Subdomain for ticketing of a client website (how to solve SEO problems caused by the subdomain/domain relationship)
We have a client in need of a ticketing solution for their domain (let's call it www.domain.com) which is on Wordpress - as is our custom ticket solution. However, we want to have full control of the ticketing, since we manage it for them - so we do not want to build it inside their original Wordpress install.
Our proposed solution is to build it on tickets.domain.com. This will exist only for selling and issuing the tickets.
The question is, is there a way to do this without damaging their bounce rate and SEO scores?
Since customers will come to www.domain.com, then click the ticketing tab and land on tickets.domain.com, Google will see this as a bounce. In reality, customers will not notice the difference as we will clone the look and feel of domain.comShould we perhaps have the canonical URL of tickets.domain.com point to www.domain.com? And also, can we install Webmaster Tools for tickets.domain.com and set the preferred domain as www.domain.com?
Are these possible solutions to the problem, or not - and if not, does anyone else have a viable solution?
Thank you so much for the help.
Hi Adam,
Are the ticket pages on the sub domain the same as the event pages on the main domain except with the ticketing system included? If yes it would make more sense to canonical each event ticketing page back to the same event page so: tickets.domain.com/event1 -> domain.com/event1.
If the ticketing pages are not meant to be indexed at all then I would put the robots no index tag on them also (or a robots file on the whole subdomain) and keep an eye on GWT to make sure none of them creep in. Canonical tags are a 'recommendation' not a rule so if your plans are for these pages to not be indexed at all best to ensure that as completely as possible.
Hey Leo!
Thanks for the taking the time to answer me. I am going to set this up exactly as you recommend.
1. I will install the same GA code from domain.com on tickets.domain.com
2. Do you think I need to set the canonical URL on the various ticketing pages all back to the main domain?
e.g. tickets.domain.com ---> canonical to domain.com
e.g. tickets.domain.com/event1 ---> canonical to domain.com
e.g. tickets.domain.com/event2 ---> canonical to domain.com
e.g. tickets.domain.com/event3 ---> canonical to domain.com
and so on?3. We did make all the header links of tickets.domain.com point straight back to their counterpart on domain.com.
Does this seem like I basically got it all correct?
Thanks again
Adam -
HI,
If technically that is the best solution for your needs then a couple of things to keep in mind:
1. If you are using Universal Analytics subdomain tracking is included by default so if you put the same analytics code on your subdomain pages then you should not be seeing any 'bounces' - google should be able to figure this out also.
2. You can install GWT for the subdomain also. I dont think you can set the preferred domain for a subdomain setup but you can use GWT to monitor issues and make sure that duplicate pages for the subdomain are not getting indexed.
3. To avoid indexing of the subdomain pages (which I assume you don't want) you could canonical them to their equivalent on the www domain. You could also meta robots no-index them all. If they creep in anyway you can use GWT to remove them.
If the subdomain is a complete clone and the experience is seamless then why not make all links on the subdomain go back to the www domain pages. That way the only pages available on the subdomain would be the ticketing pages and the rest would be on the www as normal.
Hope it helps.
What's your proudest accomplishment in regards to SEO?
After many years in the industry, you come to realize a few things. One of of the biggest pain points for us at web daytona was being able to give clients a quick keyword ranking cost estimation. After multiple trial and error and relying on API data from one of the most reliable SEO softwares in our industry, we were able to develop an SEO tool that allows us to quickly and accurately get the estimated cost for a given keyword (s) using multiple variables. Most agencies can relate to that story. It’s something my colleagues and I at Web Daytona have been through before. Finding the cost and amount of time needed to rank for a keyword is a time consuming process. That’s why it’s a common practice to sell SEO packages of 5-10 keywords for about $1000-2000 / month. The problem is not all keywords are equally valuable, and most clients know this. We constantly get questions from clients asking: “how much to rank for this specific keyword?” It’s difficult to answer that question with a pricing model that treats the cost of ranking every keyword equally. So is the answer to spend a lot more time doing tedious in-depth keyword research? If we did we could give our clients more precise estimates. But being that a decent proposal can take as long as 2-5 hours to make, and agency life isn’t exactly full of free time, that wouldn’t be ideal. That’s when we asked a question. What if we could automate the research needed to find the cost of ranking keywords? We looked around for a tool that did, but we couldn’t find it. Then we decided to make it ourselves. It wasn’t going to be easy. But after running an SEO agency for over a decade, we knew we had the expertise to create a tool that wouldn’t just be fast and reliable, it would also be precise. Fast forward to today and we’re proud to announce that The Keyword Cost Estimator is finally done. Now we’re releasing it to the public so other agencies and businesses can use it too. You can see it for yourself here. Keyword-Rank-Cost-Ectimator-Tool-by-Web-Daytona-Agency.png
Local Website Optimization | | WebDaytona0 -
Is there any way to report a website that is not complying with webmaster guidelines to Google?
Like how we can "suggest an edit" in Google Business Listings, is there any way to report Google about the webmaster guidelines violation?
Local Website Optimization | | Alagurajeshwaran0 -
I have a client in Australia that is going to set up a website that is in Chinese to service their Asian customer base (Indonesia, Singapore, HK, China). What domain should they use?
They're website is hosted on a .com.au domain. Should they host their Chinese language pages under their current domain (.com.au) using a subdirectory (i.e. /asia) or should they use another separate domain that they own that is a regular .com? Or does it really not matter?
Local Website Optimization | | 100yards1 -
SEO and Main Navigation Best Practices
I've read a number of articles on SEO and main navigation for websites. I'd like to get a solid answer/recommendation to help solve this one. This is the situation. We're helping a local business that offers pest control and property maintenance services. Under each of these, there area a number of services available, eg, cockroach control, termite inspections or lawn mowing services, rubbish removal and so on. Is it best to have a main nav containing the top keywords for the services - Pest Control | Property Maintenance, with a drop down to the services under each. Or, a simple approach - Our Services > drop down to each - Pest Control > Termite Inspections, etc. My concern here is that they have quite a lot of services, so the nav could be way too long. Really appreciate any assistance here. Many thanks.
Local Website Optimization | | RichardRColeman0 -
How to correctly move subdomain to subfolder (google webmaster)?
Hello, This is my first post in here 🙂 I just wondered what is the correct way to move a subdomain to subfolder? I've moved it, re-done sitemap, so that main website would include a subfolder, as they are part of one big website now (it was something like a blog on a subdomain). Subdomain now does correct 301 redirects. Submitted new sitemap to google, asked google to re-fetch the whole domain (thus subfolder should be re-fetched too, as it's part of main nav). The areas i'm in doubt: I can tell google that the domain got moved, however it is moved to the one that is already approved in the same account, but is in a subfolder, so should i do this? Or should i simply somehow erase it on webmaster? The blog was launched about a month ago, and it isn't perfectly optimized yet, it wasn't on google SERPs pretty much at all, excluding googling it straightly, and there are pretty much 0 traffic from google, almost all of it is either direct either referral, mostly social, Thanks, Pavel
Local Website Optimization | | PavelGro920 -
Does multiple sites that relate to one company hurt seo
I know this has been asked and answered but my situation is a little different. I am a local electrical contractor. I specialize in a service and not a product. Competition is high in the local market due to the other electrical contractors that have well seasoned sites with very good DA/PA. Although new to the web I am not new to the trade. Throughout years almost back to the AOL dialup days I have been collecting domain names for this particular purpose. Now I want to put them to good use. Being an electrical contractor, there are many different facets of work and services we provide. My primary site is empireelec.com A second site I threw online overnight with minimal content is jacksonvillelightingrepair.com. Although it is a fresh site, there is minimal content and I have put almost zero effort in to it. It appears to be ranking for keywords a lot quicker. That leads me to believe I should utilize my other domain jacksonvillefloridaelectrician.com and target just the keyword Jacksonville Florida Electrician. It leads me to believe I should use jacksonvillebeachelectrician.com for targeting electricians in jacksonville beach. And again with jacksonvilleelectricianservice.com I can provide a unique phone number for each site. Am I going about this all wrong? Everything I read says no,no,no but I feel my situation is a little more unique.
Local Website Optimization | | empireelec1 -
Country/Language combination in subdirectory URL
Hello, We are a multi country/multi lingual (English, Arabic) website. We are following a subdirectory structure to separate and geotarget the country/language combinations. Currently our english and arabic urls are the same: For UAE: example.com/ae (English Site) For Saudi Arabic: example.com/sa (Saudi Arabia) We want to separate the English and Arabic language URLs and I wanted to know if there is any preference as to which kind of URL structure we should go with : example.com/ae-en (Country-Language) example.com/en-ae (Language-Country) example.com/ae/en (Country/Language) Is there any logic to deciding how to structure the language/country combinations or is is entirely a matter of personal preference. Thanks!
Local Website Optimization | | EcommRulz0 -
Is translating my SEO meta data to new languages worthwhile?
When translating a website to additional languages, is it recommended, for Google SEO purposes, that the keywords, re-written URLs, meta titles and meta descriptions of each page be translated as well; or have those elements been completely depreciated?
Local Website Optimization | | sptechnologies0
