Home page suddenly dropped from index!!
A client's home page, which has always done very well, has just dropped out of Google's index overnight!
Webmaster tools does not show any problem. The page doesn't even show up if we Google the company name.The Robot.txt contains:
Default Flywheel robots file
User-agent: *
Disallow: /calendar/action:posterboard/
Disallow: /events/action~posterboard/The only unusual thing I'm aware of is some A/B testing of the page done with 'Optimizely' - it redirects visitors to a test page, but it's not a 'real' redirect in that redirect checker tools still see the page as a 200. Also, other pages that are being tested this way are not having the same problem.
Other recent activity over the last few weeks/months includes linking to the page from some of our blog posts using the page topic as anchor text.
Any thoughts would be appreciated.
Caro -
Woot! So glad to see it wasn't a penalty!
Michael,
Duplicate content wasn't the issue in the end, but your response prompted me to analyse their home page text more closely and I discovered that there was room for improvement - too much of the home page content was also present on other pages of the site. Thanks for that!
Everyone, this has been resolved! The problem turned out to be a code error in the canonical tag for the page. There was an extra space and slash. Ironically, the canonical tag was one of the first things we looked at, yet we all overlooked that error
Thank you all so much for your input and assistance.
Thank you Michael...I'll do that.
I've seen a client have an internal page just suddenly be de-indexed. What appears to have happened is that Google saw it as a near duplicate of another page on their site, and dropped it from the index for that reason. Then, magically, it reappeared a week later.
You may be seeing something like this here. See what Moz Pro thinks in terms of duplicate content on your site, and if the home page gets called out along with another page.
Thanks so much for that info. I had not heard of Kerboo...I'll definitely check that out right away. Your input has been extremely helpful Kristina.
Caro
I would be incredibly surprised if internal links to the homepage caused the issue. Google expects you to have a bunch of internal links to the homepage.
What you're going to need to do now is do a thorough review of all of the external links pointing to your homepage. I would do this with a tool - I recommend Kerboo, although I'm sure there are others that could do the same thing. Otherwise, you can look through all of the links yourself and look for spam indications (steps outlined in this handy Moz article).
Either way, make sure that you pull your list of links from Ahrefs or Majestic. Ideally both, and merge the lists. Moz doesn't crawl nearly as many links.
Since you haven't gotten a manual penalty warning, you're going to have to take as many of the spammy links you find down as you can and disavow the others. For speed, I'd recommend that you immediately upload a list of spammy links with Google's disavow tool, then start asking for an actual removal.
Keep in mind that you're probably going to disavow links that were helping rankings, so expect that your homepage won't come back ranking as well for nonbranded search terms as it used to. You'll probably want to start out uploading a very conservative set of URLs to the disavow tool, wait a couple of days to see if that fixes the problem, upload a bigger set, check, etc.
Good luck!
No luck Kristina
I'm wondering if it's an algorithmic penalty in response to back links. We've never done shady linking, but over the years the site has gathered some strange links. Or, is there some chance that about two dozen anchor text links from their blog to the home page could have done it? I deleted them. But I can't request reconsideration if the penalty isn't manual.
Any luck so far? Usually it only takes a few hours for Google to crawl new pages after you submit them in GSC, in my experience.
I see no serious crawl issues. Mostly things we're already addressing, like duplicate content caused by blog tags and categories, missing meta descriptions (mostly in our knowledge base, so not an issue) and stuff like that.
When I checked the home page alone it said zero high, medium or low priority issues.
The page only de-indexed very recently. Maybe the next crawl will catch something. Same with GSC...it looks like the last 2 days of info is not available yet.
I should mention the home page Optimizely test had been running for at least a week before the page got dropped (will get actual date from client) , plus they have had a product page running a test for weeks with no problem. But I still think your suggestion to pause the test is a good one as I don't want anything to hinder the process of fixing this.
Update: Optimizely has been paused, code removed, home page submitted in GSC.
Okay, I ran some tests, and can't see anything that could've gone wrong. That does make it seem like a penalty, but given that this coincided with setting up Optimizely, let's go down that path first.
While your team is taking down the test - have you checked Moz to see if its crawler sees anything that could be causing an issue? I set up my Moz crawler to look into it, but it'll take a few days.
Thanks Kristina,
We have not tried pausing the test, but I can request they do that. It may be a good idea to do it regardless of whether it's causing the problem or not, while we get this issue sorted out.
Fetch as Google gave this result:HTTP/1.1 200 OK - so looks ok. I understand this also submits your page to Google as an actual indexing request?
site:https://website.com shows all our pages except the home page.
So, it looks like it's decided not to rank it for some reason.
I deleted some links from the blog to the home page - they had a keyword phrase as the anchor text. There were about 20 links that had accumulated over a few months. Not sure if that's the issue.
Still no manual penalty notice from Google.
Hm, I've done a lot with Optimizely in the past, and it's never caused an SEO problem, but it's completely possible something went wrong. Since that's your first inkling, have you tried pausing that test and removing the Optimizely code from the homepage? Then you can determine whether or not it's an Optimizely problem.
Another thing you can do is use the Fetch as Googlebot feature in GSC. Does GSC say it can fetch the page properly?
If it says it can, try searching for "site:www.yourcompanysite.com". This will show if Google's got your URL in its index. If nothing comes up, it's not there; if it comes up, Google's decided not to rank it for some reason.
After those steps, get back to us so we can figure out where to go from there!
Good luck,
Kristina
Jordan, not on the original version of the home page, but there is on the B test version.
The way I understand it the B version is a javascript page that is noindexed. Their redirect system seems to leave the original page looking like there is no redirect. Are you suggesting we use a 302 instead? -
Also, Google recommends you 302 those url's instead of returning a 200 http code. You can read more about their best practices about a/b testing.
Is there a 'meta no index no follow tag' implemented by chance?
E-Commerce Site Collection Pages Not Being Indexed
Hello Everyone, So this is not really my strong suit but I’m going to do my best to explain the full scope of the issue and really hope someone has any insight. We have an e-commerce client (can't really share the domain) that uses Shopify; they have a large number of products categorized by Collections. The issue is when we do a site:search of our Collection Pages (site:Domain.com/Collections/) they don’t seem to be indexed. Also, not sure if it’s relevant but we also recently did an over-hall of our design. Because we haven’t been able to identify the issue here’s everything we know/have done so far: Moz Crawl Check and the Collection Pages came up. Checked Organic Landing Page Analytics (source/medium: Google) and the pages are getting traffic. Submitted the pages to Google Search Console. The URLs are listed on the sitemap.xml but when we tried to submit the Collections sitemap.xml to Google Search Console 99 were submitted but nothing came back as being indexed (like our other pages and products). We tested the URL in GSC’s robots.txt tester and it came up as being “allowed” but just in case below is the language used in our robots:
Intermediate & Advanced SEO | | Ben-R
User-agent: *
Disallow: /admin
Disallow: /cart
Disallow: /orders
Disallow: /checkout
Disallow: /9545580/checkouts
Disallow: /carts
Disallow: /account
Disallow: /collections/+
Disallow: /collections/%2B
Disallow: /collections/%2b
Disallow: /blogs/+
Disallow: /blogs/%2B
Disallow: /blogs/%2b
Disallow: /design_theme_id
Disallow: /preview_theme_id
Disallow: /preview_script_id
Disallow: /apple-app-site-association
Sitemap: https://domain.com/sitemap.xml A Google Cache:Search currently shows a collections/all page we have up that lists all of our products. Please let us know if there’s any other details we could provide that might help. Any insight or suggestions would be very much appreciated. Looking forward to hearing all of your thoughts! Thank you in advance. Best,0 -
How to check if the page is indexable for SEs?
Hi, I'm building the extension for Chrome, which should show me the status of the indexability of the page I'm on. So, I need to know all the methods to check if the page has the potential to be crawled and indexed by a Search Engines. I've come up with a few methods: Check the URL in robots.txt file (if it's not disallowed) Check page metas (if there are not noindex meta) Check if page is the same for unregistered users (for those pages only available for registered users of the site) Are there any more methods to check if a particular page is indexable (or not closed for indexation) by Search Engines? Thanks in advance!
Intermediate & Advanced SEO | | boostaman0 -
Google indexing only 1 page out of 2 similar pages made for different cities
We have created two category pages, in which we are showing products which could be delivered in separate cities. Both pages are related to cake delivery in that city. But out of these two category pages only 1 got indexed in google and other has not. Its been around 1 month but still only Bangalore category page got indexed. We have submitted sitemap and google is not giving any crawl error. We have also submitted for indexing from "Fetch as google" option in webmasters. www.winni.in/c/4/cakes (Indexed - Bangalore page - http://www.winni.in/sitemap/sitemap_blr_cakes.xml) 2. http://www.winni.in/hyderabad/cakes/c/4 (Not indexed - Hyderabad page - http://www.winni.in/sitemap/sitemap_hyd_cakes.xml) I tried searching for "hyderabad site:www.winni.in" in google but there also http://www.winni.in/hyderabad/cakes/c/4 this link is not coming, instead of this only www.winni.in/c/4/cakes is coming. Can anyone please let me know what could be the possible issue with this?
Intermediate & Advanced SEO | | abhihan0 -
Getting Pages Requiring Login Indexed
Somehow certain newspapers' webpages show up in the index but require login. My client has a whole section of the site that requires a login (registration is free), and we'd love to get that content indexed. The developer offered to remove the login requirement for specific user agents (eg Googlebot, et al.). I am afraid this might get us penalized. Any insight?
Intermediate & Advanced SEO | | TheEspresseo0 -
How long does google take to show the results in SERP once the pages are indexed ?
Hi...I am a newbie & trying to optimize the website www.peprismine.com. I have 3 questions - A little background about this : Initially, close to 150 pages were indexed by google. However, we decided to remove close to 100 URLs (as they were quite similar). After the changes, we submitted the NEW sitemap (with close to 50 pages) & google has indexed those URLs in sitemap. 1. My pages were indexed by google few days back. How long does google take to display the URL in SERP once the pages get indexed ? 2. Does google give more preference to websites with more number of pages than those with lesser number of pages to display results in SERP (I have just 50 pages). Does the NUMBER of pages really matter ? 3. Does removal / change of URLs have any negative effect on ranking ? (Many of these URLs were not shown on the 1st page) An answer from SEO experts will be highly appreciated. Thnx !
Intermediate & Advanced SEO | | PepMozBot0 -
Why does my home page show up in search results instead of my target page for a specific keyword?
I am using Wordpress and am targeting a specific keyword..and am using Yoast SEO if that question comes up.. and I am at 100% as far as what they recommend for on page optimization. The target html page is a "POST" and not a "Page" using Wordpress definitions. Also, I am using this Pinterest style theme here http://pinclone.net/demo/ - which makes the post a sort of "pop-up" - but I started with a different theme and the results below were always the case..so I don't know if that is a factor or not. (I promise .. this is not a clever spammy attempt to promote their theme - in fact parts of it don't even work for me yet so I would not recommend it just yet...) I DO show up on the first page for my keyword.. however.. instead of Google showing the page www.mywebsite.com/this-is-my-targeted-keyword-page.htm Google shows www.mywebsite.com in the results instead. The problem being - if the traffic goes only to my home page.. they will be less likely to stay if they dont find what they want immediately and have to search for it.. Any suggestions would be appreciated!
Intermediate & Advanced SEO | | chunkyvittles0 -
Google is indexing wordpress attachment pages
Hey, I have a bit of a problem/issue what is freaking me out a bit. I hope you can help me. If i do site:www.somesitename.com search in Google i see that Google is indexing my attachment pages. I want to redirect attachment URL's to parent post and stop google from indexing them. I have used different redirect plugins in hope that i can fix it myself but plugins don't work. I get a error:"too many redirects occurred trying to open www.somesitename.com/?attachment_id=1982 ". Do i need to change something in my attachment.php fail? Any idea what is causing this problem? get_header(); ?> /* Run the loop to output the attachment. * If you want to overload this in a child theme then include a file * called loop-attachment.php and that will be used instead. */ get_template_part( 'loop', 'attachment' ); ?>
Intermediate & Advanced SEO | | TauriU0 -
301 - should I redirect entire domain or page for page?
Hi, We recently enabled a 301 on our domain from our old website to our new website. On the advice of fellow mozzer's we copied the old site exactly to the new domain, then did the 301 so that the sites are identical. Question is, should we be doing the 301 as a whole domain redirect, i.e. www.oldsite.com is now > www.newsite.com, or individually setting each page, i.e. www.oldsite.com/page1 is now www.newsite.com/page1 etc for each page in our site? Remembering that both old and new sites (for now) are identical copies. Also we set the 301 about 5 days ago and have verified its working but haven't seen a single change in rank either from the old site or new - is this because Google hasn't likely re-indexed yet? Thanks, Anthony
Intermediate & Advanced SEO | | Grenadi0
