Need a layman's definition/analogy of the difference between schema and structured data
I'm currently writing a blog post about schema. However I want to set the record straight that schema is not exactly the same as structured data, although both are often used interchangeably. I understand this schema.org is a vocabulary of global identifiers for properties and things. Structured data is what Google officially stated as "a standard way to annotate your content so machines can understand it..."
Does anybody know of a good analogy to compare the two?
Hi Rosemary, Dave here.
I like to think of it like our addressing system. Because we all use the same system and format for our addresses on an envelope we don't need a code to tell us but as you know ... everyone displays their product information and other data differently on a page. Because of that the engines can have difficulty telling what bit of data is what. Is "blue" the color of the product, the color of the screen or simply used on the page in a "Don't feel blue ... buy XYZ !"
Structured data, as Matt well-noted, is just an idea really of matching information with what it means. Like saying "blue" = "product color".
Of course, that's all well-and-good but we can all build our own systems and many have been. If we're all using different systems then nothing makes sense so folks got together and created Schema.org simply as a body that could help create a standard. Like saying, "on an envelop you put the name first, then the address, then the city, then the state, then the zip code". If we put things on the envelop differently things would get messy so Schema basically gives us the instruction on how to pass information across. Schema isn't the idea or even the data, it's the instructions on how to tell Google what specific data means.
Clear as mud?
Well, let's see.
Structured data in this sense comes down to a method of labelling elements of your site in order to clarify what they are for search engine crawlers, microdata is a form of structured data that works in HTML5, and Schema is a standard for microdata. So Schema is microdata is structured data. All Schema (in this use) is structured data, but not all structured data is Schema.
Maybe something like, if structured data represents all the team sports in the world, and microdata represents every game intended to be played on a football pitch, then Schema may be the Laws of the Game—the standard rules for international soccer.
Also, go Seattle Sounders!
Yes, thank you. However I'm looking for a simple layman's analogy. Most of the blog post readers are not going to be able to comprehend the technical aspects.
Hi Rosemary! There's actually a pretty decent explanation here: https://cloudz.click/learn/seo/schema-structured-data
Structured data is a system of pairing a name with a value that helps search engines categorize and index your content. Microdata is one form of structured data that works with HTML5. Schema.org is a project that provides a particular set of agreed-upon definitions for microdata tags.
Does that make sense?
Magento: Should we disable old URL's or delete the page altogether
Our developer tells us that we have a lot of 404 pages that are being included in our sitemap and the reason for this is because we have put 301 redirects on the old pages to new pages. We're using Magento and our current process is to simply disable, which then makes it a a 404. We then redirect this page using a 301 redirect to a new relevant page. The reason for redirecting these pages is because the old pages are still being indexed in Google. I understand 404 pages will eventually drop out of Google's index, but was wondering if we were somehow preventing them dropping out of the index by redirecting the URL's, causing the 404 pages to be added to the sitemap. My questions are: 1. Could we simply delete the entire unwanted page, so that it returns a 404 and drops out of Google's index altogether? 2. Because the 404 pages are in the sitemap, does this mean they will continue to be indexed by Google?
Intermediate & Advanced SEO | | andyheath0 -
Benefits/drawbacks to different Schema markup languages (ie. JSON-LD, Microdata, RDFa)
Just a question (or questions) I have wondered about. What's the difference, besides the actual encoding, between the three? Why have three? Why not just the one? Seems to me that Microdata is the easiest, but maybe I am wrong. Is there a reason to use one versus another? I have not found anything explaining this on schema.org - I suppose this is just a discussion versus getting one right or wrong answer. I am just curious of the opinions of people in the SEO MOZ community. Unless of course there is one answer. I'll take that too.
Intermediate & Advanced SEO | | Brian_Dowd1 -
How to prevent 404's from a job board ?
I have a new client with a job listing board on their site. I am getting a bunch of 404 errors as they delete the filled jobs. Question: Should we leave the the jobs pages up for extra content and entry points to the site and put a notice like this job has been filled, please search our other job listings ? Or should I no index - no follow these pages ? Or any other suggestions - it is an employment agency site. Overall what would be the best practice going forward - we are looking at probably 20 jobs / pages per month.
Intermediate & Advanced SEO | | jlane90 -
Include Cross Domain Canonical URL's in Sitemap - Yes or No?
I have several sites that have cross domain canonical tags setup on similar pages. I am unsure if these pages that are canonicalized to a different domain should be included in the sitemap. My first thought is no, because I should only include pages in the sitemap that I want indexed. On the other hand, if I include ALL pages on my site in the sitemap, once Google gets to a page that has a cross domain canonical tag, I'm assuming it will just note that and determine if the canonicalized page is the better version. I have yet to see any errors in GWT about this. I have seen errors where I included a 301 redirect in my sitemap file. I suspect its ok, but to me, it seems that Google would rather not find these URL's in a sitemap, have to crawl them time and time again to determine if they are the best page, even though I'm indicating that this page has a similar page that I'd rather have indexed.
Intermediate & Advanced SEO | | WEB-IRS0 -
Adding index.php at the end of the url effect it's rankings
I have just had my site updated and we have put index.php at the end of all the urls. Not long after the sites rankings dropped. Checking the backlinks, they all go to (example) http://www.website.com and not http://www.website.com/index.php. So could this change have effected rankings even though it redirects to the new url?
Intermediate & Advanced SEO | | authoritysitebuilder0 -
Posing QU's on Google Variables "aclk", "gclid" "cd", "/aclk" "/search", "/url" etc
I've been doing a bit of stats research prompted by read the recent ranking blog http://www.seomoz.org/blog/gettings-rankings-into-ga-using-custom-variables There are a few things that have come up in my research that I'd like to clear up. The below analysis has been done on my "conversions". 1/. What does "/aclk" mean in the Referrer URL? I have noticed a strong correlation between this and "gclid" in the landing page variable. Does it mean "ad click" ?? Although they seem to "closely" correlate they don't exactly, so when I have /aclk in the referrer Url MOSTLY I have gclid in the landing page URL. BUT not always, and the same applies vice versa. It's pretty vital that I know what is the best way to monitor adwords PPC, so what is the best variable to go on? - Currently I am using "gclid", but I have about 25% extra referral URL's with /aclk in that dont have "gclid" in - so am I underestimating my number of PPC conversions? 2/. The use of the variable "cd" is great, but it is not always present. I have noticed that 99% of my google "Referrer URL's" either start with:
Intermediate & Advanced SEO | | James77
/aclk - No cd value
/search - No cd value
/url - Always contains the cd variable. What do I make of this?? Thanks for the help in advance!0 -
Is 404'ing a page enough to remove it from Google's index?
We set some pages to 404 status about 7 months ago, but they are still showing in Google's index (as 404's). Is there anything else I need to do to remove these?
Intermediate & Advanced SEO | | nicole.healthline0 -
URL Length or Exact Breadcrumb Navigation URL? What's More Important
Basically my question is as follows, what's better: www.romancingdiamonds.com/gemstone-rings/amethyst-rings/purple-amethyst-ring-14k-white-gold (this would fully match the breadcrumbs). or www.romancingdiamonds.com/amethyst-rings/purple-amethyst-ring-14k-white-gold (cutting out the first level folder to keep the url shorter and the important keywords are closer to the root domain). In this question http://www.seomoz.org/qa/discuss/37982/url-length-vs-url-keywords I was consulted to drop a folder in my url because it may be to long. That's why I'm hesitant to keep the bradcrumb structure the same. To the best of your knowldege do you think it's best to drop a folder in the URL to keep it shorter and sweeter, or to have a longer URL and have it match the breadcrumb structure? Please advise, Shawn
Intermediate & Advanced SEO | | Romancing0
