Using same business number on different websites
I have number of websites in different locations with different business name and address with verified listings. However, I am thinking to use the same phone number on all the websites as it is difficult for me to keep track of all the numbers.
So, is it okay to use the same phone number on different websites with different business name and address?
Waiting for your thoughts.
Brian
If the call is ringing 10-12 times before the call forwarding provider connects with your phone, I would drop that provider. A good company will have a seamless transition so no one would ever know the difference when they call you. Who are you currently running tracking numbers through? Sounds like either you've set up too many redirects in the call system or the provider has some serious support issues.
Hi Brian,
As others in the community have rightly indicated, sharing a phone number across multiple websites is definitely a no-no. It may help to think of it this way. You have a Google My Business listing for your company, HappyTrees.com, and it points to your website. Google's bots travel from your GMB data to your website to cross-check for accuracy. They find your name, address and phone number on the website page your GMB listing points to and say, "A-okay, this checks out."
Then they crawl further and they begin to encounter the phone number you've got on your GMB listing and HappyTrees.com on BigTrees.com, TallTrees.com and GreenTrees.com. The bot stops and says, "Wait a minute, I thought this phone number belonged to Happy Trees. What's up with this? Hmm ... my data isn't trustworthy about this business. Likely, this shouldn't be ranking as well as this competitor here who clearly has this very consistent NAP."
Maybe a somewhat cartoon-ish explanation, but I find it can be helpful to visualize how Google may react to decisions you are making in your online marketing. One of your best bets for achieving high rankings is to have utterly consistent NAP across the ecosystem, and so, the following things can dilute this:
Any mismatches in name, address, phone, website anywhere on the web
Taking a multi-site approach instead of a single site approach
Duplicating your content across multi sites
Sharing details or interlinking between multi sites
The use of call tracking numbers in any local search campaign except in a very few instances which are described very well in these 2 posts:
http://blumenthals.com/blog/2014/11/25/guide-to-using-call-tracking-for-local-search/
http://localu.org/blog/truth-about-seo-call-tracking/
Any mistakes in these areas have been described as severely damaging to a business' ability to rank well for its desired terms, so a thorough study of the history of each of these types of issues would be your best bet for protecting your company against unwanted outcomes.
Hope this helps, and glad you've asked!
Hello All,
Thanks for replying.
I am already using a tracking number but the problem is if you call the business on our tracking number, it rings over 10-12 times before it’s picked up. This results in a large number of callers not leaving a message or just hanging up.
About how to answer, the nature of business is independent of where the call came from. The only thing matters is the call but as I said I am using tracking number and I cannot replace that service provider.
Further, as per the responses, I think it would be bad to put the same number. Is there any other solution?
Thanks in advance!
Under no circumstances if you want to rank for local results should you use the same telephone number for multiple locations or different companies that will destroy your ranking as you will compete against yourself and confuse Google. There are many excellent methods of getting additional phone numbers that are legitimate
do not mess with your NAP
Name
Address
Phone number
Level 3, jive communications, grasshopper, trilo, 8x8, Vonage, & Ringcentral are just a few that come to mind.
I believe you can save money on grasshopper in Moz.com/perks I can personally vouch for jive, grasshopper, trilo & 8x8 for inexpensive phone numbers trilo is tough to beat but may not be the exactly what you're looking for. I encourage you to look at all the phone systems I can tell you I think
http://grasshopper.com/blog/should-you-have-a-local-number-for-business/
http://grasshopper.com/blog/local-numbers-have-benefits-too-ya-know/
I assume that doesn't matter, otherwise the question asked wouldn't make sense.
But good point! I'd like to know the answer as well
SEO aside ... how would you know how to answer the phone?
Hi there.
It surely would look strange and maybe even suspicious in eyes of google. What about simple call forwarding? Just forward all calls from all of those numbers to your main one. Win-win situation.
Verifying Google My Business After An Address Change
Local Listings | | Ben-R
We are trying to verify our Google My Business listing, however, the current unverified listing is using an old address we no longer have access to. The only option for verification is through the mail. We tried requesting an edit but it didn’t go through. Would the best option be to create a new one and try to have the old (unverified) listing removed? Any insight would be appreciated. Thank you in advance.
Best,0 -
Can having a google business listing harm a company selling services globally?
Hi, We are a SAAS platform offering cloud based solution for educators. We had a google business listing in India and recently added one for US as well. Our keywords rank significantly better in India than in US. Is it a good idea to remove these business listing? Also, what could be other factors that impact GEO SEO rankings for a online company like ours?
Local Listings | | WizIQMarketing0 -
How to verify Google My Business (GMB) account in Dubai, United Arab Emirates (UAE)
Hi folks, I know the majority of you are based in the US, so won't be experiencing the same problem as me. I have set up a Google My Business account for a company here in Dubai, United Arab Emirates. The only problem is that I can't verify it using the normal methods like a postcard being sent out as the UAE doesn't have a postal service, so there are no postcodes to target an address. Basically I go through the process of creating a GMB account, setting the address details and map marker, then try to verify the account by postcard (this is the only way). I wait 14+ days but still no postcard arrives for obvious reasons - no postal address! So - my question is, how do we get round this problem? I know it can be done as there are plenty of businesses out there in Dubai that are verified on Google maps and GMB. Any advice or input would be greatly appreciated. Thanks
Local Listings | | SeoSheikh0 -
Another Business is Using My Client's Address
This morning my client contacted me that another business is using their address as their own! They received a Google verification postcard with pin number on it, but luckily had the foresight to not give it to the person when they called. After some research, we also found out that they are using our address on Facebook and LinkedIn as well. The kicker is: this business is another SEO firm! You would think they would know that using our address would cause NAP issues for their own business. Has anyone dealt with another business trying to hijack their address for local rankings? Any advice on steps to take to report this abuse would be appreciated. Since this person is obviously unscrupulous, we don't want to provoke them into taking any other negative action online that could affect our business.
Local Listings | | IlluminousGwen0 -
Google My Business for 2 Websites With the Same Location
Local Listings | | alihus
My client has two separate websites with different business names but under one location and phone number. The websites are for two separate services that he offers.
My question is that if creating two Google+ for business pages for the two businesses bad for their SEO or local ranks?
And what about creating local listings for both?(This does not seem logical to me personally!!)
Thank you for the kind answers in advance.0 -
How can I submit Baidu business listings if I live outside of China?
A client of our wants to manage business listings for three locations in China. We wanted to submit to Baidu but from what I've learned this is highly regulated (you live in China, pay a fee and call them to confirm). This is the only article I could find about submitting to Baidu: http://www.nanjingmarketinggroup.com/blog/baidu/how-can-baidu-maps-help-my-business Are there any conduit or 3rd party services available that can handle this? Thanks
Local Listings | | RosemaryB0 -
Removing phone number from GMB = lower rankings?
Hey, all! I have a client who needs for people to see her website before they call her, or else she spends 15 min explaining what's already on the site. Her Google My Business rankings are excellent for a lot of keywords (yay!), so people are seeing the number big and bold and just picking up the phone. I called GMB support to ask if removing the phone number would affect rankings, and they said "I don't think so". If this weren't a HUGE deal to the client, I wouldn't take the chance, but she feels that she's losing business by being on these calls when legitimate prospects try to call and get voice mail. So... any experience with removing phone numbers from GMB, or any other creative solutions to the quandary? Thanks so much for reading! ~ Scott UPDATE: Well, we went ahead and tried it anyway, and our GMB listins on the 7-pack nosedived! STRONGLY recommend against this, at least with the current algorithm!! The phone number is back now. 🙂
Local Listings | | measurableROI0 -
2 businesses same phone number
I was wondering how I should approach a scenario where I am optimizing two different companies websites that have the same phone number but different addresses. This sounds like a weird scenario, however it is out of my control. Is treating them as two separate companies fine, or do I have to take special precautions when submitting business directories and what not? Thanks for everyone's help! As a side note, is their a way to use Moz Local with both companies, right now it is getting confused as to what business belongs to what listing.
Local Listings | | brfieger0
