How do you implement dynamic SEO-friendly URLs using Ajax without using hashbangs?
We're building a new website platform and are using Ajax as the method for allowing users to select from filters. We want to dynamically insert elements into the URL as the filters are selected so that search engines will index multiple combinations of filters. We're struggling to see how this is possible using symfony framework. We've used www.gizmodo.com as an example of how to achieve SEO and user-friendly URLs but this is only an example of achieving this for static content.
We would prefer to go down a route that didn't involve hashbangs if possible.
Does anyone have any experience using hashbangs and how it affected their site?
Any advice on the above would be gratefully received.
Hey,
so I guess you're wanting to achieve this (http://extensions.ecommerce-team.com/apparel?___store=shopbypro&reset_filter=1) - aor something similar using ajax so the page updates without re-loading?
I guess you need to use token's in the url path rather than a dynamic url. Its a big job as you'll have to define some rules to say colour must come first, brand second, range last or something similar so you end up with domain.com/brown/levis/jackets/ - is that right?
Essentially its working as a site search with some defined rules, so you'd have to think about the following:
404's - if your pages are built on queries, a user could potentially create a link to a page domain.com/brown/jackets/f**k/, obviously this would need to return a 404 or this could be indexed.
Canonical - the previosu point brings about dudplicate content issues, if you don't define the rules then you could have /brown/jackets/levis/ vs. /brown/levis/jackets/ showing the same content, so there needs to be some canonical management.
So you can use ajax to call a particular URL, you would need to use the filters as links ( <a>tags) so the pages are crawled and pull that content (search results) back, the url wouldn't changes though unfortunately, but it would still be linked to from the</a> <a>tag.</a>
<a>Is there a specific reason why you don't want to use a hashbang?</a>
Is using a subheading to introduce a section before the main heading bad for SEO?
I have noticed a popular trend in web design which involves sections of content being started with what looks to be smaller sub heading something like <h3>, <h4> or <h5> and then followed by a bigger heading <h2>. My question is, what is the best way to deal with this visual structure and will having a structure like this hurt your SEO? <h5>Contact Us</h5> <h2>Get started with your next project in minutes!<h2> <p>Some text here ...</p> Here are some examples where the header structure is similar to above (smaller before bigger): https://www.snappr.com/ https://form.taxi/ https://fluz.app/ If that structure is bad for SEO, then it seems like a simple solution is to make it purely visual, mimicking a sub header with styling on a span or paragraph like these sites do: https://www.andrejilderda.nl/ https://nightwatch.io/ https://www.swingvy.com/ https://www.figma.com/ My only concern with that approach is because your section sub heading is no longer an actual header you will miss out on ranking important and relevant keyword information for that section. Is this correct something to be worried about? There is one last solution I stumbled upon that involves using headings for both but in reverse hierarchy so a <h3> is first but styled to be smaller, followed by a visually bigger <h4> which provides the addition context. https://avocode.com/ Anyone have thoughts, expertise or resources on the matter?
Intermediate & Advanced SEO | | si.analytics0 -
My url disappeared from Google but Search Console shows indexed. This url has been indexed for more than a year. Please help!
Super weird problem that I can't solve for last 5 hours. One of my urls: https://www.dcacar.com/lax-car-service.html Has been indexed for more than a year and also has an AMP version, few hours ago I realized that it had disappeared from serps. We were ranking on page 1 for several key terms. When I perform a search "site:dcacar.com " the url is no where to be found on all 5 pages. But when I check my Google Console it shows as indexed I requested to index again but nothing changed. All other 50 or so urls are not effected at all, this is the only url that has gone missing can someone solve this mystery for me please. Thanks a lot in advance.
Intermediate & Advanced SEO | | Davit19850 -
How To Implement Breadcrumbs
Hi, I'm looking to implement breadcrumbs for e-commerce store so they will appear in the SERP results like the attached image. In terms of implementing to a site, would you simply add HTML to each page like this Google example? Which looks like this: Books › Science Fiction Award Winners Then is there anything you need to do, to get this showing in the SERPs results e.g. doing something in search console. Or do you just wait into google has crawled and hopefully starts showing in the SERPs results? Cheers. wn3ybMMOQFW98fNQkxtJkA.png [SERP results with bread crumbs](SERP results with bread crumbs)
Intermediate & Advanced SEO | | jaynamarino0 -
Should I include URLs that are 301'd or only include 200 status URLs in my sitemap.xml?
I'm not sure if I should be including old URLs (content) that are being redirected (301) to new URLs (content) in my sitemap.xml. Does anyone know if it is best to include or leave out 301ed URLs in a xml sitemap?
Intermediate & Advanced SEO | | Jonathan.Smith0 -
Replace dynamic paramenter URLs with static Landing Page URL - faceted navigation
Hi there, got a quick question regarding faceted navigation. If a specific filter (facet) seems to be quite popular for visitors. Does it make sense to replace a dynamic URL e.x http://www.domain.com/pants.html?a_type=239 by a static, more SEO friendly URL e.x http://www.domain.com/pants/levis-pants.html by creating a proper landing page for it. I know, that it is nearly impossible to replace all variations of this parameter URLs by static ones but does it generally make sense to do this for the most popular facets choose by visitors. Or does this cause any issues? Any help is much appreciated. Thanks a lot in advance
Intermediate & Advanced SEO | | ennovators0 -
Does having a ? on the end of your URL affect your SEO?
I have some redirects that were done with at "?" at the end of the URL to include google coding (i.e. you click on an adwords link and the google coding follows the redirected link). When there is not coding to follow the link just appears as "filename.html?". Will that affect us negatively SEO-wise? Thank you.
Intermediate & Advanced SEO | | RoxBrock1 -
If you have an unlimited SEO budget, what would you do?
Here's a bit of background information: I've achieved the targets and is now being offered what is essentially an unlimited budget. I have a nice list of ideas but thought I would the brilliant people here at the SEOMOZ community what they would do. So as to promote as much response as possible, I'm going to keep my list to myself for now. And by "SEO", I mean I can do things like content strategy, blogging, infographics, etc. Shoot away!
Intermediate & Advanced SEO | | andrep0 -
Are URL shorteners building domain authority everytime someone uses a link from their service?
My understanding of domain authority is that the more links pointing to any page / resource on a domain, the greater the overall domain authority (and weight passed from outbound links on the domain) is. Because URL shorteners create links on their own domain that redirect to an off-domain page but link "to" an on-domain URL, are they gaining domain authority each time someone publishes a shortened link from their service? Or does Google penalize these sites specifically, or links that redirect in general? Or am I missing something else?
Intermediate & Advanced SEO | | Jay.Neely0
