What is best practice for "Sorting" URLs to prevent indexing and for best link juice ?
We are now introducing 5 links in all our category pages for different sorting options of category listings.
The site has about 100.000 pages and with this change the number of URLs may go up to over 350.000 pages.
Until now google is indexing well our site but I would like to prevent the "sorting URLS" leading to less complete crawling of our core pages, especially since we are planning further huge expansion of pages soon.Apart from blocking the paramter in the search console (which did not really work well for me in the past to prevent indexing) what do you suggest to minimize indexing of these URLs also taking into consideration link juice optimization?
On a technical level the sorting is implemented in a way that the whole page is reloaded, for which may be better options as well.
With canonicals, I would not worry about the incoming pages. If the new content is useful and relevant, plus linked to internally, they should do fine in terms of indexation. Use the canonical for now, and once you launch the new pages, well a month after launch, if there are key pages not getting indexed, then you can reassess. The canonical is the right thing to do in this case.
As for link equity, you are right, that is a simplistic view of it. It is actually much more intricate than that, but that's a good basic understanding. However, the canonical is not going to hurt your internal link equity. Those links to the different sorting are navigational in nature and the structure will be repeated throughout the site. Google's algo is good at determining internal, editorial links versus those that are navigational in nature. The navigational links don't impact the strength nearly as much as an editorial link.
My personal belief is that you are worrying about something that isn't going to make an impact on your organic traffic. Ensure the correct canonicals are in place and launch the new content. If that new content has the same issue with sorting, use canonicals there as well and let Google figure it out. "They" have gotten pretty good at identifying what to keep and what not.
If you don't want the sorting pages in there at all, you'll need to do one of the following:
- Noindex, disallow in robots.txt - Rhea Drysdale showed me a few years back that you can do a disallow and noindex in robots. If you do both, Google gets the command to not only noindex the URLs, but also cannot crawl the content.
- Noindex, nofollow using meta robots - This would stop all link equity flow from these pages. If you want to attempt to stop flow to these pages, you'll need to nofollow any links to them. The pages can still be crawled however.
- Noindex, follow - Same as above but internal link equity would still flow. Again, if you want to attempt to cut off link equity to these sorting pages, any links to them would need to be nofollowed.
- Disallow in robots - This would stop them from crawling the content, but the URLs could technically still be indexed.
Personally, I believe trying to manage link equity using nofollow is a waste of time. You more than likely have other things that could be making larger impacts. The choice is yours however and I always recommend testing anything to see if it makes an impact.
Kate. The domain has 100.000 pages and will scale to over 1 million unique pages during the next couple of months. I do not want the Sorting URLs have any negative effect on the new indexing of the new 900.000 unique pages in the next months.
Regarding link equity. My simplified understanding of link equity is that if a page has 10 links then each link carries 10% of the total link juice of the page. If now 5 of the 10 links do link to a canonical version of the same page (=sorting URLs), I may be losing out on 50% of the potential link juice the page carries. This is my concern. Therefore my doubt is if I should rather try to hide these sorting URLs from google (same as was also recommended by Rand for facetted navigation pages that one does not consider important for being indexed).
Is your issue with crawling or indexing? Those are two separate issues. Why don't you want Google having the canonicals in the index? If you can give me some more insight, I can try to recommend the best option.
And I'm not following your last question. Can you try to ask it another way?
Hi Kate, thanks lot. Yes canonical is something we should definetly do and we have implemented.
Still I had the experience in the past that google also indexed lots of canonicalized URLs with near identical content. Any additional step I could do to minimize indexing of these URLs further?
Wouldn't then the basically "self referencing" URLS of sorting links (going to canonicalized versions of the same page) be lost for link equity?
This one would need a canonical. For one category page with 5 different sort options, you'd need one canonical URL (one without any sorting or the default sorting) and point all others to that URL using a canonical tag.
https://support.google.com/webmasters/answer/139066?hl=en
Would that work for your setup? If I understand your situation correctly, this should work. It consolidates link equity and allows Google to choose what needs to be indexed and served.
Best way to set up URL structure for reviews off of PDP pages.
We are adding existing customer reviews to Product Detail Pages pages. There are about 300 reviews per product so we're going to have to paginate reviews off of the PDP page. I'm wondering what the best url structure for reviews pages is to get the most seo benefit. For example, would it be something like this? site.com/category/product/reviews/page-1 or something that used parameters, such as: site.com/reviews?product=a Also, what is the best way to show that the internal link on the PDP page to "All Reviews" is a higher priority link than the other links on the page?
Intermediate & Advanced SEO | | katseo10 -
Best Practices for Title Tags for Product Listing Page
My industry is commercial real estate in New York City. Our site has 300 real estate listings. The format we have been using for Title Tags are below. This probably disastrous from an SEO perspective. Using number is a total waste space. A few questions:
Intermediate & Advanced SEO | | Kingalan1
-Should we set listing not no index if they are not content rich?
-If we do choose to index them, should we avoid titles listing Square Footage and dollar amounts?
-Since local SEO is critical, should the titles always list New York, NY or Manhattan, NY?
-I have red that titles should contain some form of branding. But our company name is Metro Manhattan Office Space. That would take up way too much space. Even "Metro Manhattan" is long. DO we need to use the title tag for branding or can we just focus on a brief description of page content incorporating one important phrase? Our site is: w w w . m e t r o - m a n h a t t a n . c o m <colgroup><col width="405"></colgroup>
| Turnkey Flatiron Tech Space | 2,850 SF $10,687/month | <colgroup><col width="405"></colgroup>
| Gallery, Office Rental | Midtown, W. 57 St | 4441SF $24055/month | <colgroup><col width="405"></colgroup>
| Open Plan Loft |Flatiron, Chelsea | 2414SF $12,874/month | <colgroup><col width="405"></colgroup>
| Tribeca Corner Loft | Varick Street | 2267SF $11,712/month | <colgroup><col width="405"></colgroup>
| 275 Madison, LAW, P7, 3,252SF, $65 - Manhattan, New York |0 -
If I nofollow outbound external links to minimize link juice loss > is it a good/bad thing?
OK, imagine you have a blog, and you want to make each blog post authoritative so you link out to authority relevant websites for reference. In this case it is two external links per blog post, one to an authority website for reference and one to flickr for photo credit. And one internal link to another part of the website like the buy-now page or a related internal blog post. Now tell me if this is a good or bad idea. What if you nofollow the external links and leave the internal link untouched so all internal links are dofollow. The thinking is this minimizes loss of link juice from external links and keeps it flowing through internal links to pages within the website. Would it be a good idea to lay off the nofollow tag and leave all as do follow? or would this be a good way to link out to authority sites but keep the link juice internal? Your thoughts are welcome. Thanks.
Intermediate & Advanced SEO | | Rich_Coffman0 -
Why is rel="canonical" pointing at a URL with parameters bad?
Context Our website has a large number of crawl issues stemming from duplicate page content (source: Moz). According to an SEO firm which recently audited our website, some amount of these crawl issues are due to URL parameter usage. They have recommended that we "make sure every page has a Rel Canonical tag that points to the non-parameter version of that URL…parameters should never appear in Canonical tags." Here's an example URL where we have parameters in our canonical tag... http://www.chasing-fireflies.com/costumes-dress-up/womens-costumes/ rel="canonical" href="http://www.chasing-fireflies.com/costumes-dress-up/womens-costumes/?pageSize=0&pageSizeBottom=0" /> Our website runs on IBM WebSphere v 7. Questions Why it is important that the rel canonical tag points to a non-parameter URL? What is the extent of the negative impact from having rel canonicals pointing to URLs including parameters? Any advice for correcting this? Thanks for any help!
Intermediate & Advanced SEO | | Solid_Gold1 -
How to de-index old URLs after redesigning the website?
Thank you for reading. After redesigning my website (5 months ago) in my crawl reports (Moz, Search Console) I still get tons of 404 pages which all seems to be the URLs from my previous website (same root domain). It would be nonsense to 301 redirect them as there are to many URLs. (or would it be nonsense?) What is the best way to deal with this issue?
Intermediate & Advanced SEO | | Chemometec0 -
How can I prevent duplicate pages being indexed because of load balancer (hosting)?
The site that I am optimising has a problem with duplicate pages being indexed as a result of the load balancer (which is required and set up by the hosting company). The load balancer passes the site through to 2 different URLs: www.domain.com www2.domain.com Some how, Google have indexed 2 of the same URLs (which I was obviously hoping they wouldn't) - the first on www and the second on www2. The hosting is a mirror image of each other (www and www2), meaning I can't upload a robots.txt to the root of www2.domain.com disallowing all. Also, I can't add a canonical script into the website header of www2.domain.com pointing the individual URLs through to www.domain.com etc. Any suggestions as to how I can resolve this issue would be greatly appreciated!
Intermediate & Advanced SEO | | iam-sold0 -
Is it a bad idea to have a "press" page and link to press mentions of our company?
We've recently been getting quite a bit of press. Would it be wise to create a "press" page and link to mentions of us or would this devalue the links on the press pages as Google may think they reciprocal?
Intermediate & Advanced SEO | | JenniferDacosta0 -
Best practice to redirects based on visitors' detected language
One of our websites has two languages, English and Italian. The English pages are available at the root level:
Intermediate & Advanced SEO | | Damiano
www.site.com/ English homepage www.site.com/page1
www.site.com/page2 The Italian pages are available under the /it/ level:
www.site.com/it Italian homepage www.site.com/it/pagina1
www.site.com/it/pagina2 When an Italian visitor first visits www.mysit.com we'd like to redirect it to www.site.com/it but we don't know if that would impact search engine spiders (eg GoogleBot) in any way... It would be better to do a Javascript redirect? Or an http 3xx redirect? If so, which of the 3xx redirect should we use? Thank you0
