Image URLs changed 3 times after using a CDN - How to Handle for SEO?
Hi Mozzers,
Hoping for your advice on how to handle the SEO effects an image URL change, that changed 3 times, during the course of setting up a CDN over a month period, as follows:- (URL 1) - Original image URL before CDN:www.mydomain.com/images/abc.jpg
- (URL 2) - First CDN URL (without CNAME alias - using WPEngine & their own CDN):
username.net-dns.com/images/abc.jpg - (URL 3) - Second CDN URL (with CNAME alias - applied 3 weeks later):
cdn.mydomain.com/images/abc.jpg
When we changed to URL 2, our image rankings in the Moz Tool Pro Rankings dropped from 80% to 5% (the one with the little photo icons).
So my questions for recovery are:
- Do I need to add a 301 redirect/Canonical tag from the old image URL 1 & 2 to URL 3 or something else?
- Do I need to change my image sitemap to use cdn.mydomain.com/images/abc.jpg instead of www.?
Thanks in advance for your advice.
Sorry I missed this follow-up earlier. Within the site map you'll want to change the http://WWW to http://CDN for these image files. The www version of your site, and the cdn server are on two different IPs / server. You want images to be serving from the CDN one.
For 2, if you do use 301 redirection I'd recommend scripting it so that the script inspects whether or not it's an image file and then applies the cdn change. A pro in your area that works with REgex and htaccess will be able to guide you through that.
The username.net-dns.com thing... That's not your server is it? You can't apply redirects on servers outside of your control. Cheers!
Hi Ryan,
Thanks for your answer - Sorry I didn't mean about the URL for the location of the sitemap - I think my question wasn't clear - may I rephrase it:(1) Inside my image sitemap, the urls serve off the www. subdomain as bolded in the example below (not .cdn). I'm assuming this setup is correct as this was auto-generated by an Image Sitemap Generator - does the below image:loc look correct to you?
<url><loc>http://www.bosphorusyacht.com/yachts/</loc>
image:imageimage:lochttp://**WWW.**bosphorusyacht.com/wp-content/uploads/2010/09/istanbul-boat-rental.jpg</image:loc></image:image></url>(2) For a 301 image redirect would I set it up like this:
Redirect 301 /wp-content/uploads/2010/09/istanbul-boat-rental.jpg
http://**WWW.**bosphorusyacht.com/wp-content/uploads/2010/09/istanbul-boat-rental.jpgOR
http://**CDN.**bosphorusyacht.com/wp-content/uploads/2010/09/istanbul-boat-rental.jpgOR
How would I 301 this one?: username.net-dns.com/images/abc.jpg
Hope you can advise one last time - thank you!
Right. Not everything is going to be served from cdn. It's most likely setup for your images so your sitemap will still reside on www. Make sure to point to the front end files though as those are the publicly accessible ones.
Hi Ryan,
Thanks for your reply and advice. I've read the guidelines and will follow those. But I wonder if you can clarify an issue on implementing them that is not answered there:On my site the images in 'Backend' (edit/admin/code view) start with WWW.mydomain... and in 'Frontend' (actual published view in browser) they start with CDN.mydomain...
So my question is, do I use the Backend or Frontend (www. or cdn.) for the URL in both image sitemaps and in 301 redirect final destination?
My current sitemap for example seems to be using www rather than cdn. : http://www.bosphorusyacht.com/sitemap-image.xml
Thanks for your help!
You're on it. Redirecting to the new image source and submitting a new sitemap pointing to the URL 3 location for your images will be big steps in the right direction. Be sure to follow the instructions here for your sitemap: https://support.google.com/webmasters/answer/178636 as well as reviewing image publishing guidelines: https://support.google.com/webmasters/answer/114016. Cheers!
Which are the best off-page SEO techniques for 2020?
I have just published an awesome website or blog, and i really worked hard keeping everything perfect. Do you think it’s enough? Having a perfect blog, website or business is just enough. i need readers for my blog, visitors to my website, and customers for my business. So, what to do?
Local Website Optimization | | boxinghunter0 -
In local SEO, how important is it to include city, state, and state abbreviation in doctitle?
I'm trying to balance local geographic keywords with product keywords. I appreciate the feedback from the group! Michael
Local Website Optimization | | BFMichael0 -
Using geolocation for dynamic content - what's the best practice for SEO?
Hello We sell a product globally but I want to use different keywords to describe the product based on location. For this example let’s say in USA the product is a "bathrobe" and in Canada it’s a "housecoat" (same product, just different name). What this means… I want to show "bathrobe" content in USA (lots of global searches) and "housecoat" in Canada (less searches). I know I can show the content using a geolocation plugin (also found a caching plugin which will get around the issue of people seeing cached versions), using JavaScript or html5. I want a solution which enables someone in Canada searching for "bathrobe" to be able to find our site through Google search though too. I want to rank for "bathrobe" in BOTH USA and Canada. I have read articles which say Google can read the dynamic content in JavaScript, as well as the geolocation plugin. However the plugins suggest Google crawls the content based on location too. I don’t know about JavaScript. Another option is having two separate pages (one for “bathrobe” and one for “housecoat”) and using geolocation for the main menu (if they find the other page i.e. bathrobe page through a Canadian search, they will still see it though). This may have an SEO impact splitting the traffic though. Any suggestions or recommendations on what to do?? What do other websites do? I’m a bit stuck. Thank you so much! Laura Ps. I don’t think we have enough traffic to add subdomains or subdirectories.
Local Website Optimization | | LauraFalls0 -
Can PPC harm SEO results, even if it's off-domain?
Here's the scenario. We're doing SEO for a national franchise business. We have over 60 location pages on the same domain, that we control. Another agency is doing PPC for the same business, except they're leading people to un-indexable landing pages off domain. Apparently they're also using location extensions for the businesses that have been set up improperly, at least according to the Account Strategists at Google that we work with. We're having a real issue with these businesses ranking in the multi-point markets (where they have multiple locations in a city). See, the client wants all their location landing pages to rank organically for geolocated service queries in those cities (we'll say the query is "fridge repair"). We're trying to tell them that the PPC is having a negative effect on our SEO efforts, even though there shouldn't be any correlation between the two. I still think the PPC should be focused on their on-domain location landing pages (and so does our Google rep), because it shows consistency of brand, etc. I'm getting a lot of pushback from the client and the other agency, of course. They say it shouldn't matter. Has anyone here run into this? Any ammo to offer up to convince the client that having us work at "cross-purposes" is a bad idea? Thanks so much for any advice!
Local Website Optimization | | Treefrog_SEO0 -
Which is the best, ".xx" or ".com.xx" in general and for SEO?
Hi, I'm working for a digital marketing agency and have traffic from different countries. We are planning to make different websites for each country. What is the best SEO practice to choose the domain between ".xx" or ".com.xx" from Spain, Mexico, Chile, Colombia and Peru?
Local Website Optimization | | NachoRetta
I think that the ccTLD is better always, for example ".es" better than ".com.es"0 -
Google my business - Image sizes
I have scoured the web in order to find a guide that would give me the ideal dimensions for images to populate google my business page... in vain. Google itself is very vague about it as indicated below Format: JPG, PNG, TIFF, BMP Size: Between 10 KB and 5 MB Minimum resolution: 250px tall, 250px wide Does anyone know of a guide with optimum recommendation for each photo (profile, Cover photo, business specific photos...) or alternatively can recommend the exact size needed. Thanks
Local Website Optimization | | coolhandluc0 -
How Google's Doorway Pages Update Affects Local SEO
Hey Awesome Local Folks! I thought I'd take a proactive stance and start a thread on the new doorway pages update from Google, as I feel there will be questions coming up about this here in the forum: Here's the update announcement: http://googlewebmastercentral.blogspot.com/2015/03/an-update-on-doorway-pages.html And here's the part that will make local business owners and Local SEOs take a second glance at this: Here are questions to ask of pages that could be seen as doorway pages: Do the pages duplicate useful aggregations of items (locations, products, etc.) that already exist on the site for the purpose of capturing more search traffic? I think this will naturally lead to questions about the practice of creating local/city landing pages. At this point, my prediction is that this will come down to high quality vs. crummy quality pages of this type. In fact, after chatting briefly with Andrew Shotland, I'm leaning a bit toward seeing the above language as being strongly geared toward directory type sites and large franchises. I recommend reading Andrew's post about his take on this, as I think he's on the right track: http://www.localseoguide.com/googles-about-to-close-your-local-doorway-pages/ So, I'm feeling at this point that if you've made the right efforts to develop unique, high quality local landing pages, you should be good unless you are an accidental casualty of an over-zealous update. We'll see! If anyone has thoughts to contribute on this thread, I hope they will, and if lots of questions start coming up about this here in the community, feel free to link back to this thread in helping your fellow community members 🙂 Thanks, all!
Local Website Optimization | | MiriamEllis9 -
Does building multiple websites hurt you seo wise? Good or bad strategy?
HI,rategy. So I spoke to a local Colorado seo company and they suggested to find whatever keywords is the most searched under my GWT's and put .com behind it and build other sites for other keywords. I was curious about this type of strategy. Does this work? This seo guy said I could just get a DBA bank account and such for each domain name etc. I am not wanting to mislead anyone, but I am curious if for the sake of promoting other services, if creating other websites with partial and EMD's are worthwhile? Another issue I worry about is if I put my companies phone number, then next thing you know there is 3 or 4 sites that use that same phone number. To me this does not build trust with Google. But being I am learning, maybe this is a common strategy, or doomed from the start. Just curious what you think. Would you build other sites to try and rank for other services? Or keep one sites and maximize it? Thank you for your thoughts. I just do not want to pay $3000 per site if it will hurt not help.
Local Website Optimization | | Berner0
