Schema markup for Webinars
I'm looking for a solution to implement schema markup for our webinars. We have an events page that has a list of upcoming events, as well as a list of the webinars we've done with a link to YouTube to watch the webinar. The webinars on our events page have the title and date. What kind of schema markup can we implement for these past events? It is not really an event, but it's not a video either (unless we embed the video on our site). Any tips? (**Also, I would like to use JSON-LD instead of HTML to implement the schema). Thanks!
The event does not have all required information in the eyes of Google. Will that harm the site?
If a lot is missing YES you need dates.
http://i.imgur.com/gT3JDhw.png
Raw structured data extracted from the page:
- http://linter.structured-data.org/?url=https:%2F%2Fwww.woorank.com%2Fen%2Fblog%2Frich-snippets-what-why-and-how-to-implement
- http://www.seoskeptic.com/structured-data-markup-validation-testing-tools/
- http://json-ld.org/playground/
- https://www.woorank.com/en/blog/rich-snippets-what-why-and-how-to-implement
Thank you! This helps a lot.
Follow-up question... The event does not have all required information in the eyes of Google. Will that harm the site? Or is it ok if we don't have every parameter... See screenshot for example of the info that I can markup: http://screencast.com/t/KPkUvHvmZaf
Utilizing past events will be will be able to instruct Google that you are having a consistent event cycle whatever length of time that is. So I do recommend doing it. JSON-LD has been, recommended for events.
In the past, Google has suggested Microdata. For websites and JSON-LD for apps however since their overhaul the new schema testing system, it seems like they have gone 100% JSON-LD in their recent "recommendations" for events.
("Try out the following examples using the Structured Data Testing Tool. All examples show JSON-LD syntax. If you prefer, you can use Microdata or RDFa syntax.")
JSON-LD His extremely lightweight but is invisible to the end-user. Microdata Is visible to the end-user.I would base it on what makes sense for your website. I do not know if you are utilizing app?If you are currently using microdata, it is still supported. If you are looking to use schema for the first time, I would recommend JSON-LD for apps and Microdata for end-users.
https://developers.google.com/search/docs/data-types/events#use-cases
https://search.google.com/structured-data/testing-tool
https://blog.kissmetrics.com/get-started-using-schema/ I would use Google's schema generator for JSON-LD or one of these options for microdata
http://schema-creator.org/event.php
http://microdatagenerator.org/
Below are two examples of the different styles and keep in mind microdata is visible
Microdata. event example I created.
descriptionStarts: 06/30/2016 12:00PM
Ends: 2016-07-01:00.000
Duration: 22:42
1313 Mockingbird Ln.Nowhere, FL32789United States
JSON-LD
** I hope this is been of help,**
** Thomas**
Schema Markup Warning "Missing field "url" (optional)"
Hello Moz Team, I hope everyone is doing well & good, I need bit help regarding Schema Markup, I am facing issue in my schema markup specifically with my blog posts, In my majority of the posts I find error "Missing field "url" (optional)"
Technical SEO | | JoeySolicitor
As this schema is generated by Yoast plugin, I haven't applied any custom steps. Recently I published a post https://dailycontributors.com/kisscartoon-alternatives-and-complete-review/ and I tested it at two platforms of schema test 1, Validator.Schema.org
2. Search.google.com/test/rich-results So the validator generate results as follows and shows no error
Schema without error.PNG It shows no error But where as Schema with error.PNG in search central results it gives me a warning "Missing field "url" (optional)". So is this really be going to issue for my ranking ? Please help thanks!6 -
Inconsistency between content and structured data markup
Hi~ everyone What does Google think about the inconsistency between content and structured data markup? Is this kind of a cheating way ? Is hurt my SEO?
Technical SEO | | intern2020120 -
Product Schema Markup for All Products
Hi Team, Google search console used to allow you to use their structured data markup helperhttps://www.google.com/webmasters/markup-helper/u/0/ to markup multiple product pages at once that were similar. I do not see this feature anymore with the new search console. Does anyone have a recommendation for marking up multiple product pages without having to have schema markup firing in GTM for each product page?
Technical SEO | | agrier0 -
Product schema with no offer as owner wants to give price per customer
Hi, Trying to markup products for a site that does not show prices. Is there any way to markup a product price when the business model is: 1. customer calls or contacts shop. 2. shop gives a price quote based on level of detail and finish on the product 3. there is no base or top price. Thanks in advance!
Technical SEO | | plahpoy0 -
Schema for blogs
When I run a wordpress blog through the structured data testing tool I see that there is @type hentry. Is this enough for blogs etc? Is this a result of Wordpress adding in this markup? Do you recommend adding @blogposting type and if so why? What benefit to add a specific type of schema? How does it help in blogging? Thanks
Technical SEO | | AL123al4 -
Schema Markup Errors - Priority or Not?
Greetings All... I've been digging through the search console on a few of my sites and I've been noticing quite a few structured data errors. Most of the errors are related to: hcard, hentry and hatom. Most of them are missing author & entry-title, while the other one is missing: fn. I recently saw an article on SEL about Google's focus on spammy mark-up. The sites I use are built and managed by vendors, so I would have to impress upon them the impact of these errors and have them prioritize, then fix them. My question is whether or not this should be prioritized? Should I have them correct these errors sooner than later or can I take a phased approach? I haven't noticed any loss in traffic or anything like that, I'm more focused on what negative impact a "phased approach" could have. Any thoughts?
Technical SEO | | AfroSEO0 -
Can you mark up a page using Schema.org and Facebook Open Graph?
Is it possible to use both Schema.org and Facebook Open Graph for structured data markup? On the Google Webmaster Central blog, they say, "you should avoid mixing the formats together on the same web page, as this can confuse our parsers." Source - http://googlewebmastercentral.blogspot.com/2011/06/introducing-schemaorg-search-engines.html
Technical SEO | | SAMarketing1 -
Schema for Price Comparison Services - Good or Bad?
Hey guys, I was just wondering what the whole schema.org markup means for people that run search engines (i.e. for a niche, certain products) or price comparison engines in general. The intend behind schema.org was to help the engines better understand the pages content. Well, I guess such services don't necessarily want Google to understand that they're just another search engine (and thus might get thrown out of the index for polluting it with search result pages). I see two possible scenarios: either not implement them or implement them in a way that makes the site not look like an aggregator, i.e. by only marking up certain products with unique text. Any thoughts? Does the SEOmoz team has any advice on that? Best,
Technical SEO | | derderko
schuon0
