Will interlinking using dynamic parameters in url help us in increasing our rankings
Will interlinking our internal pages using dynamic parameters(like abc.com/property-in-noida?source=footer) help us in increasing our rankings for linked pages OR we should use static urls for interlinking
Regards
Hi Anirban,
I think a better question would be, "whats the best way to link to my internal content when using dynamic parameters?"
You can definitely link this way to your internal content if you really want to measure the effectiveness of your footer links. BUT, just make sure you have a canonical tag on all the pages - not just the pages you're linking to with a dynamic parameter to analyze link performance on the footer.
If you want to measure the link effectiveness of all your links pointing to any piece of internal content, I'd probably rethink how important that is for you and think of your long term goals of your site first before doing something like that; it may be more work for you. However, as long as you have the canonical tag in place, this is something you shouldn't worry about.
With regards to your initial question, if you don't use a canonical tag on all your pages (at least the ones you plan on linking to), you're going to be throwing away any link juice you think you're passing to it.
I hope this helps you.
I don't think so. The purpose of internal linking is to flow link juice so I don't think if you use url with parameters(& or ?) will help to improve ranking.
it is recommended that standard HTML links is good for internal linking.
You can also check moz guide for best practices
http://cloudz.click/learn/seo/internal-link
Website rankings drop significantly after moving to new hosting provider
My website - www.isacleanse.co.nz has dropped from being top10 rankings for all of my keywords to not even being in top 50 after just checking now. It used to be hosted on: www.1stdomains.nz
Web Design | | IsaCleanse
It got migrated to Sitground servers about a month ago See attached screenshot - would moving hosting provider cause such a huge drop? Or would there be anything else I should be looking at ? J2ahi0 -
Help with error: Not Found The requested URL /java/backlinker.php was not found on this server.
Hi all, We got this error for almost a month now. Until now we were outsourcing the webdesign and optimization, and now we are doing it in house, and the previous company did not gave us all the information we should know. And we've been trying to find this error and fix it with no result. Have you encounter this issue before? Did anyone found or knows a solution? Also would this affect our website in terms of SEO and in general. Would be very grateful to hear from you. Many thanks. Here is what appears on the bottom of the site( www.manvanlondon.co.uk) Not Found The requested URL /java/backlinker.php was not found on this server. <address>Apache/2.4.7 (Ubuntu) Server at 01adserver.com Port 80</address> <address> </address> <address> </address>
Web Design | | monicapopa0 -
Question Mark In URL??
So I am looking at a site for a client, and I think I already have my answer, but wanted to check with you guys. First off the site is in FLASH and HTML. I told the client to dump the flash site, but she isn't willing right now. So the URLS are generated like this. Flash: http://www.mysite.com/#/page/7ca2/wedding-pricing/ HTML: http://www.mysite.com/?/page/7ca2/wedding-pricing/ checking the site in Google with a site:mysite, none of the interior pages are indexed at all. So that is telling me that Google is pretty much ignoring everything past the # or ?. Is that correct? My recommendation is to dump the flash site and redo the URLS in a SEo friendly format.
Web Design | | netviper0 -
Does a loading homepage animation effect rankings?
Our website ( panphoenix dot com) has a Javascript animation when you load it for the first time which takes just over 2 seconds to load. Does having this animation effect rankings negatively? Would appreciate your thoughts!Thanks Rob
Web Design | | roberthseo0 -
How to put 'Link to this article' HTML code at bottom of article & is it helpful?
Hello, I was thinking about putting a box down at the bottom of my client's main articles that let's the reader easily copy the html code it takes to link to the article they're reading. Maybe I'd put it after the author bio. Do any of you do this? If so, what format do you use? It has to look nice of course. This is a non-techie industry. Thanks.
Web Design | | BobGW0 -
My Site Is Using A Lot of Hosting Bandwidth. Suggestions?
My website http://www.socialseomanagement.com/ is using tons of bandwidth. I received a message from the hosting company saying I exceeded my monthly bandwidth and it has only been a few days. Can anyone take a look and make suggestions? Thanks
Web Design | | JChronicle0 -
Best Website Builder - Help Me Choose
I need to built a multi language site (to built a Pilates, Yoga site) and I will use a site builder. After posting questions on wix.com I came to the fact I should continue my research because there are not SEO friendly. Do you have a suggestions? Limited to html knowledge, using a website builder is my only option. Here are some of the features I need: Multilanguage Web Site Mobile version SEO Friendly Nice Template Selections( this is important) HTML customization Twitter, Facebook, Blog... I'm not looking at free website builder, when you want good features, there is a price to paid. Thank you for your help and suggestions, BigBlaze
Web Design | | BigBlaze2050 -
Does using Wordpress Multisite have any negative SEO impact?
I manage multiple websites in Wordpress and the idea of managing them all under one Wordpress install is very attractive. Are there any dangers SEO-wise to doing so? I know that all of the sites would live under the same IP address, but that's not something I'm really concerned with anyway because I don't do a lot of inter-linking between the sites. Thanks for your help! -El Juano
Web Design | | JonathanFashbaugh0
