Duplicate content through product variants
Before you shout at me for not searching - I did and there are indeed lots of threads and articles on this problem. I therefore realise that this problem is not exactly new or unique.
The situation: I am dealing with a website that has 1 to N (n being between 1 and 6 so far) variants of a product. There are no dropdown for variants. This is not technically possible short of a complete redesign which is not on the table right now. The product variants are also not linked to each other but share about 99% of content (obvious problem here). In the "search all" they show up individually. Each product-variant is a different page, unconnected in backend as well as frontend. The system is quite limited in what can be added and entered - I may have some opportunity to influence on smaller things such as enabling canonicals.
In my opinion, the optimal choice would be to retain one page for each product, the base variant, and then add dropdowns to select extras/other variants.
As that is not possible, I feel that the best solution is to canonicalise all versions to one version (either base variant or best-selling product?) and to offer customers a list at each product giving him a direct path to the other variants of the product.
I'd be thankful for opinions, advice or showing completely new approaches I have not even thought of!
Kind Regards,
Nico
Hehehe yes we do usually!
Thanks for the hint!
Personally, I am a big fan of schema.org and marking up all the products has been on my further ToDo list.
Hi Martijn,
Thanks for your reply. I'll have to check with the responsible developer - but I fear that this option is not on the table. Then again, I have been hinted at that a complete redesign might eventually be. As I said below: Nobody who does SEO seems to have been around when the site was created. And we all know what happens in such a case, don't we?
Hi Matt,
If it were only that easy... I have since learnt that way back when the client had that website developed he specifically asked to NOT have an ecommerce website. (I, nor anybody advising on SEO, was not around back then AFAIK.)
The products are not connected. They are litereally independently created pages with the same template. The URLs are not parameter based but look like
http://www.example.de/category/subcategory1/subcategory2/product_name-further_description_1
http://www.example.de/category/subcategory1/subcategory2/product_name-further_descripittion_2
So, identical apart from the last bit that is NOT a parameter. And the last bit might be "750-kg" or "Alu" or "with-brakes". Thanks for the advice; I agree that it is generally a good starting point but sadly not possible in this case.
Just implemented something similar to this, and used canonicals. Also, if you're able to add more than just canonicals, possibly worth looking at microdata? We used schema.org isVariantOf for colors and size variants, not sure how much this influences googles understanding / search display, but it's widely recommended and seems unlikely to hurt. Implementing took a little trial and error, this helped as did google's schema testing tool.
What do the duplicate content URLs look like? In a lot of ecommerce systems you end up with parameter-based URLs such as:
http://www.example.com/products/women/dresses/green.htm
http://www.example.com/products/women?category=dresses&color=greenAccording to Google "When Google detects duplicate content, such as the pages in the example above, a Google algorithm groups the duplicate URLs into one cluster and selects what the algorithm thinks is the best URL to represent the cluster (and) tries to consolidate what we know about the URLs in the cluster, such as link popularity, to the one representative URL. However, when Google can't find all the URLs in a cluster or is unable to select the representative URL that you prefer, you can use the URL Parameters tool to give Google information about how to handle URLs containing specific parameters." (see more at Google Support)
If your URLs are parameter based I would suggest looking into handling them at that level in Search Console or (last resort) robots.txt as well. However, I'd start with canonicals and parameters if possible.
Hi Nico,
As you said it's far from prefect but I would indeed go with using a canonical on the pages that have duplicate variants. But if you're doing this already then it might be not that much more effort to also link them back on the back-end of your site so you can do more advanced things.
When should a variant be a variant and when should it be a separate product from an SEO POV?
Hi all, We are looking at changing our current e-commerce store to a new platform and in doing so thinking of making some changes to how we list products in sub-categories. We have seen related questions asking about splitting a single product into multiple products to rank for different terms, but we are wondering about combining multiple products into a single product page? The examples we have seen have been about fashion items with variants of colour and size. However, the products we sell have variances that change the appearance, dimensions and technical specification, so we would like to ask the MOZ community if combining products with these variances would still be deemed good practice? We sell wood burning stoves and a good example of a product that we are considering combining is the Scan 85 stove, which is available in eight different configurations: 85-1, 85-2, 85-3 etc. Scan themselves refer to each version as a separate product and they are bought, stocked and sold as separate products. Wood burning stoves like this typically have a firebox in the centre and then design options that can change the top, side, base, door, colour and fuel. In this example, the firebox is the Scan 85 and the variation is the last number, each of which corresponds to a different design option changing both the appearance and dimensions (see attached image). We have them listed as eight different products on our current site, one for each version. Primarily because each option has its own name (albeit 1-digit difference) which when we created the pages we thought that more pages would present us with more ranking opportunity. However, we have since learnt that because these eight pages are all so similar and it is difficult to write unique content about each product (with the 85-1 and 85-2 the only difference between the models are the black trim on the 85-1 and the silver trim on 85-2). Especially as when talking about the firebox itself, how well the fire burns, how controllable it is etc, will be the same for all versions. Likewise, earning backlinks to eight separate pages is also very difficult. Exploring this lead, us to the question, when is a variant a variant and when is it a separate product? Are there hard and fast rules for what defines variants and products? Or does it simply vary from industry to industry product to product, and if so should we be looking at it from a UX or SEO POV, when making that decision? Our hope is that if we combine these eight products into a single high-quality page, it will present us with a greater ranking opportunity for that one page over eight individual pages. We also hope that in doing so will allow us to create a more intuitive UX on a single page with a unique description, more reviews focused on one page and an explanation of the options available, all of which should lead to more conversions. Finally, by creating a better UX and unique detailed description we hope that there is a higher chance of us earning product level backlinks then we do with eight lower quality pages. One of the issues in creating a single product page for all the variants is the sub-category/results pages, as we would be removing eight simple products and replacing them with one complex product. We have questions over how this would work from a filter/facet level whereby when you apply a filter there is an expectation that the image shown will match the criteria, so if we filter for stoves with a silver trim for example, there is an expectation to only see stoves that have a silver trim in the results. When you have separate product pages you have separate listings which makes this easier to only bring back the models matching the criteria. However, when you have a single page this is more complex as you will need a default image for non-filtered results and then the ability to assign an image to lots of different attributes so that the correct image is always shown that matches the criteria selected. All of which we have been assured is do-able but adds an extra level of complexity to the process from an admin side. The alternative to doing this would be to create eight simple/child products and link them to one configurable/parent product. We could them list the simple products into the results pages and have them all linking back to the main configurable product which could load with the options of the simple product that was selected. From an SEO POV this brings in some more work, redirecting each page to the parent, but ultimately this could provide a better UX and might be the better solution. Has anyone got any experience in doing either of these options before? Both options above with affect the number of products we have available, so does the number of products in a sub-category effect the ability for that category page to rank? We currently have around 500 products in our wood burning stoves category, with perhaps an additional 300 to add. If we go down the combining into a single product page route this will reduce the number of products by around a third. If we keep all the simple/child products, then this will stay around the same. So, have we missed something obvious? Is there a glaring issue that we have overlooked from an SEO point of view as well as from the customer experience? We would appreciate your thoughts on this. Thanks, Reece scan85-1.jpg
Technical SEO | | fireproductsuk0 -
Duplicate Content on a Page Due to Responsive Version
What are the implications if a web designer codes the content of the site twice into the page in order to make the site responsive? I can't add the url I'm afraid but the H1 and the content appear twice in the code in order to produce both a responsive version and a desktop version. This is a Wordpress site. Is Google clever enough to distinguish between the 2 versions and treat them individually? Or will Google really think that the content has been repeated on the same page?
Technical SEO | | Wagada0 -
Query Strings causing Duplicate Content
I am working with a client that has multiple locations across the nation, and they recently merged all of the location sites into one site. To allow the lead capture forms to pre-populate the locations, they are using the query string /?location=cityname on every page. EXAMPLE - www.example.com/product www.example.com/product/?location=nashville www.example.com/product/?location=chicago There are thirty locations across the nation, so, every page x 30 is being flagged as duplicate content... at least in the crawl through MOZ. Does using that query string actually cause a duplicate content problem?
Technical SEO | | Rooted1 -
How does Google view duplicate photo content?
Now that we can search by image on Google and see every site that is using the same photo, I assume that Google is going to use this as a signal for ranking as well. Is that already happening? I ask because I have sold many photos over the years with first-use only rights, where I retain the copyright. So I have photos on my site that I own the copyright for that are on other sites (and were there first). I am not sure if I should make an effort to remove these photos from my site or if I can wait another couple years.
Technical SEO | | Lina5000 -
Duplicate content on job sites
Hi, I have a question regarding job boards. Many job advertisers will upload the same job description to multiple websites e.g. monster, gumtree, etc. This would therefore be viewed as duplicate content. What is the best way to handle this if we want to ensure our particular site ranks well? Thanks in advance for the help. H
Technical SEO | | HiteshP0 -
.com and .co.uk duplicate content
hi mozzers I have a client that has just released a .com version of their .co.uk website. They have basically re-skinned the .co.uk version with some US amends so all the content and title tags are the same. What you do recommend? Canonical tag to the .co.uk version? rewrite titles?
Technical SEO | | KarlBantleman0 -
Whats with the backslash in the url adding as duplicate content?
Is this a bug or something that needs to be addressed? If so, just use a redirect?
Technical SEO | | Boogily0 -
Are recipes excluded from duplicate content?
Does anyone know how recipes are treated by search engines? For example, I know press releases are expected to have lots of duplicates out there so they aren't penalized. Does anyone know if recipes are treated the same way. For example, if you Google "three cheese beef pasta shells" you get the first two results with identical content.
Technical SEO | | RiseSEO0
