Title Tag Capitalization Impact on SERP Rankings and Click Through Rates
My company made a branding decision to use lowercase for all of our title tags. This, of course, means that our titles on SERPs are all lower case. Overwhelmingly, it seems that websites use title case. This makes me wonder if we're shooting ourselves in the foot.
Does using lower case titles negatively impact our rankings and/or click through rates? Is there any data out there suggesting that title case has a better click through rate than lower case?
Thanks for reading!
Thanks John!
Your company's optimization tools are very interesting. I'd like to implement if possible...Do you have a way to integrate it w/ Amazon, similar to SERP Turkey's "Mechanical Turk?". See: http://www.tomanthony.co.uk/blog/amazon-mechanical-turk-serp-turkey/
I suppose for a small business, you would recommend running an optimization tool like yours or SERP turkey, then tracking the implementation w/ before and after from WMT using spreadsheets, correct?
If so, what is the minimum amount of impressions that should be collected to consider the data reliable? Our industry has relatively low search volume, so I would venture to guess that a set minimum time frame would make less sense than impression totals.
I do not think anything can be truly accurate or perfect online, the nature of bots, broken links, and again too many variables. But it is 100% improvement on the old search console. In short it is unquestionably more accurate than the old search console. The old search console had too many variables. The new search console, gives us more succinct information.
And on the cross comparison of data between old search console and new search console - I think this would have negligible utility - certainly not worth relying on. The way the data has been collated means it is not like for like. So yes, I think your experiments would be thrown off, but general trends maybe still be identifiable.
Hey John,
Thanks for your response. Do you believe the "Search Analytics" data in WMT is accurate? I just finished an experiment where I tracked clicks, impressions, CTR and avg. position (using data from WMT). However, I know that WMT data accuracy was an issue in the past which Google has supposedly fixed.
Since I started the experiments in mid March before the data accuracy was addressed, do you think my test could be thrown off?
Hey TheDude -
For my rudimentary test I recorded 28 days worth of WMT data (impressions, clicks, CTR, avg pos.) before the capitalization change, then measured 28 days worth of data after the change and measured the difference.
My results were inconclusive, but in favor of title casing. My company's SEO traffic is seasonal, so clicks and CTR have been on the rise independent of the capitalization changes. This makes it difficult to isolate the impact of my changes.
If I were to do it again, I would identify N eligible for change pages with comparable stats and then divide them 50/50 into test and control groups. Then I'd make the changes to the test group and measure. The test group lift vs. control group would have given a clearer picture of the impact of the capitalization change.
The dude
Yes we get uplift. But for small traffic sites it can be close to immeasurable. For large traffic sites, we find it easy to get data from WMT's to demonstrate uplift. I have not heard from solid gold, except he seemed to like the experiment results back when we did it, and was implementing.
On us, yes, we use our own tool, but the results are independently measurable from WMT's. The new updates in search console earlier this year, have been integral and precise to tracking impact.
So suggest you excel spread sheet keypages CTR & Clicks (data from WMT's) and then monitor changes post implementation. You cannot go wrong for more than a week...
Hey Solid_Gold and John,
I'm in the middle of rewriting our title tags to increase organic CTR as well. Did either of you find conclusive results with your tests?
John, I'm assuming you used your own tool Predikkta for testing, correct?
Solid_Gold, I see that you said you'd also run your own before/after tests to determine which title tags had a higher CTR. How did you go about testing this?
Thanks guys!
SG
We do consistently identify that customers in that 1/3 of a second when they scan the page are attracted to click on the "well written" & "proper english" result. There are rare exceptions but does not look like they are relevant in your case. Good luck with it, at least I think you have partially answered the branding decision with some hard data...
Very cool, John. Thank you for running the test.
What I'm seeing in the results is that all of the title case title tags are projected to outperform the lowercase title tag I selected as the baseline. Granted, your software warns "Not enough responses & care should be taken when using the predictions", the outcome supports my hypothesis that title case would perform better than all lower case.
From here, I intend to run some before & after tests on our title tags to see if I can measure differences in performance.
Thanks again!
Ok. Your experiment is live:-
website www.predikkta.com
username: chasingfireflies
password: 2mvs7h8vLogin and review results... It is live now. Good to see what you learn.
That's correct!
No problem and the keyword phrase typed into google appears to be "girls halloween costumes". Correct me if I am wrong.
Great, John. Thank you.
Assumed URL: http://www.chasing-fireflies.com/costumes-dress-up/girls-costumes/
8 title tags:
I'm most interested in measuring the difference between all lower case and title case, so I've included 2 versions of 4 title tags:
- girls halloween costumes | wishcraft by chasing fireflies
- Girls Halloween Costumes | Wishcraft by Chasing Fireflies
- girls costumes | costume & dress-up | chasing fireflies
- Girls Costumes | Costume & Dress-Up | Chasing Fireflies
- girls costumes - girls halloween costumes
- Girls Costumes - Girls Halloween Costumes
- girls costumes for halloween | chasing fireflies
- Girls Costumes for Halloween | Chasing Fireflies
8 descriptions (full disclosure: I've taken these from competitors' pages on SERPs. I assume that your test does not involve publishing any this. Please let me know if I'm wrong and need to provide original descriptions.):
- Magical dress-up and Halloween costumes designed for her and her doll, from Chasing Fireflies.
- Your little girl deserves to look her best this Halloween. Find everything you need for girls costumes & kids Halloween accessories at Chasing Fireflies!
- Cute Halloween costumes for girls at affordable prices. Shop for Disney girls costumes, animal-themed girls Halloween costumes, and more.
- Chasing Fireflies has the best selection of girls' Halloween costumes. You can find costumes for girls so she can look adorable this Halloween.
- The best, most popular Halloween costumes for girls are available at Chasing Fireflies. Everything from adorable classics to popular movie characters.
- Chasing Fireflies has girls' Halloween costumes. You can find adorable costumes for girls so they look as sweet as candy this Halloween.
- Girls Halloween costumes at the very best prices. Shop for girls Frozen costumes, princess costumes, girls Halloween costumes and more.
- Find popular girls Halloween costumes at Chasing Fireflies. Shop a huge selection of girls Halloween costumes featuring their favorite characters.
Let me know if this suits your needs.
Cheers!
For interest more than anything. A freebie. No cost.
We will not do a competitor test, we start with a self test, hence offering a self test. It will give you insight into the preferred way to present your title tags, descriptions etc. So you can run the baseline (current result) result against 7 other titles and descriptions see the outcomes. Can test up to 8 URL's as well, but assume the URL is static. This way you can play around with the capitalization and present some hard data to the people above...
Can you help me understand what you're proposing John?
You'd like for me to provide you 8 lower case title tag & description pairs from our website and you will test them against their title case counterparts? How would you do this? Are you offering to sell me Predikkta services or are you offering me a trial of some variety?
SG
Your keen to get it right. I can run an experiment or test it for you and get you a definitive answer. Hopefully settle the discussion.
If you list 8 possible Title tags and 8 possible descriptions - (include the ones your using now so you have a baseline) then I will run an experiment for you. Let you what combination is the most clickable. Can do it Monday.
So you can find out Monday if capitalized or not in your instance...
Thanks again for taking the time to reply, John.
I'm picking up what you're laying down about there not being rules.
That you said Hire Experienced Professionals | Thumbtack looks more professional and therefore might earn a higher CTR supports my hypothesis. To your point - such a change would need to be tested. In our case, most of current title tags are well within the 512px width limit, so truncation is not a big concern should we decide to switch from lower case to title case.
SG
We assume CTR is a google ranking factor - as it just makes sense ie we know CTR is a ranking factor for Adwords so we assume it is a ranking factor for organic search results.
On lower case -v- upper case - It really depends on a case by case basis - there is no other way.
We do find that proper capitalization, english and a clean looking title have a positive impact on CTR. But it depends on each SERP page.
I will give you a few examples:-
Lets say your title was the one below
Thumbtack - Accomplish your personal projects
If the company changed to the below, they would increase their CTR for new customers. Note increased Capitalization and simply looks more professional.
So this supports your hypothesis. However on the title below - Capitalization for each word has been used so based on the above as a general rule - it should have a better CTR. However it doesn't.
Cosmetics SFG Australia, Discount Make Up, Skin Care, H
Buy affordable makeup & beauty products | Cosmetics SFG
So by using the title starting "Buy affordable makeup.." - the CTR increased significantly. Why? To obtain this optimum Title, for SEO and clickability the company had to use lower case to come within the 512 pixels so the Ad did not truncate - and hence lose its customer friendliness.
I appreciate you are looking for rules but there are none. There are some general rules. ie at present from what we observe the pipe (|) has a higher CTR than the hyphen (-) - so we would recommend using the pipe. Also www. has a higher CTR than no www. on domain names.
But every instance needs to be carefully examined.
Finally say you are in the gambling space - our research shows - that when you want to gamble - it really does not matter what the Ad states - as long as it is passable, not off putting - it is all about position only. However for other SERP's ie "travel insurance" customers tend to scan the page in more detail. On those SERP's spend the time getting the balance between SEO & clickability right.
Not sure if I have assisted your argument to get capitalization, as indicated it all depends on your SERP that you are competing on.
Thanks Richard - I'm bookmarking the snippet optimizer!
Thanks for your response, John!
Re: rankings - I was thinking that if we were hurting CTR by using all lowercase that this in turn could harm our rankings since Moz's 2013 Search Engine Ranking Factors suggests that CTR is a ranking factor. Do you disagree with this?
We typically just use a headline format where the 1st letter of each word is capitalized with the exception of stop words (when used - but we of course, try to limit the use of these types of words in meta titles!)
I wouldn't have considered that the capitalization could impact rankings, however, I could see where it could have an effect on CTR.
I'm glad I stumbled upon this question to read some of the valuable comments made so far on this topic!
- Amiee
I've found using carefully placed all caps in certain parts of the description works great. Both the title and the description should have some type of cliff hanger or teaser at the end too. Take a look at the below example.
The SECRET to Smart META DATA is to Catch the EYE!!
Meta Data that has COMPELLING calls to ACTION & cleverly seeded BUZZ words achieves
FANTASTIC results for CTR. Great descriptions leave you hanging for...And I always use the mofoseo snippet optimizer so I know exactly whats its going to look like in the search results (provided Google doesn't change it)
There is no direct effect, having in lower case (title) impact ranking but it can decrease the CTR at some extent. IMO you should neither use all upper case nor all lower case. Best way is keep first alphabet of every word in caps.
Hope this helps.
I actually specialize in your question. In short there is no data either way. There are general rules.
The balance between clickability and SEO is integral to success for big companies defeating or mitigating page rank ie competing for big keywords like "car insurance" or "home loans". Small companies we find the problem is too granular - they go for title for SEO only. Small companies in fairness do not have time to research the balance.
The prime reason why no-one can give a definitive answer to your question is the title tag is generally only allowed to be 512 pixels. 1 pixel over and it truncates. So often you have to go lower case (optimize clickability) to fit within the 512 pixels or make lower case type adjustments to get to the optimum clickable headline. That said a general rule it is best to go with "proper pronunciation or spelling". It has a clear positive impact on clickability.
Our studies generally show that a Capitalized appropriate word in the right place has a higher impact on clickability.
However to be clear if this changes the title tag make up, ie it now truncates then it could be a disastrous decision for CTR. Finally and i will not go into detail here - it depends on your competitors title tags and descriptions on the relevant SERP.
So I appreciate you will hate the answer - but in short "it all depends".
Finally on rankings I have not heard that it would have any impact. So I would discount that. Though one of the myriad of factors for google on rankings would be spelling and "proper english". Though we deal with many companies where their branding is lower case, even capitalization second letter and it has not been an issue for them. So as indicated on rankings I would discount entirely but someone may have alternate views on same.
Page Speed or Site Speed which one does Google considered a ranking signal
I've read many threads online which proves that website speed is a ranking factor. There's a friend whose website scores 44 (slow metric score) on Google Pagespeed Insights. Despite that his website is slow, he outranks me on Google search results. It confuses me that I optimized my website for speed, but my competitor's slow site outperforms me. On Six9ja.com, I did amazing work by getting my target score which is 100 (fast metric score) on Google Pagespeed Insights. Coming to my Google search console tool, they have shown that some of my pages have average scores, while some have slow scores. Google search console tool proves me wrong that none of my pages are fast. Then where did the fast metrics went? Could it be because I added three Adsense Javascript code to all my blog posts? If so, that means that Adsense code is slowing website speed performance despite having an async tag. I tested my blog post speed and I understand that my page speed reduced by 48 due to the 3 Adsense javascript codes added to it. I got 62 (Average metric score). Now, my site speed is=100, then my page speed=62 Does this mean that Google considers page speed rather than site speed as a ranking factor? Screenshots: https://imgur.com/a/YSxSwOG **Regarding: **https://six9ja.com/
Reporting & Analytics | | Kingsmart1 -
Lower Impression higher clicks and CTR Compared to Previous Month?
I'm looking at our monthly traffic report and noticed that impressions were down in October compared to September but Clicks and CTR increased. I'm thinking it's because certain keyword increased in rank thus increase chances of a click through? Anyone else have any idea? Thank you in advance. Here is the data below: September:
Reporting & Analytics | | davidwang
Total clicks: 5071
Total impressions: 83429
Avg. CTR: 6.08%
Avg. Position: 28.4 October:
Total clicks: 5695
Total impressions: 79366
Avg. CTR: 7.18%
Avg. Position: 28.90 -
Impression and click discrepancies in Search Console when filtering by date
I recently filtered query information by week and day. The impression and click totals were different depending on whether I looked at totals by a full weeks or by day. So for example, the impression and click totals when I choose a date range of monday-sunday are different when I look at impressions and clicks that same week by day and then add up the click and impression numbers to get a weekly total. At first i was expecting a slight difference since I know the data is heavily sampled but the totals were very different. Any explanations for this? Thanks
Reporting & Analytics | | znotes0 -
Would updating Meta Titles affect Google analytics tracking?
Hi All, I need a little bit of help. We need to optimize our blog's articles Meta titles for SEO which all exceed 100 characters. I was told that if we change the titles, google analytics would split the tracking pages and count the data as 2 pages (old title and new title). Has any of you have this experience before and if so, is there a way to avoid google analytics counting this as two pages? Thanks in advance! Viviana http://analyteguru.com/ http://analyteguru.com/ http://analyteguru.com/
Reporting & Analytics | | mchoi0 -
Seeing massive spikes in direct traffic with 100% bounce rates
Hi all, Looking through Analytics yesterday, I saw that my website had a huge increase in direct traffic in sessions. However, they apparently spent 0 seconds on the website in total so that raised plenty of red flags. Does anyone have reasons why this might be? Spam or bug? Thanks in advance!
Reporting & Analytics | | Whittie0 -
Google Analytics and Bounce Rates Query - Should I block access from foreign countries ?
Hi , When I look at my google analytics for my UK Website, I can see alot of visits come from outside the UK , i.e Brazil and USA. Both of which give me almost 100% bounce rates from people visiting from there. I am wondering, if google looks at bounce rates with regards to ranking factors and should I therefore block access to my site from visitors outside the UK ?... Would this help increase my rankings ? Given that we only serve uk customers, I cant see any benefit of allowing non uk customers the ability to see the site . what does people think ? thanks pete
Reporting & Analytics | | PeteC121 -
Is it possible to use Google Tag Manager to pass a user’s text input into a form field to Google analytics?
Hey Everyone, I finally figured out how to use auto event tracking with Google Tag Manager, but didn't get the data I wanted. I want to see what users are typing into the search field on my site (the URL structure of my site isn't set up properly to use GA's built-in site search tracking). So, I set up the form submit event tracking in Google Tag Manager and used the following as my event tracking parameters: Category: Search Action: Search Value When I test and look in Google Analytics I just see: "search" and "search value." I wanted to see the text that I searched on my site. Not just the Action and Category of the event.... Is what I'm trying to do even possible? Do I need to set up a different event tracking parameter? Thanks everyone!
Reporting & Analytics | | DaveGuyMan0 -
Conversion Rate Question: Should I Measure Visits or Unique Visits?
When you measure conversion rates, is the equation: conversion rate = visits/conversions or conversion rate = unique visits/conversions I ask because it can actually make a pretty big difference in the conversion rate. For example, if you visit my ecommerce website 100 times before buying something (and assuming you're my only visitor), then my conversion rate is 100% _if I'm determining conversion rates by unique visits/conversions. _However, it's only 1% _if I'm determining conversion rates by visits/conversions. _Wow! Now this is clearly an extreme example, but it should serve to illustrate the point that in more reasonable cases, the way the data is measured can have a potentially significant impact on the conversion rate. Is there an industry standard for this? Am I missing something really basic? Also, here's a little bit of context for the question: I run an ecommerce website powered by the Magento CMS and I'm trying to measure my conversion rate in Google Analytics for individual products. Google Analytics shows me my site wide conversion rate, but apparently I have to do some customization in order to measure conversion rates on the product level. That's fine, but I want to make sure I'm measuring my product conversions in a standard way. Thanks for any and all help! Adam
Reporting & Analytics | | Adam-Perlman0
