attribute on a meta element found after the first 1024 bytes.
Can anybody help me with this error please...
Error: A
charset
attribute on ameta
element found after the first 1024 byteshttps://validator.w3.org/nu/?doc=https%3A%2F%2Fsocialmotors.uk%2F
I have no idea how to find or fix this issue, i have spoke to my theme dev and they say it is not a problem with the theme, so i do not know were to turn now.
As you will see in the link above there are a couple of errors, i do not know how to fix them either
Any help would be greatly appreciated.
Move charset="UTF-8"> immediately after the opening
Hreflang Errors 404 vs "Page Not Found"
For a websites that differ between catalogs (PDPs) what hreflang error causes the least harm? Obviously the best solution is to only have hreflang for shared products, but this takes more work to implement. So when no identical product exists... 1. Hreflang points to 404 or 410 error. 2. Hreflang points to 200 status "Page Not Found" page. This obviously has the additional issue of needing to point back to 100+ urls. I want to avoid having Google decide to ignore all hreflang due to errors as many correct urls will exist. Any thoughts?
On-Page Optimization | | rigelcable0 -
Duplicate 'meta title' issue (AMP & NON-AMP Pages)
how to fix duplicate meta title issue in amp and non-amp pages? example.com
On-Page Optimization | | 21centuryweb
example.com/amp We have set the 'meta title' in desktop version & we don't want to change the title for AMP page as we have more than 10K pages on the website. ----As per SEMRUSH Tool---- ABOUT THIS ISSUE It is a bad idea to duplicate your title tag content in your first-level header. If your page’s <title>and <h1> tags match, the latter may appear over-optimized to search engines. Also, using the same content in titles and headers means a lost opportunity to incorporate other relevant keywords for your page.</p> <p><strong>HOW TO FIX IT</strong></p> <p>Try to create different content for your <title> and <h1> tags.<br /><br />this is what they are recommending, for the above issue we have asked our team to create unique meta and post title for desktop version but what about AMP page?<br /><br />Please help!</p></title>0 -
Each page with a different meta description?
each page on my website represents a different department, can I program the header to show a different meta description on each page or should there only be 1 meta description tag per domain?
On-Page Optimization | | RonnieT0 -
Exact keyword match for meta title and h1 what is best practice?
How exact should my meta titles and H1 one be compare to the keyword you wish to rank on. Eksample. When I do a research with google AdWords the keyword tool shows me: 260 monthly searches for house for rent Hua Hin 140 monthly searches for Hua Hin house for rent 70 monthly searches for House for rent in Hua Hin The first two includes the exact same 5 words while the last one includes the stopword "in". That google have different search volumens for these very smilair search queries tells me that small differences matters. So how does that effect the way i shoulf write my: a)meta titles b)H1 I feel I get better sentences often by reordering the keywords etc. “Top tips on how to rent house in Hua Hin” Instead of “Top tips if you want a house for rent in Hua Hin” Do you use stop words like “in” hua hin. (only used in 25% of the searches queries)? Also would it matter if i write a plural form of a keyword instead of a singular etc propeties and sted of property? My goal is to write easy to read and unique content but i feel i can make exact matches if required with out compromising to much.
On-Page Optimization | | nm19770 -
URL Domain Used in Meta Description
Today I was asked if using a domain url in your meta description can have a negative impact on your website. This description includes a list of the homepage url, but directs visitors to a different internal page of the website. My concern fell with directing visitors to a different page of the site, but promoting the homepage in the description/snippet. With Penguin 2.1 release on the 4th, I'm very cautious of my links/urls. What are your thoughts behind this? What are the possible, if any negative impacts this could have on a site? This URL does have a brand name as so the Title.
On-Page Optimization | | flcity150 -
Does the link title attribute benefit seo?
Hello, Anyone could tell me the benefit SEO of link title attribute. Is **Link Title **ranking factor? Thanks
On-Page Optimization | | JohnHuynh0 -
Duplicate Title and Meta Description Tags in Shopify with this App
Hello. I'm finding that by adding the Ultra SEO app in Shopify, I now have duplicates of the Title tags and Meta Descriptions. It looks like it's pulling title tags from the Shop info, the product or page titles as well as the Title tag I add in Ultra SEO. The website is 1bigcookie.com. The duplicate meta descriptions are from the text I entered in the meta description field in Ultra SEO. I entered the canonical url code shopify specifies to help with duplicate content, but what about duplicate title and meta description tags on the same page?
On-Page Optimization | | mymochamoney0 -
Any SEO effect(s) / impact of Meta No Cache?
Hi SEOMoz Guys, Hope you guys are doing well. I've been searching online and bumped into this archived page (http://www.seomoz.org/qa/view/34982/meta-nocache-affect-ranking). I would like to get an updated take on this issue whether or not the meta no cache code on a page bears negative/positive or no SEO impact / effect. <meta http-equiv="Pragma" content="no-cache" /> <meta http-equiv="Cache-Control" content="no-cache"/> Thanks! Steve
On-Page Optimization | | sjcbayona-412182
