Does using Sucuri block Moz?
I am using Opensite explorer on my site which uses Sucuri and it shows 0 for everything. Does Sucuri stop MOZ from reading the link?
I also suspect that using Sucuri has made my SEO suffer because the first page is always saying "redirecting" . Anyone with experience to this? Thanks
I use Sucuri cloud proxy and it has never affected my sites in any way. If you tell it to block the IP's or referral domain it will do so. If you do not it considers Moz/ Roger Bot & Dot Bot as white hat and does not block them unless you request that it does.
their user agents are right here
http://cloudz.click/community/q/what-is-the-full-user-agent-for-rogerbot
you can request that Sucuri check and make sure you are not being blocked. With that said I just ran a test on the site above and the only bots that are being blocked bad bots.
if you find this is not true for you simply tell Sucuri.net support inside the dashboard to Speak to support There phone number is 1–888–873–0817 they will tell security operations Center or( SOC) to white list anything you want white listed
Could you possibly share a screenshot of the redirect your talking about?
Tt sounds to me like you have a redirect issue on your server that could be blocking dotbot ( the bot for open site Explorer)
To determine whether or not a robots.txt file or a no index page is doing this please use the tools below their free and will give us a lot of information quickly & make sure your robots.txt is not blocking it.
To check regarding search engines or bots being redirected using this tool
http://tools.seochat.com/tools/search-engine-friendly-redirect-checker/
to re-create a robots.txt file that works and will not block anything if that is the case use this tool.
http://tools.seochat.com/tools/online-robots-txt-generator/ ( Site maps may not be official but do help if they're in the robots.txt file)
** last but not least run your site through this tool and make sure nothing is out of whack.**
- http://www.feedthebot.com/tools/
- http://cloudz.click/tools/crawl-test ( do not be surprised if this does not work as may use the same bot being blocked by a number of different things)
- If you continue to have problems and Sucuri tell you that they are not blocking it.
- Look into using Deepcrawl.co.uk or screaming frog SEO spider
- I even run a free audit on deep crawl for you if everything above does not work.
I hope this helps,
Tom
Thanks Joe for the thumbs up on Sucuri based on your experience. Have tweaked the settings on Sucuri and opensite is able to detect it. Will continue to monitor it.
Appreciate the sharing of your experience with Sucuri, Joe.
Eric
Thanks Abe, you are right. Went to tweak the settings at sucuri and the opensite explorer worked. Cheers and appreciate the response
Thanks for the reply Ryan. Appreciate.
Robot.txt is ok, went to tweak the settings in sucuri and the opensite is able to detect it.
Cheers,
Eric
We do use Sucuri on some of our clients websites with high rankings and no crawl or ranking issues. I agree with Ryan it's some other issue you are having. Just wanted to let you know from direct experience with Sucuri not having any issues for us. Best Regards,
Joe
Hello and thanks for reaching out to us! While I don't have any personal experience with Sucuri, there are certainly website protection tools out there that can mess with our crawl attempts. If you can send your campaign name and web address to [email protected], we'd love to take a look at that for you!
Doubtful. Several sites mentioned on their clients page are showing numbers in OSE. Try out a few from: https://sucuri.net/clients/. Chances are you have a robots.txt issue blocking OSE, the site is brand new, or it's on a tld domain that is currently not compatible with OSE, such as http://example.website If you list your site here more details could be provided. Cheers!
Problem with third party cookies while using MOZ?
Hello, I am using Moz Pro and I am happy to have this tool for my SEO work. But I am having a little problem while working on my blog site https://thepoolparadise.com/ some times the Moz does not work and asks to allow third-party cookies, wherein the settings third-party cookies are always allowed. Please guide me in this matter. Thank you.
Link Explorer | | Niujbuj760 -
Why my website Backlinks not getting Crawl by Moz?
Hi, I've the query related to backlinks of my website. Some of the high authority sites give backlinks to my website but these links are still not showing in Moz. My website is 6 months old and also continuously getting backlinks from high authority sites but still these are not showing on Moz and also not improving DA and PA of my website. I've also attached the screenshot of Moz link explorer results please check and guide me what to do with website so Moz will consider it and give some authority. And also guide me How much Moz takes time to crawl website backlinks and shown in their link explorer. Website URL: https://www.welderexpert.com Moz Expert Suggestions needed. Thanks, overview?site=welderexpert.com⌖=domain
Link Explorer | | KOidue0 -
Ranking Keywords are not showing on Moz
i just check my Apk Finds on moz site explorer and check its ranking keywords but it does not show it please help me my site age is 3 months
Link Explorer | | malik12378670 -
Moz tool to estimate a website's organic traffic?
Moz has tons of great tools, so I was quite suprised there is nothing similar to Alexa's siteinfo tool, or SimilarWeb's site comparison tool. Am I missing something? Or does such a tool exists at Moz? Or is there a different way of estimating my competitor's traffic? It would be great if Moz would have something like that.
Link Explorer | | GrandRapids0 -
Moz's new Link Explorer, including our revamped index and DA/PA scores is now open to everyone!
Hey Moz Community, Link Explorer is now open to the public! Everyone can access it via a subscription or a free Moz ‘Community’ account. As you may know by now, the brand-new Link Explorer tool is primed to replace Open Site Explorer as Moz’s link building and analysis tool. The Link Explorer project is the result of an incredible amount of perseverance and hard work by the team, and we’re proud to be able to finally share it with you — we know it’s going to revolutionize how you approach link building and make your job easier. You can read more about the tool here in Sarah Bird’s announcement post. Because Link Explorer improves on almost every aspect of Open Site Explorer, the metrics have improved, too. That means you’re likely going to see some Domain Authority and Page Authority discrepancies between OSE’s index and Link Explorer’s index. We definitely suggest you use the new DA/PA from Link Explorer, as they’re more accurate and refresh daily rather than monthly, as was the case with OSE’s index. However, we also realize that many of you use these metrics to report to your clients and colleagues, and a sudden change or fluctuation could potentially make your job harder. Which DA is the real DA? The new DA is based on a much larger index that has many improvements, several of which are designed to make the index more like Google’s than ever before. You should consider moving towards the new DA (and the old DA won’t be updated after April 26th 2018, so the sooner the better). While there will be fluctuations as we improve the model and add features to the index, we expect it to remain largely stable and to be a far more accurate picture of a site’s authority according to how it’s seen by Google. Why is Link Explorer’s DA/PA considered better than OSE’s, and which should I trust? The larger link index with improved crawl selection allows us to produce a stronger model that includes a much larger proportion of the web. That being said, DA and PA should always be considered in the context of your competitors. A drop in PA or DA relative to the old OSE is of little concern if your competitors saw similar movement. Is Domain Authority/Page Authority an absolute score or a relative one? Both DA and PA are relative to the Internet as a whole. If Facebook acquired a billion new links, everyone’s PA and DA would drop relative to Facebook. Because of this, it’s always best to look at PA and DA in comparison to your competitors. What does a drop/raise in DA mean in Link Explorer vs OSE? How can I explain this to my clients when I’m reporting it? DA and PA should always be considered in the context of your competitors. A drop or raise in PA or DA relative to the old OSE is of little concern if your competitors saw similar movement. Reporting that your site has moved from a DA of 45 to a DA of 42 doesn’t tell the whole story, but reporting that your site has a DA of 42 while your main competitor moved from a 43 to a 37 shows that, relative to the sites you’re competing against in the SERPs, your site has significantly more authority and ranking power. What’s happening to MozTrust and MozRank and why, and what should I replace those with? The improvements to our DA/PA and Spam Score metrics now now account for more important nuances in helping you determine one site’s ability to rank higher than another. Because they no longer correlate with Google’s ranking model as well as they used to, MozRank and MozTrust are being deprecated for better metrics. Users should rely on Page Authority, Domain Authority, and Spam Score to determine the importance and quality of pages, domains, and links. I have historical data I use to help my clients benchmark their progress. What do I do now that DA is calculated differently? You should annotate any KPI changes referencing the change in DA and PA. However, most importantly, you should compare those changes to your competitors, as this will best show how strong your site’s authority is relative to the sites you’re competing against in the SERPs. We take updating our metrics very seriously, and our last major update to the model was 7 years ago. Users of Domain Authority and Page Authority can expect us to continue to produce steady, reliable metrics for the long haul, and only make changes to these metrics when we believe the benefits dramatically outweigh the stability of the metric. Do you have any questions about the new metrics? Anticipating a tough time reporting changes to clients or bosses? Metrics, features or functionality missing that you would want to see? Let us know in the thread, and we’ll work to find a good answer for you. Hope you enjoy the new Link Explorer product and the amazing new link index powering it. We are very excited to provide this valuable data to our community and customers.
Link Explorer | | IanWatson9 -
Fastest way to get new backlinks recognised by Moz?
Hi all, I have seen a few discussions / advice pieces around this, but wondered what the current view is on the fastest way to get new backlinks recognised by Moz? I have seen people say that the content needs to be shared (e.g. on Twitter), and advice around creating Bitly links. I am not convinced that these techniques are working. On a related note, my website is very large. I have around 2.5m pages. Most of these pages are 3-4 clicks from the home page, but I have a small amount of important content much higher up in the site (1-2 clicks from the home page). Does Moz crawl pages nearer the home page more frequently, or does it make a pass of all pages on the site before it starts at the beginning again? If it makes a complete pass of all pages, then presumably making my site smaller will help to get Moz to see new content more quickly? Is there any other value to be gained in making a large site smaller? Many thanks in advance, Neil.
Link Explorer | | NHARRIS10 -
How to force moz to crawl my backlinks?
I have some good number number of backlinks in my webmaster tools. But, open site explorer is showing very few backlinks. How to force moz to crawl all the backlinks? Or is there any way to submit backlinks to moz?
Link Explorer | | sankar7890 -
Does Moz have anything similar to ahrefs batch analysis tool?
I am wanting to do analysis of a whole bunch of URLs at once - i know ahrefs already has a very good tool for this - but I don't really want to have to pay the $79 a month if moz has something similar? I know it has the OSE. Can I do batch analysis in this? Thanks
Link Explorer | | SWD.Advertising1
