Help Blocking Crawlers. Huge Spike in "Direct Visits" with 96% Bounce Rate & Low Pages/Visit.
I'm hoping one of you search geniuses can help me.
We have a successful client who started seeing a HUGE spike in direct visits as reported by Google Analytics. This traffic now represents approximately 70% of all website traffic. These "direct visits" have a bounce rate of 96%+ and only 1-2 pages/visit. This is skewing our analytics in a big way and rendering them pretty much useless. I suspect this is some sort of crawler activity but we have no access to the server log files to verify this or identify the culprit. The client's site is on a GoDaddy Managed WordPress hosting account.
The way I see it, there are a couple of possibilities.
1.) Our client's competitors are scraping the site on a regular basis to stay on top of site modifications, keyword emphasis, etc. It seems like whenever we make meaningful changes to the site, one of their competitors does a knock-off a few days later. Hmmm.2.) Our client's competitors have this crawler hitting the site thousands of times a day to raise bounce rates and decrease the average time on site, which could like have an negative impact on SEO. Correct me if I'm wrong but I don't believe Google is going to reward sites with 90% bounce rates, 1-2 pages/visit and an 18 second average time on site.
The bottom line is that we need to identify these bogus "direct visits" and find a way to block them. I've seen several WordPress plugins that claim to help with this but I certainly don't want to block valid crawlers, especially Google, from accessing the site.
If someone out there could please weigh in on this and help us resolve the issue, I'd really appreciate it. Heck, I'll even name my third-born after you.
Thanks for your help.
Eric
Hi SirMax,
Thanks for your input. I appreciate it. We'll add Wordfence to our WordPress toolbox and see if that addresses the issue.
In response to previous posts, thanks to everyone for your input. We were able to apply some filters to remove the bogus bot traffic from the analytics and normalize the data, however, this did not actually resolve the issue and in my eyes is more of a BandAid fix. The evil crawlers are still there, we just can't see them.
Thanks again for all of your input.
Eric
Hostname filtering does not work any more. Unfortunately most of the spammers have adapted and are using your website as hostname.
For the WordPress I use Wordfence plugin( using paid version - not affiliated with them in any shape or form beyond paying for their services). In the advance blocking you can set limits on how fast and how many pages crawlers can request. You can also block by country or ip range. It can also show you live traffic with a lot of details ( a lot more then google analytic - more like server log ). It might not be the complete remedy but it can help.
I wish I had an answer for how to stop the bots from hitting your site at all - I don't think a good one exists, as any solutions that wouldn't also block real human traffic to your site are going to be easy for spam bots to get around. I think your best bet is just to do everything you can to keep your data as clean as possible.
Hi Ruth,
Thanks a bunch for taking the time to respond to my post. Great advice. This is reassuring on a number of levels, however, it doesn't address the underlying issue of how to stop these spam bots in the first place.
We've already started the process of filtering out some of this bogus data. We'll also be integrating some WordPress plugins to see if that helps. That said, if the spam bots are hitting Analytics directly, as opposed to the actual website, WP plugins won't do anything.
Anyway, I appreciate your input and advice. Thanks so much.
Eric
Hi Eric,
A few things to reassure you off the bat:
- For what it's worth, there is a huge, HUGE amount of crawler spam happening in the web today. Every site I work on is being hit hard with false referrals and direct visits. I know Google Analytics is working on a solution to better filter these visits out. So I wouldn't be too concerned that it is something a competitor is doing to your site, specifically - it's more likely that it's been caught up in the general wave of spam crawlers.
- It's important to note that when we talk about Google looking at bounce rate and dwell time as part of ranking your site, those numbers are specifically from clicks through from search - that's data that Google can get without using your private web analytics data as a ranking factor, which they've said repeatedly that they don't and won't do. So a bunch of direct visits with high bounce rates will NOT affect your rankings.
So, it's not dangerous, just annoying. On to how to get that data out of your reports:
- Make sure you're not filtering out spam referrers at a View level - this can cause those visits to incorrectly appear as direct traffic.
- You could set up an Advanced Segment in Google Analytics to filter out direct visits with visit times of, say, under 5 seconds. Some real traffic may get caught in that, but it will get the noise levels down.
- The best way to filter out spam bot traffic, in my opinion, is to set up hostname filtering. Here's a post on Megalytic on how to do that: https://megalytic.com/blog/how-to-filter-out-fake-referrals-and-other-google-analytics-spam. Make sure you've also got an "Unfiltered Data" View so you'll still have historic raw data if you need it.
Hope that helps! Good luck.
Check webserver log files, or log visits (ip address, user agent, __utma, __utmz, possibly browser fingerprint, etc...)
Analyzing those you can easily find out if the traffic is from scraping bot or humans.
How important is Lighthouse page speed measurement?
Hi, Many experts cite the Lighthouse speed as an important factor for search ranking. It's confusing because several top sites have Lighthouse speed of 30-40, yet they rank well. Also, some sites that load quickly have a low Lighthouse speed score (when I test on mobile/desktop they load much quicker than stated by Lighthouse). When we look at other image rich sites (such as Airbnb, John Deere etc) the Lighthouse score can be 30-40. Our site https://www.equipmentradar.com/ loads quickly on Desktop and Mobile, but the Lighthouse score is similar to Airbnb and so forth. We have many photos similar to photo below, probably 30-40, many of which load async. Should we spend more time optimizing Lighthouse or is it ok? Are large images fine to load async? Thank you, Dave bg_05.jpg
Reporting & Analytics | | erdev0 -
Google analytics suddenly stopped tracking all my landing pages
Hey guys. I love the new update of GA. Looks so clean. So, of course, I was excited to see how my landing pages were doing. I went to behavior, all content, all pages. And I noticed it's only showing me 19 pages out of the 93 I have indexed. And none of the top ones at all! Can't find them anywhere in GA! Anyone seen this before? Thank you so much
Reporting & Analytics | | Meier0 -
Track conversion from paypal express/Apple pay
Hi All, Is there any way to track apple pay conversion or paypal express conversion in Google Analytics? Thanks
Reporting & Analytics | | Alick3000 -
Fixing Bounce Rate between Domain and Subdomain
Currently, the way our site is set up, our clients generally visit our homepage and then login through a separate page that is a subdomain, or they can read our blog/support articles that are also on separate subdomains. From my understanding, this can be counted as a bounce, and I know this sorta of site structure isn't ideal, but with our current dev resources and dependencies, fixing this isn't going to happen overnight. Regardless, what would be the easiest way to implement this fix witihn the Google Analytics code? EX: If someone visits our site at X.com, and then wants to login at portal.X.com, I don't want to count that as a bounce. Any insight is appreciated! Thanks
Reporting & Analytics | | KathleenDC0 -
Should I use sessions or unique visitors to work out my ecommerce conversion rate?
Hi all First question here but I've been lingering in the shadows for a while. As part of my companies digital marketing plan for the next financial year we are looking at benchmarking against certain KPIs. At the moment I simply report our conversion rate as Google Analytics displays it. I was incorrectly under the impression that it was reported as unique visits / total orders but I've now realised it's sessions / total orders. At my company we have quite a few repeat purchasers. So, is it best that we stick to the sessions / total orders conversion rate? My understanding is multiple sessions from the same visitor would all count towards this conversion rate and because we have repeat purchasers these wouldn't be captured under the unique visits / total orders method? It's almost as if every session we would have to consider that we have an opportunity to convert. The flip side of this is that on some of our higher margin products customers may visit multiple times before making a purchase. I should probably add that I'll be benchmarking data based on averages from the 1st April - 31st of March which is a financial year in the UK. The other KPI we will be benchmarking against is visitors. Should we change this to sessions if we will be benchmarking conversion rate using the sessions formula? This could help with continuity and could also help to reveal whether our planned content marketing efforts are engaging users. I hope this makes sense and thanks for reading and offering advice in advance. Joe
Reporting & Analytics | | joe-ainswoth1 -
Help With Understanding Chrome Web Store Analytics
Hi all, our website Creately is listed in the Chrome Web Store. Its not an extension or an app, but just a link to app which users can use to quickly log into the app and start drawing their diagrams. They do provide you a way to add Google Analytics to track some visitor data like user visits. But we want to figure out from which sections of Chrome Web Store is sending us traffic. When looking at the Source/Medium reports I can see the following. chrome-ntp-icon / (not set) chrome-app-launcher / (not set) chrome-ntp-launcher / (not set) chrome-app-launcher-search / (not set) chrome-app-launcher-info-dialog / (not set) I'm guessing these indicate where we're getting the traffic to the Chrome web store page but I can't seem to find any information about what they mean. Any help will be greatly appreciated.
Reporting & Analytics | | Nishadha0 -
Www.googleadservices.com/pagead/conversion_async.js what is this url doing on my site?
Hello Guys, I am using google tagmanager and i have configured adwords in tag manager now what i find is that this link - www.googleadservices.com/pagead/conversion_async.js showing on my homepage not in view source but when i do inspect element at that time it appears. So do you think after using google tag manager still i need to use the given link? Thanks, Raghu
Reporting & Analytics | | raghuvinder0 -
A/B Tests: How To Verify Difference In Average Order Value?
Hi there! When the data from an A/B test shows a difference in AOV between the variants, how do you determine if this difference is statistically probable or not? Best Regards, Martin
Reporting & Analytics | | TalkInThePark0
