Do I have a problem with missing pages in Screaming Frog?
We have category pages and some of those pages have pagination due to us having additional items. Screaming Frog could not find the items that were after page 1. Is this a problem for Google? These item pages are still in the sitemap. I am sure they can find them to index them but does it hurt rankings at all.
Check your settings in Screaming Frog for obeying robots.txt, obeying canonicals, etc. That might be your problem.
Big Fan!
Yes the pages are in the Google Index, I'll message you the URLs.
Hey Niners52! You a 49ers fan?
In my experience, yes, if ScreamingFrog cannot crawl those pages, you will definitely have an issue being crawled by Google as well. Are any of those pages/items currently in Google's index?
Would you mind sharing the URL with me? If so I'd be happy to take a look into it and see if I can help further.
How to find orphan pages
Hi all, I've been checking these forums for an answer on how to find orphaned pages on my site and I can see a lot of people are saying that I should cross check the my XML sitemap against a Screaming Frog crawl of my site. However, the sitemap is created using Screaming Frog in the first place... (I'm sure this is the case for a lot of people too). Are there any other ways to get a full list of orphaned pages? I assume it would be a developer request but where can I ask them to look / extract? Thanks!
Technical SEO | | KJH-HAC1 -
My Website's Home Page is Missing on Google SERP
Hi All, I have a WordPress website which has about 10-12 pages in total. When I search for the brand name on Google Search, the home page URL isn't appearing on the result pages while the rest of the pages are appearing. There're no issues with the canonicalization or meta titles/descriptions as such. What could possibly the reason behind this aberration? Looking forward to your advice! Cheers
Technical SEO | | ugorayan0 -
Indexed pages
Just started a site audit and trying to determine the number of pages on a client site and whether there are more pages being indexed than actually exist. I've used four tools and got four very different answers... Google Search Console: 237 indexed pages Google search using site command: 468 results MOZ site crawl: 1013 unique URLs Screaming Frog: 183 page titles, 187 URIs (note this is a free licence, but should cut off at 500) Can anyone shed any light on why they differ so much? And where lies the truth?
Technical SEO | | muzzmoz1 -
Exclude status codes in Screaming Frog
I have a very large ecommerce site I'm trying to spider using screaming frog. Problem is I keep hanging even though I have turned off the high memory safeguard under configuration. The site has approximately 190,000 pages according to the results of a Google site: command. The site architecture is almost completely flat. Limiting the search by depth is a possiblity, but it will take quite a bit of manual labor as there are literally hundreds of directories one level below the root. There are many, many duplicate pages. I've been able to exclude some of them from being crawled using the exclude configuration parameters. There are thousands of redirects. I haven't been able to exclude those from the spider b/c they don't have a distinguishing character string in their URLs. Does anyone know how to exclude files using status codes? I know that would help. If it helps, the site is kodylighting.com. Thanks in advance for any guidance you can provide.
Technical SEO | | DonnaDuncan0 -
Error: Missing Meta Description Tag on pages I can't find in order to correct
This seems silly, but I have errors on blog URLs in our WordPress site that I don't know how to access because they are not in our Dashboard. We are using All in One SEO. The errors are for blog archive dates, authors and just simply 'blog'. Here are samples: http://www.fateyes.com/2012/10/
Technical SEO | | gfiedel
http://www.fateyes.com/author/gina-fiedel/
http://www.fateyes.com/blog/ Does anyone know how to input descriptions for pages like these?
Thanks!!0 -
Diagnosing Canonical Errors Is Screaming frog reliable?
Morning from suny & warm wetherby UK 🙂 On this page http://www.goldsboroughestates.co.uk/how-we-care-for-you/right-to-manage/ screaming frog is citing a canonical error but I'm confused as this piece of code is in place: http://www.goldsboroughestates.co.uk/About/right-to-manage" /> So my question is please - "Does this page http://www.goldsboroughestates.co.uk/how-we-care-for-you/right-to-manage/ have a caninical error or is screaming frog useless? Other examples where screaming frog is picking up canonical errors include:
Technical SEO | | Nightwing
http://www.goldsboroughestates.co.uk/what-our-customers-say/right-to-manage/
http://www.goldsboroughestates.co.uk/buying-a-home/right-to-manage/ Oh forgot to say the preffered version is http://www.goldsboroughestates.co.uk/About/right-to-manage/ Any insights welcvome 🙂0 -
Trailing Slash Problems
Link juice being split between trailing slash and non versions. ie. ldnwicklesscandles.com/scentsy-uk and ldnwicklesscandles.com/scentsy-uk/ Initially asked in here and was told to do a rewrite in the htaccess file. I don't have access to this with squarespace, nor can I add canonical tags on a page by page basis. 301 redirect from scentsy-uk to scentsy-uk/ didn't work either...said that the redirect wasn't completing in an error message on the browser. Squarespace hasn't been very helpful at all. My question is....is there another way to fix this? or should I just call it a day with squarespace and move to wordpress?
Technical SEO | | cmjolley0
