Sitemap with homepage URL repeated several times - it is a problem?
Hello Mozzers,
I am looking at a website with the homepage repeated several times (4 times) on the sitemap (sitemap is autogenerated via a plugin) - is this an SEO problem do you think - might it damage SEO performance, or can I ignore this issue?
I am thinking I can ignore, yet it's an odd "issue" so your advice would be welcome!
Thanks, Luke
Many thanks Eric - much appreciated - that clarifies everything perfectly
Generally speaking, this is normal, and you shouldn't have to worry about it. There's a Google Webmaster thread that pointed to this issue specifically, and Google gave an official response (https://www.seroundtable.com/google-sitemaps-duplicate-16128.html)
"This is apparently normal if you submit Sitemap files with the same URLs listed multiple times. Since submitting the same URLs multiple times doesn't change anything with regards to your site's crawling & indexing, I'd just submit it once if you want the correct counts (alternately, if the count doesn't bother you, you can also just leave it like this."
This url is not allowed for a Sitemap at this location error using pro-sitemaps.com
Hey, guys, We are using the pro-sitemaps.com tool to automate our sitemaps on our properties, but some of them give this error "This url is not allowed for a Sitemap at this location" for all the urls. Strange thing is that not all of them are with the error and most have all the urls indexed already. Do you have any experience with the tool and what is your opinion? Thanks
Intermediate & Advanced SEO | | lgrozeva0 -
URL structure change and xml sitemap
At the end of April we changed the url structure of most of our pages and 301 redirected the old pages to the new ones. The xml sitemaps were also updated at that point to reflect the new url structure. Since then Google has not indexed the new urls from our xml sitemaps and I am unsure of why. We are at 4 weeks since the change, so I would have thought they would have indexed the pages by now. Any ideas on what I should check to make sure pages are indexed?
Intermediate & Advanced SEO | | ang0 -
Magento Trailing Slash URL Problem
Howdy Mozzers! Our magento store URL's are accessible with or without a trailing slash at the end. Canonical's and 301 redirects are not set up for one of them at the moment. Will this cause duplicate issue? Do we need to set canonical or 301 up? Which one is recommended? MozAddict
Intermediate & Advanced SEO | | MozAddict0 -
Does having a ? on the end of your URL affect your SEO?
I have some redirects that were done with at "?" at the end of the URL to include google coding (i.e. you click on an adwords link and the google coding follows the redirected link). When there is not coding to follow the link just appears as "filename.html?". Will that affect us negatively SEO-wise? Thank you.
Intermediate & Advanced SEO | | RoxBrock1 -
Is using dots in URL path really a problem?
we have a couple of pages displaying a dot in the URL path like domain.com/mr.smith/widget-mr.smith It displays fine in chrome, firefox and IE and for the user it may actually look better than replacing it by _ or -. Did this ever cause problems to anybody?
Intermediate & Advanced SEO | | lcourse
Any statement from google about it?
Should I change existing URLs? If so, which other characters can I use in the URL instead of underscore and dash, since in our system dash and underscore are already used for rewriting other characters. Thanks0 -
302 redirects in the sitemap?
My website uses a prefix at the end to instruct the back-end about visitor details. The setup is similar to this site - http://sanfrancisco.giants.mlb.com/index.jsp?c_id=sf with a 302 redirect from the normal link to the one with additional info and a canonical tag on the actual URL without the extra info ((the normal one here being http://sanfrancisco.giants.mlb.com,) However, when I used www.xml-sitemaps.com to create a sitemap they did so using the URLs with the extra info on the links... what should I do to create a sitemap using the normal URLs (which are the ones I want to be promoting)
Intermediate & Advanced SEO | | theLotter0 -
Overly-Dynamic URL
Hi, We have over 5000 pages showing under Overly-Dynamic URL error Our ecommerce site uses Ajax and we have several different filters like, Size, Color, Brand and we therefor have many different urls like, http://www.dellamoda.com/Designer-Pumps.html?sort=price&sort_direction=1&use_selected_filter=Y http://www.dellamoda.com/Designer-Accessories.html?sort=title&use_selected_filter=Y&view=all http://www.dellamoda.com/designer-handbags.html?use_selected_filter=Y&option=manufacturer%3A&page3 Could we use the robots.txt file to disallow these from showing as duplicate content? and do we need to put the whole url in there? like: Disallow: /*?sort=price&sort_direction=1&use_selected_filter=Y if not how far into the url should be disallowed? So far we have added the following to our robots,txt Disallow: /?sort=title Disallow: /?use_selected_filter=Y Disallow: /?sort=price Disallow: /?clearall=Y Just not sure if they are correct. Any help would be greatly appreciated. Thank you,Kami
Intermediate & Advanced SEO | | dellamoda2 -
Where to link to HTML Sitemap?
After searching this morning and finding unclear answers I decided to ask my SEOmoz friends a few questions. Should you have an HTML sitemap? If so, where should you link to the HTML sitemap from? Should you use a noindex, follow tag? Thank you
Intermediate & Advanced SEO | | cprodigy290
