Help with facet URLs in Magento
Hi Guys,
Wondering if I can get some technical help here...
We have our site britishbraces.co.uk , built in Magento. As per eCommerce sites, we have paginated pages throughout.
These have rel=next/prev implemented but not correctly ( as it is not in is it in ) - this fix is in process.
Our canonicals are currently incorrect as far as I believe, as even when content is filtered, the canonical takes you back to the first page URL. For example,
http://www.britishbraces.co.uk/braces/x-style.html?ajaxcatalog=true&brand=380&max=51.19&min=31.19
Canonical to...
Which I understand to be incorrect.
As I want the coloured filtered pages to be indexed ( due to search volume for colour related queries ), but I don't want the price filtered pages to be indexed - I am unsure how to implement the solution?
As I understand, because rel=next/prev implemented ( with no View All page ), the rel=canonical is not necessary as Google understands page 1 is the first page in the series.
Therefore, once a user has filtered by colour, there should then be a canonical pointing to the coloured filter URL? ( e.g. /product/black )
But when a user filters by price, there should be noindex on those URLs ? Or can this be blocked in robots.txt prior?
My head is a little confused here and I know we have an issue because our amount of indexed pages is increasing day by day but to no solution of the facet urls.
Can anybody help - apologies in advance if I have confused the matter.
Hi Lewis,
Firstly thank you for taking your time to respond in depth to my question.
Since reading your response, I have done the following...
Identified the parameters that should NOT be indexed, these are; 'brand=', 'min=' and 'max='
The colour filter 'colour=' is to be kept indexed. I have reviewed the website and found that users cannot currently select to filter more than on colour, which eliminates Google from indexing multiple colour filters in one URL.
However, users can still filter by colour and brand, hence why I have requested ours devs to meta noindex any URL that contains the 'brand=' parameter as well as any URLs that have the 'min/max=' parameters as these are price filters.
I have also requested rel=next/prev to be implemented correctly.
The above should drastically reduce our indexed content.
As well as this, I have added the following parameters into Search Consoles' URL Parameter tool as 'No Crawl', 'brand, min, max' - although I understand this is not a guaranteed fix, it was my first option with no immediate dev time over the weekend.
Now the only URLs in need of a canonical is the colour filtered URLs as 'brand, min max' are all noindex. I have asked dev to ensure the canonical points back to page 1 for now, however I am looking into a view-all page option so the canonical would point to that.
A good learning curve all of this!
There is a big difference between robots.txt and no index
"Therefore, once a user has filtered by colour, there should then be a canonical pointing to the coloured filter URL? ( e.g. /product/black )
But when a user filters by price, there should be noindex on those URLs Or can this be blocked in robots.txt prior?"
See http://i.imgur.com/114BHcR.png
You need to use a no index tag not robots.txt ideally with a secular canonical pointing to the product.
Please see references one and two below. There are larger versions of the photos below as well
You need to run your site through deep crawl and or screaming frog SEO spider If you would be kind enough to give me the URL privately or publicly I will run a deep crawl and SEO spider
** This topic is difficult to explain without using the ability to show videos and images inside the box while describing this. That's why I recommend you view this YouTube video and slide share.**
Deep crawl is fantastic at solving these issues it has done this for other magenta clients of mine, and I strongly recommend utilizing what you've learned from that webinar and the other references below.
please see one and two below
- https://www.deepcrawl.com/knowledge/webinars/masterclass-webinar-faceted-navigation-for-seo/
- https://www.stonetemple.com/seo-tags-virtual-keynote-with-gary-illyes-and-eric-enge/
https://webmasters.googleblog.com/2014/02/faceted-navigation-best-and-5-of-worst.html
https://cloudz.click/blog/building-faceted-navigation-that-doesnt-suck
http://searchengineland.com/google-offers-advice-faceted-navigation-infinite-scroll-web-pages-184232
larger versions of the images
I agree with Lewis's recommendation for an extension and have added a couple more.
- http://www.mageworx.com/magento-2-seo-extension.html
- https://ecommerce.aheadworks.com/magento-extensions/ultimate-seo-suite.html
- https://ecommerce.aheadworks.com/magento-2-extensions/layered-navigation
I Hope this helps,
Thomas
Hi!
We do a lot of consultancy for Magento projects and this is a question that comes up quite regularly as it can't really be handled perfectly straight out of the box with Magento.
Every implementation is a little bit different, but I'll put together some recommendations below based on the information available at the moment.
For your faceted navigation, you ideally don't want to index any of these pages, unless you believe that you'll rank in your own right for specific filters (e.g. Colour, like you pointed out in your last message).
That then comes with some additional complications. In Magento, if you have 3 colours available in the faceted nav, you'll have all the different variations indexed in each combination.
For example:
Blue
Black
RedBlue + Black
Blue + Red
Black + Red
Black + Blue
Red + Blue
Red + BlackMagento as standard doesn't always keep the filters in the same order, so you can end up with literally thousands of pages ending up in the index for a relatively small number of attributes being shown on your pages.
There are a few recommendations here:
- Go and look at the MageWorx Ultimate SEO Suite Plugin - http://www.mageworx.com/seo-suite-ultimate-magento-extension.html - For $249, it solves a lot of issues Magneto has straight out of the box and gives you ultimate control over your meta titles.
What you want to do is set all of your facets to 'NOINDEX,FOLLOW' where possible. This will reduce the number of URLs in the index gradually. An example of this would be adding ?min=* and mode=* etc (grid/list variants).
- For your canonicals, you're probably best setting the canonical to the current filtered page (for example, if you're on a category page with colour = blue selected in your faceted nav, you'd have this URL as your canonical). Some sites we work on have it setup so the canonical points to the category URL (like you currently have).
Finally, you probably want to build an extension to allow you to inject content into the filtered content pages. If you're using an extension like ManaDev for your facet navigation, this can be achieved fairly easily and allows you to add a block of text to each filter applied on a page.
You should also look to request each of the incorrectly indexed URLs is removed from the index (although this does take a long time if you have a lot!).
We wrote a really long guide around launching a Magento website last month which may be of interest - https://www.pinpointdesigns.co.uk/the-definitive-guide-to-launching-a-magento-website/. We've also done a guide on Common Magento SEO Issues here - https://www.pinpointdesigns.co.uk/common-magento-seo-issues/ and I previously wrote a guide on setting Magento up for Search Engines on Moz - https://cloudz.click/ugc/setting-up-magento-for-the-search-engines (Although this is likely to be a little outdated now)
I hope this helps!
Lewis
Removing the Trailing Slash in Magento
Hi guys, We have noticed trailing slash vs non-trailing slash duplication on one of our sites. Example:
Intermediate & Advanced SEO | | brandonegroup
Duplicate: https://www.example.com.au/living/
Preferred: https://www.example.com.au/living So, SEO-wise, we suggested placing a canonical tag on all trailing slash pointing to non-trailing slash. However, devs have advised against removing the trailing slash from some URLs with a blanket rule, as this may break functionality in Magento that depends on the trailing slash. The full site would need to be tested after implementing a blanket rewrite rule. Is any other way to address this trailing slash duplication issue without breaking anything in Magento? Keen to hear from you guys. Cheers,0 -
Duplicate URLs ending with #!
Hi guys, Does anyone know why a site can contain duplicate URLs ending with hastag & exclamation mark e.g. https://site.com.au/#! We are finding a lot of these URLs (as duplicates) and i was wondering what they are from developer standpoint? And do you think it's worth the time and effort adding a rel canonical tag or 301 to these URLs eventhough they're not getting indexed by Google? Cheers, Chris
Intermediate & Advanced SEO | | jayoliverwright0 -
Image URLs - best practice
Hi - I'm assuming image URL best practice follows same principles as non image URLs (not too many files and so on) - I notice alot of web devs putting photos in subdomains, so wonder if I'm missing something (I usually avoid subdomains like the plague)!
Intermediate & Advanced SEO | | McTaggart1 -
If I own a .com url and also have the same url with .net, .info, .org, will I want to point them to the .com IP address?
I have a domain, for example, mydomain.com and I purchased mydomain.net, mydomain.info, and mydomain.org. Should I point the host @ to the IP where the .com is hosted in wpengine? I am not doing anything with the .org, .info, .net domains. I simply purchased them to prevent competitors from buying the domains.
Intermediate & Advanced SEO | | djlittman0 -
Changing a url from .html to .com
Hello, I have a client that has a site with a .html plugin and I have read that its best to not have this. We currently have pages ranking with this .html plug in. However If we take the plug in out will we lose rankings? would we need a 301 or something?
Intermediate & Advanced SEO | | SEODinosaur0 -
Is it safe to redirect multiple URLs to a single URL?
Hi, I have an old Wordress website with about 300-400 original pages of content on it. All relating to my company's industry: travel in Africa. It's a legitimate site with travel stories, photos, advice etc. Nothing spammy about. No adverts on it. No affiliates. The site hasn't been updated for a couple of years and we no longer have a need for it. Many of the stories on it are quite out of date. The site has built up a modest Mozrank value over the last 5 years, and has a few hundreds organically achieved inbound links. Recently I set up a swanky new branded website on ExpressionEngine on a new domain. My intention is to: Shut down the old site Focus all attention on building up content on the new website Ask the people linking to the old site to my new site instead (I wonder how many will actually do so...) Where possible, setup a 301 redirect from pages on the old site to their closest match on the new site Setup a 301 redirect from the old site's home page to new site's homepage Sounds good, right? But there is one issue I need some advice on... The old site has about 100 pages that do not have a good match on the new site. These pages are outdated or inferior quality, so it doesn't really make sense to rewrite them and put them on the new site. I call these my "black sheep pages". So... for these "black sheep pages" should I (A) redirect the urls to the new site's homepage (B) redirect the urls the old site's home page (which in turn, redirects to the new site's homepage, or (C) not redirect the urls, and let them die a lonely 404 death? OPTION A: oldsite.com/page1.php -> newsite.com
Intermediate & Advanced SEO | | AndreVanKets
oldsite.com/page2.php -> newsite.com
oldsite.com/page3.php -> newsite.com
oldsite.com/page4.php -> newsite.com
oldsite.com/page5.php -> newsite.com
oldsite.com -> newsite.com OPTION B: oldsite.com/page1.php -> oldsite.com
oldsite.com/page2.php -> oldsite.com
oldsite.com/page3.php -> oldsite.com
oldsite.com/page4.php -> oldsite.com
oldsite.com/page5.php -> oldsite.com
oldsite.com -> newsite.com OPTION 😄 oldsite.com/page1.php : do not redirect, let page 404 and disappear forever
oldsite.com/page2.php : do not redirect, let page 404 and disappear forever
oldsite.com/page3.php : do not redirect, let page 404 and disappear forever
oldsite.com/page4.php : do not redirect, let page 404 and disappear forever
oldsite.com/page5.php : do not redirect, let page 404 and disappear forever
oldsite.com -> newsite.com My intuition tells me that Option A would pass the most "link juice" to my new site, but I am concerned that it could also be seen by Google as a spammy redirect technique. What would you do? Help 😐1 -
Should I Use City Name in URL?
Having a website designed for a car dealership and deciding what attributes to use in the URL. Should I include the city name in the URL? Or does that help for SEO purposes? Other ideas of what to research or try are appreciated too. Thanks 🙂
Intermediate & Advanced SEO | | kylesuss0 -
Htaccess Redirect with %C2%A0 in URL
Below is my setup for redirects in .htaccess file in my root word press installation. The www to non-www works well, so no problems there Other page redirects work well, too (example: redirect 301 /some-page/ http://mysite.com/another-page/ (I didn't post those because I have a few too many : ) So here it goes... RewriteEngine On
Intermediate & Advanced SEO | | pepsimoz
RewriteCond %{HTTP_HOST} ^www.mysite.com$ [NC]
RewriteRule ^(.*)$ http://mysite.com/$1 [R=301,L] BEGIN WordPress <ifmodule mod_rewrite.c="">RewriteEngine On
RewriteBase /
RewriteRule ^index.php$ - [L]
RewriteCond %{REQUEST_FILENAME} !-f
RewriteCond %{REQUEST_FILENAME} !-d
RewriteRule . /index.php [L]</ifmodule> END WordPress redirect 301 /archives/10-college- majors/ http://mysite.com/archives/10-college-majors/ redirect 301 /archives/10-college-%20majors/ http://mysite.com/archives/10-college-majors/ redirect 301 /archives/10-college-%C2%A0majors/ http://mysite.com/archives/10-college-majors/ I'm having a problem with the last 301 redirect: redirect 301 /archives/10-college-%C2%A0majors/ http://mysite.com/archives/10-college-majors/ not working... As you can see I've tried using other varations of the "space" but no go. I also used a redirect in cPanel's Redirect screen; testing all the possible options + wildcard I've also tried this: http://serverfault.com/questions/201829/using-special-characters-in-apache-mod-rewrite-rule (perhaps unsuccessfully, because it caused a 500 server error and it's a different situation in my case) I also saw something here: http://www.webmasterworld.com/apache/3908682.htm but I don't know if it works and how I would implement that + do so without compromising ALL other redirects. Note: the URL displays with a space in the address bar of all major web browsers: http://mysite.com/10-college- majors/ and goes to a 404 page I have a goregous page / PR6 / high authority site linking to the URL on my site, but they copied the URL with a space somehow. I contacted the person responsible for the website and he claims it works fine (aka he didn't check it). Is there a clean way to redirect ONLY this problematic URL without compromising other redirects, etc? Any ideas would be great. I'll respond with progress. Thanks in advance. UPDATE the redirect works, and it did work. Even so, when looking at source of page linking to mine, the URL looks like this: ``` http://mysite.com/archives/10-college- majors/ Clicking the URL in Source View in FireFox takes me to ``` http://mysite.com/archives/10-college-%C2%A0majors/ none of my 301 redirects should direct there. I don't have any redirect plugins either.0
