Canonical issues using Screaming Frog and other tools?
In the Directives tab within Screaming Frog, can anyone tell me what the difference between "canonicalised", "canonical", and "no canonical" means? They're found in the filter box. I see the data but am not sure how to interpret them. Which one of these would I check to find canonical issues within a website? Are there any other easy ways to identify canonical issues?
Hello
I spotted this thread and was just about to reply, but Dirk has answered it all perfectly. Thanks Dirk!
Under 'reports' there's also a 'canonical errors' report which will show canonicals with various technical issues - Those that are blocked by robots.txt, have no response, 3XX redirect, 4XX or 5XX error (essentially anything other than a 200 ‘OK’ response). It will also show any URLs discovered only via a canonical, that are not linked to internally from the sites own link structure (in the ‘unlinked’ column when ‘true’).
Hope that helps anyway.
Cheers!
Dan
The difference between them
canonical : url has a canonical url - which can be self-referencing (canonical url = url) or not
canonicalised: url has a canonical url which is not self-referencing (canonical url <> url)
no canonical : quite obvious - the url has no canonical.
Potential issues could be - url's that you would like to have a canonical don't have a canonical or url's that are canonicalised don't have the right canonical url. You can use the lists (both canonicalised & no canonical) from Screaming Frog to check them - but it's up to you to judge whether the canonical is ok or not (no automated tool can guess what your intentions are).
Typical mistakes with canonicals: all url's have the same canonical url (like the homepage), or have canonical url's that do not exist. You could also check this with Screaming Frog using the setting "respect canonicals" - this way only the canonical url's will be shown in the listing.Also keep in mind that canonical url's are merely a friendly request to Google to index the canonical rather than the normal url - but it's not an obligation for Google to do this (check https://support.google.com/webmasters/answer/139066?hl=en quote: "the search results will be more likely to show users that URL structure. (Note: We attempt to respect this, but cannot guarantee this in all cases.)"
Dirk
What Tools Should I Use To Investigate Damage to my website
I would like to know what tools I should use and how to investigate damage to my website in2town.co.uk I hired a person to do some work to my website but they damaged it. That person was on a freelance platform and was removed because of all the complaints made about them. They also put in backdoors on websites including mine and added content. I also had a second problem where my content was being stolen. My site always did well and had lots of keywords in the top five and ten, but now they are not even in the top 200. This happened in January and feb. When I write unique articles, they are not showing in Google and need to find what the problem is and how to fix it. Can anyone please help
Technical SEO | | blogwoman10 -
Canonical or hreflang?
I have four English sites for four different countries, UK, Ireland, Australia and New Zealand and I want to share some content between the sites. On the pages that share the content, which is essentially exactly the same on all 4 sites, do I use the hreflang tags like: or do I add a canonical tag to the other three pointing to the "origin", which would be the UK site? I believe it is best practice to use one or the other, but I'm not sure which make sense in this situation.
Technical SEO | | andrew-mso0 -
Should we use Cloudflare
Hi all, we want to speed up our website (hosted in Wordpress, traffic around 450,000 page views monthly), we use lots of images. And we're wondering about setting up on Cloudflare, however after searching a bit in Google I have seen some people say the change in IP, or possible sharing of Its with bad neighbourhoods, can really hit search rankings. So, I was wondering what the latest thinking is on this subject, would the increased speed and local server locations be a boost for SEO, moreso than a potential loss of rankings for changing IP? Thanks!
Technical SEO | | tiromedia1 -
My backlinks are not showing in webmaster tools? Why
Hi Experts, I have follow backlinks from a domain for 6 months, but its not apear in Links to Your Site tools (search console) that domain has 302k indexed pages in google! Could you please explain me why google not showing this type of backlinks?
Technical SEO | | denakalami7 -
Set Canonical for Paginated Content
Hi Guys, This is a follow up on this thread: http://cloudz.click/community/q/dynamic-url-parameters-woocommerce-create-404-errors# I would like to know how I can set a canonical link in Wordpress/Woocommerce which points to "View All" on category pages on our webshop.
Technical SEO | | jeeyer
The categories on my website can be viewed as 24/48 or All products but because the quanity constantly changes viewing 24 or 48 products isn't always possible. To point Google in the right direction I want to let them know that "View All" is the best way to go.
I've read that Google's crawler tries to do this automatically but not sure if this is the case on on my website. Here is some more info on the issue: https://support.google.com/webmasters/answer/1663744?hl=en
Thanks for the help! Joost0 -
Using the Google Remove URL Tool to remove https pages
I have found a way to get a list of 'some' of my 180,000+ garbage URLs now, and I'm going through the tedious task of using the URL removal tool to put them in one at a time. Between that and my robots.txt file and the URL Parameters, I'm hoping to see some change each week. I have noticed when I put URL's starting with https:// in to the removal tool, it adds the http:// main URL at the front. For example, I add to the removal tool:- https://www.mydomain.com/blah.html?search_garbage_url_addition On the confirmation page, the URL actually shows as:- http://www.mydomain.com/https://www.mydomain.com/blah.html?search_garbage_url_addition I don't want to accidentally remove my main URL or cause problems. Is this the right way this should look? AND PART 2 OF MY QUESTION If you see the search description in Google for a page you want removed that says the following in the SERP results, should I still go to the trouble of putting in the removal request? www.domain.com/url.html?xsearch_... A description for this result is not available because of this site's robots.txt – learn more.
Technical SEO | | sparrowdog1 -
Issue with .uk.com domain
hi i have rockshore.uk.com which is not indexing properly. the internal pages do not show up for the text they have on them, or the title tags. the site is on aekmps shops platform. I understand that a .uk.com is not a proper TLD but i think i have a subdomain of .uk.com Can anyone help? thanks
Technical SEO | | Turkey0 -
What tool do you use to check for URLs not indexed?
What is your favorite tool for getting a report of URLs that are not cached/indexed in Google & Bing for an entire site? Basically I want a list of URLs not cached in Google and a seperate list for Bing. Thanks, Mark
Technical SEO | | elephantseo3
