Help Setting Up 301 Redirects from Coldfusion Site to Wordpress Site.
I have created a new website and need to redirect all of the previous pages to the new one. The old website was built in coldfusion and the new site is built in wordpress.
One of the pages I'm trying to redirect is www.norriseal.com/products.cfm to http://norrisealwellmark.com/products/.
This is what I have in my .htaccess file
<ifmodule mod_rewrite.c="">Options +FollowSymlinks
RewriteEngine On
RewriteBase /
Redirect 301 /products.cfm http://norrisealwellmark.com/products/</ifmodule>The result of this redirect is http://norrisealwellmark.com/products.cfm
How do I prevent the .cfm from appending to the destination URL?
Hey Britney,
No, the old (ColdFusion) site and the new (PHP) site are on the same linux (CentOS) server.
The 301 redirect rule I described above in my original post is applying '.cfm' to the end of the destination URL - thats the main issue we're trying to tackle here.
Thanks for responding!
Hi Chris,
Are you still using ColdFusion?
It sounds like you're on a Windows server, yeah? If so, adding this to your web.config file should do the trick:
<match url="(.*)"><conditions><add matchtype="IsFile" negate="true"><add matchtype="IsDirectory" negate="true"></add></add></conditions>
<action type="Rewrite" url="{R:1}.cfm"></action></match>Otherwise, adding the following to your web.config for WordPress should work:
<rulename="company cfm"=""><matchurl="^company (.*)$"=""><conditionslogicalgrouping="matchall"><addinput="{request_filename}"matchtype="isfile"negate="true"><addinput="{request_filename}"matchtype="isdirectory"negate="true"><actiontype="rewrite"url="{r:1}.cfm"></actiontype="rewrite"url="{r:1}.cfm"></addinput="{request_filename}"matchtype="isdirectory"negate="true"></addinput="{request_filename}"matchtype="isfile"negate="true"></conditionslogicalgrouping="matchall"></matchurl="^company></rulename="company>
301 Redirect for multiple links
I just relaunched my website and changed a permalink structure for several pages where only a subdirectory name changed. What 301 Redirect code do I use to redirect the following? I have dozens of these where I need to change just the directory name from "urban-living" to "urban", and want it to catch the following all in one redirect command. Here is an example of the structure that needs to change. Old
Technical SEO | | shawnbeaird
domain.com/urban-living (single page w/ content)
domain.com/urban-living/tempe (single page w/ content)
domain.com/urban-living/tempe/the-vale (single page w/ content) New
domain.com/urban
domain.com/urban/tempe
domain.com/urban/tempe/the-vale0 -
301 Redirects, Sitemaps and Indexing - How to hide redirected urls from search engines?
We have several pages in our site like this one, http://www.spectralink.com/solutions, which redirect to deeper page, http://www.spectralink.com/solutions/work-smarter-not-harder. Both urls are listed in the sitemap and both pages are being indexed. Should we remove those redirecting pages from the site map? Should we prevent the redirecting url from being indexed? If so, what's the best way to do that?
Technical SEO | | HeroDesignStudio0 -
How do I redirect the Author archive page in Wordpress?
If you do a search for my name on Google, the first result is the author archive page of my Wordpress blog. I would like to redirect the author page to my "about me" page but cannot add a 301 as the author page is created dynamically in Wordpress. Anyone know how I can do this?
Technical SEO | | richdan0 -
301 redirect relative or absolute path?
Hello everyone, Recently we've changed the URL structure on our website, and of course we had to 301 redirect the old urls to the coresponding new ones. The way the technical guys did this is: "http://www.domain.com/old-url.html" 301 redirect to "/new-url.html"
Technical SEO | | Silviu
meaning as a relative redirect path, not an absolute one like this:
"http://www.domain.com/old-url.html" 301 redirect to "http://www.domain.com/new-url.html" This happened for few thousands urls, and the fact is the organic traffic dropped for those pages after this change. (no other changes were made on these pages and the new urls are as seo friendly as possible, A grade on On-Page Grader). The question is: does the relative redirect negatively affects seo, or it counts the same as an absolute path redirect? Thanks,
S.0 -
301 redirect from Blogger
Hello, I have a client with a Wordpress network of blogs, each blog is owned by a different blogger. Many of them were migrated time ago from Blogger. I have seen that the way used to redirect them is a meta refresh, so no authority is being passed. I cannot find any reliable way of making a 301 from Blogger, There are some plugins, but I'm afraid of using them. Any of you have experience with this situation please? I have even thought about placing a global rel canonical before the meta refresh, but I think that here the problem is the meta refresh itself.... Thank you in advance
Technical SEO | | Juandbbam0 -
How do I fix a 301 Redirect Loop?
Saturday I waas doing some correcting of some duplicate titles, including nofollowing tags, etc. (my main problem was duplicate titles due to tags and categories being indexed). Now this morning I see that one of my pages refuses to load, citing a 301 redirect loop. http://www.incredibleinfant.com/feeding/switching-baby-formula/ Originally, the page was posted under the wrong category. http://www.incredibleinfant.com/uncategorized/switching-baby-formula I resaved it under the correct category (feeding) and now it won't load. Can someone help me figure out how to correct this mess? Thanks so much Heather
Technical SEO | | Gotmoxie0 -
My site keeps losing positions, Please help!!
Hello, This is the first time I post on this forum but have been a Pro Member for about 11 months. Im going crazy the more I do the more it drop positions. My problem is that one of the sites that Im working is has not been on the top 50 of any of the keywords. There were many issues but I have reduce the number. Im not sure if I can post the link here or via PM. My market is very competitive and Im using word press. One of my target keywords is: web design miami I would like for a member to give me an opinion of my site and may tell me what Im doing wrong. Thanks in advance.
Technical SEO | | ogdcorp0 -
Delete 301 redirected pages from server after redirect is in place?
Should I remove the redirected old pages from my site after the redirects are in place? Google is hating the redirects and we have tanked. I did over 50 redirects this week, consolidating content and making one great page our of 3-10 pages with very little content per page. But the old pages are still visible to google's bot. Also, I have not put a rel canonical to itself on the new pages. Is that necessary? Thanks! Jean
Technical SEO | | JeanYates0
