How did I get over 1000 backlinks in less then a month? help?
Hi Guys
I'm a newbie and just started my website, im wondering if im reading this correctly, i use a tool called my seo tools and its telling me my website zenory.co.nz has over 1600 backlinks, this is scary since the site is only 5months old and i didn't see this till at least today and i check my sites backlinks on a regular basis. However when I check with moz it says I only have 2? I'm a little confused. Any advice here?
Much appreciated
Check with ahrefs or majestic, check the links manually or using a tool like link detox and then you'll know what needs to be done.
Hi MindlessWizard,
Thanks so much for your help! Yes, I contact the company myseotools who i use, and they said the results they feed from come via ahrefs, who are displaying these results incorrectly, in the meantime I had already contacted the web master to remove my link, so its good to know that I went ahead and did the right thing.
My question would be how long does it usually take for a company to refresh the results?
I checked you site with ahrefs.com and here is the backlink profile. So all of the backlinks coming from total of 16 domains. And here is something that you should look for
http://prntscr.com/6t64y7 1,623 backlinks coming from this domain. You can contact them and request to remove your listing from there. That solve half of your problem if they can remove your listing.
Hi Lewis
Thanks for that! This was also confusing as I checked moz and it was saying I only had 2 backlinks, which I couldn't make any sense of, so I sent the web master at the directory that were sending me all the links, works out it was because I was categorised in all regional categories which ended up in being over 900 categories, to which were all linking back to me... This is in the same industry as well, so when i checked the site pointing to me had good authority as well.
According to Open Site Explorer, you only have one external link going to your site.
Here's a step-by-step guide on how to use the disavow tool if you do have some dodgy links - http://cloudz.click/blog/guide-to-googles-disavow-tool
Hope this helps.
Lewis
Thanks Alick, seriously you have been so helpful!
Any idea on how I can go about using this disavow tool? I have heard about it but not sure how I go about applying it in the real SEO world lol
Hi Justin,
Yes you can do that and that would be the best if they remove & in the worst case if they don't remove or asking to pay leave them .You can use disavow tool and disavow entire that directory domain.
Hope this helps
Hi Alick300
I tried using ahrefs but I don't have an account with them. It does look like there are alot, would you recommend that I contact the owner to delist from the directory?
Hi Justin,
I have never use myseotools so I can't say about authenticity one thing I would like to mention here that huge number of links from same site is not good thing & Google can easily caught such links.
I would like to suggest to check in some other tools once if you are getting there such number of links then you have to consider it seriously
Hi Alick300
Yes I checked GWT i don't see anything thats come through from them yet?
When I check the myseotools for where the links where coming from, it looks like they are from a directory that i submitted my listing to under each region category that seems to be returning a link per region.
Hi Justin,
Did you check in Google webmaster tools? If not please do check how many links you are seeing there?
****Over 1000 links within a month is very suspicious if that tool showing current numbers. ****
If you have ahrefs tool please also check there . You will get correct data
My indexed site URL removed from google search without get any message or Manual Actions???
On Agust 2 or 3.. I'm not sure about the exact date...
White Hat / Black Hat SEO | | newwaves
The main URL of my website https://new-waves.net/ had been completely removed from Google search results! without getting any messages or Manual Actions on search console ?? but I'm still can find some of my site subpages in search results and on Google local maps results when I tried to check it on google
info:new-waves.net >> no results
site:new-waves.net >> only now I can see the main URL in results because I had submitted it again and again to google but it might be deleted again today or tomorrow as that happen before last few days
100% of all ranked keywords >> my site URL new-waves.net had been completely removed from all results! but I'm still can see it on maps on some results I never get any penalties to my site on Google search console. I noticed some drops on some keywords before that happens (in June and July) but it all of it was related to web design keywords for local Qatar, but all other keywords that related to SEO and digital marketing were not have any changes and been on top My site was ranked number 1 on google search results for "digital marketing qatar" and some other keywords, but the main URL had been removed from 100% of all search results. but you can still see it on the map only. I just tried to submit it again to Google and to index it through google search console tool but still not get any results, Recently, based on google console, I found some new links but I have no idea how it been added to links of my website:
essay-writing-hub.com - 9,710
tiverton-market.co.uk - 252
facianohaircare.com - 48
prothemes.biz - 44
worldone.pw - 2
slashdot.org - 1
onwebmarketing.com - 1 the problem is that all my high PR real links deleted from google console as well although it still have my site link and it could be recognized by MOZ and other sites! Can any one help to know what is the reason?? and how can I solve this issue without losing my previous ranked keywords? Can I submit a direct message to google support or customer service to know the reason or get help on this issue? Thanks & Regards0 -
How/Why do I have so many Spam backlinks?
I was looking in GWT yesterday and found we have several thousand "spam" backlinks...I am curious why this happens and how this happens? There are some links from websites/domains that are not mine that appear to be spam. However, we own a large group of domains and have noticed some of the links are coming from 2 of those sites/domains we own to my main site. The sites/domains are not active, we just own them. I am wondering how someone could access these domains that are not active and create spammy backlinks to my main website? (They created about 20,000 links). Thanks.
White Hat / Black Hat SEO | | carlystemmer0 -
Ever seen this tactic when trying to get rid of bad backlinks?
I'm trying to get rid of a Google penalty, but one of the URLS is particularly bizarre. Here's the penalized site: http://www.travelexinsurance.com. One of the external links Google cited as not being natural that links to the penalized site is: http://content.onlineagency.com/index.aspx?site=6599&tide=769006&last=3111516 In the backlink profile of the penalized site, there are about 100 different backlinks pointing to www.travelexinsurance.com from content.onlineagency.com/... So when I visit http://content.onlineagency.com/index.aspx?site=6599&tide=769006&last=3111516 it actually is displaying content from http://www.starmandstravel.com/787115_6599.htm, which you can see after clicking the "Home" button. That company is a legit travel agency who I assume knows nothing about content.onlineagency.com and is not involved in whatever is going on. And that's the case for every link from content.onlineagency.com. So I'm just wondering if someone can help me understand what sort of tactic content.onlineagency.com is using. One of my predecessors I fear used some black hat tactics. I'm wondering if this is a remnant of that effort.
White Hat / Black Hat SEO | | Patrick_G0 -
Why would links that were deleted by me 3 months ago still show up in reports?
I inadvertently created a mini link farm some time back by linking all of my parked domains (2000 plus) to some of my live websites (I was green and didn't think linking between the same owner sites / domains was an issue). These websites were doing well until Penguin and although I did not get any 'bad link' advices from Google I figure I was hit by Penguin. So about 3 or 4 months ago I painstakingly deleted ALL links from all of those domains that I still own (only 500 or so - the others were allowed to lapse). None of those domains have any links linking out at all but old links from those domains are still showing up in WMT and in SEOmoz and every other link tracking report I have run. So why would these links still be reported? How long do old links stay in the internet archives? This may sound like a strange question but do links 'remain with a domain for a given period of time regardless'? Are links archived before being 'thrown out' of the web. I know Google keeps archives of data that has expired, been deleted, website closed etc, etc for about 3 years or so (?). In an effort to correct a situation I have spent countless hours manually deleting thousands of links but they won't go away. Looking for some insight here please. cheers, Mike
White Hat / Black Hat SEO | | shags380 -
Are expired domains for Godaddy backlinks already reset by googel ?
When does Google actual reset backlinks to a domain. If i am buying expired domains from godaddy action for linking purpose am i wasting my time.Also if that the case whats the point of buying expired domains with many links pointing to them. If the backlinks to the expired domain still show up under my Google webmaster tool window does that mean Google counts that link?
White Hat / Black Hat SEO | | Ryguy870 -
Finding and Removing bad backlinks
Ok here goes. Over the past 2 years our traffic and rankings have slowly declined, most importantly, for keywords that we ranked #1 and #2 at for years. With the new Penguin updates this year, we never saw a huge drop but a constant slow loss. My boss has tasked me with cleaning up our bad links and reshaping our link profile so that it is cleaner and more natural. I currently have access to Google Analytics and Webmaster Tools, SEOMoz, and Link Builder. 1)What is the best program or process for identifying bad backlinks? What exactly am I looking for? Too many links from one domain? Links from Low PR or low “Trust URL” sites? I have gotten conflicting information reading about all this on the net, with some saying that too many good links(high PR) can be unnatural without some lower level PR links, so I just want to make sure that I am not asking for links to be removed that we need to create or maintain our link profile. 2)What is the best program or process for viewing our link profile and what exactly am I looking for? What constitutes a healthy link profile after the new google algorithm updates? What is the best way to change it? 3)Where do I start with this task? Remove spammy links first or figure out or profile first and then go after bad links? 4)We have some backlinks that are to our old .aspx that we moved to our new platform 2 years ago, there are quite a few (1000+). Some of these pages were redirected and some the redirects were broken at some point. Is there any residual juice in these backlinks still? Should we fix the broken redirects, or does it do nothing? My boss says the redirects wont do anything now that google no longer indexes the old pages but other people have said differently. Whats the deal should we still fix the redirects even though the pages are no longer indexed? I really appreciate any advice as basically if we cant get our site and sales turned around, my job is at stake. Our site is www.k9electronics.com if you want to take a look. We just moved hosts so there are some redirect issues and other things going on we know about.
White Hat / Black Hat SEO | | k9byron0 -
Article submission, and how to build backlinks for Ecommerce? [HELP]
Hi guys, I have a question, for high quality backlinks apparently you go to these article websites where you submit your site such as Ezine etc etc, however is it just one article you submit to these as it'll look like duplicate content? Also can I have it on my site first? How does it work? Also I run an ecommerce website, how can I build backlinks to each product, theres over 200+ products and 1.6k subcategories. I would like to rank for as many as possible but getting an SEO company to do this would cost to much. Any ideas on how I should go about it?
White Hat / Black Hat SEO | | InkCartridgesFast1 -
How do you deal with spammy backlinks?
One of the web designers I work with asked me to do a preliminary site assessment on a small business website. The owner of the business had a falling out with his previous web designer and moved over to the one I work with earlier this year. The site has been redesigned but when analyzing the back links I discovered that the previous designer had created directories to create backlinks to the page. The PR 0 links from the site number about 150 and are from unrelated topic pages. So, it made me wonder, how much damage can spammy backlinks do? What is the best practice to deal with spammy backlinks if you find them?
White Hat / Black Hat SEO | | TheARKlady0
